Old 03-27-2003, 05:53 PM   #1711
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by rc-zombies
yea..it's pricey...
$50.00 is not too bad, that's how much I paid for mine....Ordering from Rainbowten $41.00 + $8-10 to ship.
but at least HPI made an effort to get some in the US to sell and
show they still support the PRo3.
Good point....
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 03-27-2003, 07:34 PM   #1712
rchotrod's Avatar
Thumbs up pro3 parts
I have been wanting that graphite chassis since they showed it to us on the website.
just ordered one from buyhpi.
My pro3 is mostly stock with the prp top deck and with this new chassis my 3 will be even more solid. That chassis will be sweet.
I still race my pro3 and do quite well with it. I always liked the idea of the batteries down the center.
I kinda like being the only 3 at the track. Kinda makes ya feel like an underdog.
Later
Rod
rchotrod is offline   Reply With Quote
Old 03-27-2003, 08:21 PM   #1713
newracer's Avatar
R/C Tech Charter Subscriber
popsracer...
do you need a front one-way? I have one to sell along with some other parts...left over after I sold my Pro3
what other parts do you have? I plan on running my pro3 for a long time.
newracer is offline   Reply With Quote
Old 03-28-2003, 05:29 AM   #1714
Thanks.
I try the WD40 strick. see how that works.
To popsracer.
I forgot the Alu spur gear adapter and alu clapon hexhubs in the hopup list.
Havend had the time to run the car yet but i will try it with one springrate difference front to back and i will try the rear uperlink.
I also changed the droop to 1mm in front and 3 in the back.
I don't have that much money now for the upperdeck and i cant order a prp upperdeck (live in the Netherlands and don't have a creditcard.) as some of u will have noticed that european car parts are relativly expensive in the US well HPI parts cost twice as much in the Netherland!!!
The only one i can get my hands on is the one from HPI itself but i heard its a struggle to get the battery's in and out.
I see how the above settings work out for me and see if i order the 3deg c-hubs to start with.
Any one have experiance with the HPI UPPERDECK!!!!
Thanks,
Whacky.
Whacky is offline   Reply With Quote
Old 03-28-2003, 10:49 PM   #1715
popsracer's Avatar
Default Whacky;
I had Powerpole connectors on my Pack before the HPI Upperdeck installation and there was NO WAY they were going to fit with the Upper Deck. I even left it off for a while. What I did was install the small Euro Plugs on my Packs (side-X-side). It is a tight fit, but they go in and out reasonably easy.
The 3 degree Front Hubs will help the Car run a tighter line in the corners. The HPI Upper Deck helped some too along with the Graphite suspension Arms. Last major change was Raising the Rear Camber link to the top hole on the Hubs. The Car is VERY good now. Good enough where I don't feel the need to make changes everytime I drive it. Racing on Concrete this weekend, I'll let you Guys know how it turns out.
popsracer is offline   Reply With Quote
Old 03-29-2003, 04:06 PM   #1716
Thanks Popsracer.
I tried the wd40 trick on the front belt and it still is tight (left it in the wd40 for 12 hours).
Should it be more lose after the wd40 bath or does it loosen up faster when driving the car.
Whacky.
Old 03-31-2003, 11:50 AM   #1717
popsracer's Avatar
Guys;
Got 3rd this weekend in Sportsman Stock "A" with the Pro-3. Had 2nd for a while, but a corner dot flub and a backmarker mishap kept me from catching 2nd place a for second time. The 1st place Guy got out front and drove a perfect race.
REALLY HAPPY with the cars performance and I Want to thank you all again for the help that you've provided me.
Side note: I made some minor changes to the TL01 that we have and it was Dialed too. Just need to work on the weight issue and freeing up the drivetrain.
Thanks, Steven
Old 03-31-2003, 11:57 AM   #1718
rc-zombies's Avatar
popsracer
Great job on the race...
next time I know you'll be 1st!
Old 03-31-2003, 01:58 PM   #1719
popsracer
Pops' is always 1st in my Book j/k
BTW good Job Pops'
-Dave
Old 03-31-2003, 02:40 PM   #1720
pops where you racing at? You ever come to socal?
teamAE is offline   Reply With Quote
Old 03-31-2003, 07:46 PM   #1721
popsracer's Avatar
Default Thanks to my online Friends
Thanks Guys.
teamAE;
Hobby People Fountain Valley. I'm a Nitro person first and a Electric second, so no So-Cal for me. Plus I live in San Bernardino and it's a long drive just to race electric.
(BTW, I got 1st in the Expert Nitro main too at the same race.)
Old 04-02-2003, 04:18 AM   #1722
Great job popsracer .
Keep the PRO3 alive and running.
About the TL01 drivetrain: Degrease the Ball bearings, use the carbon propeller shaft and use a teflon based grease on the gears, this makes up for a very smooth drivetrain.
The carbon propellor shaft is +/- 28grams lighter than the stock one.
Greatz
-Whacky.
Old 04-02-2003, 05:36 AM   #1723
sosidge's Avatar
Don't let the avatar fool you!
I'm still running the Pro 3, and I've finally got it handling consistently (graphite arms are the key). It used to change character between every run, but now I can leave the setup the same and really feel how the track conditions/tyres are.
It's just that after two years, i'm a bit bored of it.
I do fancy one of those Yokomo's, but I'm effectively out of work from Saturday, so I think I should watch the wallet a bit...
...then again, we all deserve a treat from time to time, and what are credit cards for anyway?
Old 04-02-2003, 08:53 AM   #1724
Whacky.
Anyone Please!
-Whacky.
Old 04-03-2003, 12:07 PM   #1725
rayhuang's Avatar
Hello,
I am going to be putting together my Pro3 next week for racing on temporary use, but treated Asphalt tracks.
Car must remain 100% box stock HPI!! Springs and all to be legal for the HPI Challenge this summer. You guys have already been a lot of help-but now I need to know where to start with the Camber links and shock locations and spur and pinion for a MOnster motor. 64 pitch preferably. This is what I have now!!!
Set of 27r with red inserts on dish rims.
Set of 33r with red inserts on dish rims.
HPI Mondeo and ALfa 190mm bodies with optional wing kit.I realize I will be making changes as I go-but I need to be put in the ballpark!!!
Thanks,
Ray
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
