Old 02-26-2003, 07:07 PM   #1621
popsracer's Avatar
Default pro3
JDM_DOHC_SiR;
I really do not understand how a car can be driveable with so much camber. Even on my Nitro cars I only run -1.5 with Foams. Believe me I have tried to run more Camber, but the cars always inherit undesirable handling traits when i do. If I feel the need to run the one-way again, more rear toe is always an option. But in Stock class anything that scrubs off speed is bad so one would cancel out the other.
Front set-up:
3 deg Caster blocks, 2 deg. Kick-up (5 deg total caster)
-0- Front toe
-1 deg Camber, 2mm spacer between link and block (stock setting)
4.5mm Ride Height, 2mm Droop
Inner camber links mounted in kit location
Shocks mounted in kit locations
(Have to go look and see what springs I'm using)
popsracer is offline   Reply With Quote
Old 02-26-2003, 08:05 PM   #1622
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: pro3
Originally posted by popsracer
JDM_DOHC_SiR;
Front set-up:
-0- Front toe
Your font set up is also very close to mine hmmm
what Oil are you running..??
as for springs I run HPI Light Blues all the way around... but sometimes Pink up front..
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-26-2003, 08:17 PM   #1623
lee82gx's Avatar
i do this to check for camber,and it mainly concerns ride height.
i push the car down on one side,add the most amount of roll(by pulling up the other side),and see if they wheels are at right angles(max traction) with the floor or not.of course they car will never go down and roll as much during driving ...so take out a LITTLE less negative camber.
i end up with about -0.5 to -1.5 degree most the time.
-3.5 is crazy
there is a really complicated and scientific way to calculate proper camber...which is relative to spring rate,spring travel ,roll,cornering speed and and corner radius..but i fall asleep half way reading thru all that
lee82gx is offline   Reply With Quote
Old 02-26-2003, 10:21 PM   #1624
popsracer's Avatar
Default Re: Re: pro3
-Dave
Dave;
Once I put the upper deck on, I had to go to lighter springs all around (with the FR 1-way).
Right now I have HPI #6846 Green Springs on the Front and #6844 Red in the Rear. I too have run the #6847 Blue Springs all around with good results. I think that I will be able to run the Blue/Blue this weekend now that the 1-way is removed.
ALL of my cars Nitro and Electric use Trinity 45wt oil F and 40wt oil R. I've always felt my Cars were "Twitchy" with heavier oils so that combination (45/40) has always felt good to me. I have a Friend that runs 80-100wt in all 4 shocks, but I haven't drivien any of his cars yet to see how they feel.
Thanks, Steven (popsracer)
Old 02-27-2003, 03:34 AM   #1625
sosidge's Avatar
That front end set-up is very similar to mine as well!
Old 02-27-2003, 01:05 PM   #1626
You'd think we were all running the same car or something.?!?!?!? ....
OH wait we are *DOH*
-Dave
Old 03-03-2003, 01:09 PM   #1627
Speed Demon's Avatar
here's my Hara edition Pro 3 with Suzuki Escudo body...
and yes... the addition front torque rod is similar to one that I saw here in rctech... notice the "o"ring under the steering linkage/ackerman.?? it reduce the steering slop..thus making it more precise....especially when adjusting front toe...
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 03-03-2003, 01:10 PM   #1628
this is the front torque rod...
Old 03-03-2003, 01:11 PM   #1629
and this is the HARA EDITION.... of mine...
Old 03-03-2003, 01:13 PM   #1630
oopss.... here is the pics..
Old 03-03-2003, 01:21 PM   #1631
popsracer's Avatar
Default pro3
JDM_DOHC_SiR;
Well I raced again this last Sunday. Did pretty well in Sportsman Stock. Qualified 6th overall (A main) out of about 40 entries and finished 6th in the Main. Mostly due to Driver error (corner dots). The Car felt very good except for the looseness, but that was a track issue that everyone had to deal with.
Old 03-03-2003, 01:57 PM   #1632
Default Re: pro3
JDM_DOHC_SiR;
Well I raced again this last Sunday. Did pretty well in Sportsman Stock. Qualified 6th overall (A main) out of about 40 entries and finished 6th in the Main. Mostly due to Driver error (corner dots). The felt very good except for the looseness, but that was a track issue that everyone had to deal with.
Great News Pop's Congrat's with the 6th in the A-main .. and glad to here about the Pro3 and that it's working like it's ment to
-Dave
Old 03-03-2003, 06:49 PM   #1633
popsracer's Avatar
Default JDM_DOHC_SiR;
This coming Saturday is another local race. I'll probably run the Car without any changes just to see how well I still like it as is.
You mentioned in an earlier post about 3 degrees Rear Toe-in. Where can I find the parts to do this. I think on a very slippery track, the infield grip might make the slight loss of top speed worth it.
Thanks for the congrats, Steven
Old 03-03-2003, 07:09 PM   #1634
lee82gx's Avatar
Speed...
are u dexter?
lee here..hehe.fixed up my new car dude.when r u up for a session?BTW great looking car man.aggresive is the word.
Old 03-03-2003, 07:18 PM   #1635
Default Re: JDM_DOHC_SiR;
Hi Steven
I'm using the Hot Bodies Most agressive Toe Blocks wich I think is 2 deg and I use the Square Hybrid rear Hubs that add 1 more deg.. so 3deg toe in total
hope this helps ya'
-Dave
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
