Old 02-16-2003, 06:47 PM   #1606
lee82gx's Avatar
thanks
nozauta619 and JDM_DOHC_SiR
will be getting a replacement soon..well if the shiny ones which are supposedly hard get bent with one crash i might as well purple for color eh?
lee82gx is offline   Reply With Quote
Old 02-16-2003, 09:26 PM   #1607
nozauta619's Avatar
no problem, good luck with the pro 3
anthony
Kyosho Blizzard EP / Tamiya DF-03RA / Tamiya TA-03F / Traxxas Monster Jams Maximum Destruction / HPI Pro 3
nozauta619 is offline   Reply With Quote
Old 02-19-2003, 06:05 AM   #1608
sosidge's Avatar
So I was thinking, shall I buy a new, stiff, car (XXX-S G+), or should I make my Pro 3 a bit stiffer? In the end I decided to save 250, and buy the graphite wishbones.
I'd say there's 1/2 the flex at the rear, and 1/3 the flex on the front - so now the springs move before the wishbones when you use stiff settings!
If anything, I found a little more understeer with the stiff wishbones than before, but the car didn't feel as vague as before with softer springs, and it's definitely a better platform to tune the car from.
Old 02-20-2003, 04:27 PM   #1609
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by lee82gx
thanks
Not a problem... The shiny's are much better for the front anyways
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-20-2003, 04:45 PM   #1610
rc-zombies's Avatar
did you get the graphite C-blocks as well? I have them on mine..it will help get rid of additional flex.
Old 02-21-2003, 03:57 AM   #1611
sosidge's Avatar
Not yet, no. I might add them to my shopping list for next time though.
Old 02-22-2003, 06:42 PM   #1612
Thumbs up Bump
Old 02-22-2003, 09:37 PM   #1613
popsracer's Avatar
Default Electric On-Road > pro3
Well I ran the car with the Graphite Arms, 3 deg Graph blocks and raised rear RC today.
Overall the car seemed much better. The track was VERY loose today so I had to remove the Front One-way for the first time ever to keep the rear from swinging out.
I won both of my heats, qualified 5th overall with guys that usually race in Expert Stock, but got hammered 3 seperate times on the first lap and that put me in last. I made up 2 places but that was the best I could do.
The Car did feel better though. See how I do next weekend.
popsracer is offline   Reply With Quote
Old 02-24-2003, 05:24 PM   #1614
Looks like you had a good outing Pops'
So what do you think make the Car handle better.?? the Graphite A-arms or the Higher Rear Roll center..
let us know if you you have any more good news!
-Dave
Old 02-24-2003, 07:10 PM   #1615
popsracer's Avatar
Default What do you think make the Car handle better
I actually think it was a combination of the two. For the first time I had to RE-install the Front diff over a One-Way. Before the Arms and RC change, the Front One-way was very drivable even in loose conditions. I could always use one where no one else could. As a matter of fact I NEEDED one just to get enough steering. With the recent changes, I had enough steering without the 1-way.
Thanks for all of the help.
Old 02-25-2003, 11:55 AM   #1616
Default Re: What do you think make the Car handle better
What are your rear toe in and Rear camber settings.?
-Dave
Old 02-25-2003, 08:40 PM   #1617
popsracer's Avatar
Default What are your rear toe in and Rear camber settings.?
JDM_DOHC_SiR;
standard 2 deg (total) rear toe and -1 deg Camber at all corners. If you know HPI cars as well as I think you do, then you know that they do not like alot of Camber. The Nitro cars are really bad about this. Turn in has always been fine so I always run -0- Front toe (instead of toe out)
See how it goes this weekend if it doesn't rain more.
*side note*
I did find out that my most recent and expensive battery pack doesn't have nowhere near the power and punch of my other packs. Have to use it for a practice pack now (like I need any more)
Thanks,
Old 02-26-2003, 02:28 PM   #1618
Default Re: What are your rear toe in and Rear camber settings.?
JDM_DOHC_SiR;
funny thing you talk about camber ... because When I started to use the High rear roll center in the rear...I used to have 1.5 deg - but now I'm using around .5~1deg- ..but my toe in is a little different though... it 3 deg total..
How's your front set up.??
Interesting.. find .. I thought I was the only one who thought that It was a little weird that I was running very minimal camber... vice what all of the people in Japan are running with the Hara. ....the most I have see is -3.5 deg camber front and rear !!
-Dave
Old 02-26-2003, 03:17 PM   #1619
rc-zombies's Avatar
Default HARA FINISHED 2ND WITH PRO3
Pro3 still on the podium.
Hara finished 2nd the the Thailand International Touring Car Championship lead by SURIKARN CHAIDEJSURIYA.
Just goes to show ya that the Pro3 is still very competative car.
Wonder why he did not run the Pro4?
Old 02-26-2003, 04:02 PM   #1620
Default Re: HARA FINISHED 2ND WITH PRO3
Glad to see that the Pro3 still has it
But I know why he didn't use it..
He clicked his heels one to many times
-Dave
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
