Old 02-07-2003, 12:44 PM   #1591
Thanks for all the replies Guys,
I'll try and pick up some RPM ball cups. I did that mod to an old TC3 and that did the trick, the AE ball cups never lasted long before they would get worn. I wonder if RPM do the ball cups in purple?
I received some extra shims with my V Spec Pro3. I wonder if the where for the CVD axles? I'll give them a try.
The O-ring is also a good idea. It is something that Shumacher employs on their kits and coming to think of it the kits I have had in the past were slop free.
I'll order the HPI woven graphite chassis. I have the HB upper deck but I was concerned that there was less room for electrics on the HPI chassis versus the HB.
I have put the Xray to bed for the time being. Back to the Pro3 for Sunday's meeting.
Yorkie
Yorkie is offline   Reply With Quote
Old 02-07-2003, 01:41 PM   #1592
sosidge's Avatar
Off to durham? or is it time for that big meeting up in scotland?
Old 02-07-2003, 02:34 PM   #1593
newracer's Avatar
R/C Tech Charter Subscriber
you can get white RPM ballcups and dye them purple, I have done it, works great
newracer is offline   Reply With Quote
Old 02-09-2003, 12:32 PM   #1594
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Wink Bump
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-13-2003, 11:24 AM   #1595
rayhuang's Avatar
HPI Challenge!!
HPI GUys,
I just purchased a MINT bone stock Pro3 to do the HPI Challenge race in Michigan this summer!! I am thinking of doing Electric Sport to keep my costs way down.
Four Questions please!!:
1. Am I allowed to run a one-way in Electric Sport?
2. What are the popular HPI bodies for Large-treated Asphalt roadcourse?
3. What shock pistons and what weight oil is s great starting point? Also-what brand of oil? I have all of the AE and Trinity oils.
4. What rollout or gear ratio do you recommend for Monster Stock motor-rubber tires?
Thanks guys,
Ray
Old 02-13-2003, 11:30 AM   #1596
rc-zombies's Avatar
Default Re: HPI Challenge!!
Originally posted by rayhuang
HPI GUys,
I just purchased a MINT bone stock Pro3 to do the HPI Challenge race in Michigna thi summer!! I am thinking of doing Electric Spor to keep my costs way down.
3. What shock pistons and what weight oil is s great starting point? Also-what brnd oil? I have all of the AE and Trinity oils?
Thanks guys,
Ray
1. NO...I think car has to be run box-stock as is.
2. Stratus the Ford Mondeo or Alfa works well.
3. #3 piston with 35wt - 40wt oil all around.
4. I run a P2K2 at around 6.00+/- final drive
Old 02-13-2003, 11:32 AM   #1597
rayhuang's Avatar
aaahhhh-my old friend the Zombie to the rescue!! I got this mint car for $75.00!!! Wow!!!
Thanks for the tip. SOunds like a breeze to set-up then!!!
Old 02-13-2003, 11:34 AM   #1598
rc-zombies's Avatar
'coz of the soft chassis the car is easy to set-up
here's are the rules:
CAR
- Standard RS4 Sport, RS4 Sport 2, RS4 Pro 2, RS4 Pro 3, Sprint and RS4 Rally cars only
- Max Width = 200mm
- Ball bearings are allowed as direct replacement for standard bushings on the RS4 Sport only
- Saddle pack battery conversion is allowed (plastic battery cradle (#A372) and hook-and-loop straps (#6152)) for RS4 Sport 2, Sprint, or RS4 Pro chassis (#A560) for RS4 Sport or RS4 Rally)
- No other modifications or structural changes - kit springs must be used (yellow Sprint springs for Sprint, silver for all other cars)
BODYSHELLS
- Any 190mm or 200mm HPI bodyshells (including the HPI Rally bodyshells)
- See the Bodies rule section, above for complete regulations on the bodies
TIRES
- 1/10 scale touring car HPI tires must be used
- 1/10 scale touring car HPI wheels must be used
MOTORS
- An unaltered ROAR-legal 24 degree 27-turn, single wind REBUILDABLE motor must be used, because this allows easier inspection and teardown
Good luck at the race!
Old 02-13-2003, 11:41 AM   #1599
rayhuang's Avatar
Thank you for the fast reply!! Race is far, far away-but I have learned when racing on a tight budget-buy everything early and slowly!!! And just to prove what a dork I am-I'll start a manila folder with set-up info-rules, etc. today!!! hahaha!!! Or else my leaky brain cells will forget all this great info!!
Thought of another question. n e the rims-do I buy 0-offset? Also-do you recommend 24 or 26mm rims?
Thanks again,
Ray
Old 02-13-2003, 11:58 AM   #1600
rc-zombies's Avatar
0 offset for 190mm bodies
3mm offset for 200mm bodies.
stay with the standard 24mm tires and wheels.
HPI 33R w/green inserts work very well on asphalt parking lot tracks. if its cold in the am..probably 27R with red or greens.
Old 02-15-2003, 05:18 AM   #1601
lee82gx's Avatar
Default bent CVD's
guys i just found out i have a slightly bent MIP-shiny CVD(the shiny part).runs fine i THINK but im not too sure.
is there any problems?it's more than really expensive to replace it.
i tried to bend it back..but it's hard as HELL.
any ideas?
thanks.
lee82gx is offline   Reply With Quote
Old 02-15-2003, 08:56 AM   #1602
Default Re: bent CVD's
any ideas?
thanks.
If you bend the Shiny CVD's straing you'll stand a chance of breaking them or making them weak in that area.. .. But if you have to try to use a vice to bend it back....
BTW are these for a Pro3..??
-Dave
Old 02-15-2003, 10:25 PM   #1603
lee82gx's Avatar
Default Re: Re: bent CVD's
-Dave
yes they are for the Pro3.japanese catalogue as option part and American as standard(spec R)
harder than the purple aluminium ones..but i managed to bend it b4 my purples bend..
are they ok to be run as slightly bent?
Old 02-15-2003, 11:42 PM   #1604
nozauta619's Avatar
Exclamation re: bent cvd's
a bent cvd will incure some power loss with each rotation, i think it can cause some wobble & suspension play. its a good idea to replace that cvd
thats what i think
Kyosho Blizzard EP / Tamiya DF-03RA / Tamiya TA-03F / Traxxas Monster Jams Maximum Destruction / HPI Pro 3
nozauta619 is offline   Reply With Quote
Old 02-16-2003, 08:00 AM   #1605
Default Re: re: bent cvd's
thats what i think
Better safe than sorry... Replace it ....
BTW every time I screwed up a CVD it took the Outdive out also .... 1 hit = bent CVD and 1 toasted outdrive
-Dave
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
