Old 01-16-2003, 12:31 AM   #1486
lee82gx's Avatar
Default Re: ??? Just a piece of C/F?
Originally posted by JDM_DOHC_SiR
What do you mean..??? where there any holes drilled??
-Dave
yes there where holes but no screws or spacers.which hole should i mount on?i heard that u shouldnt mount on steering posts....and do u remove the front bulkhead -rear?
lee82gx is offline   Reply With Quote
Old 01-16-2003, 07:13 AM   #1487
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: solid hpi pro 3 arms...?
Originally posted by nozauta619
hey JDM-DOCH-SiR,
what type of suspension arms are you running with on your hpi pro3? is it delrin plastic or composite graphite? looks really cool & durable i want one too!!!
The A-arms are made by Square and the they are really durable and arm made of durable Nylon I have had the HPI composite graphite one and I have kept breaking then right where the hinge pin goes throught the A-arm So I switched to the Square Arms and Have had no problems since
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 01-16-2003, 07:22 AM   #1488
Default Re: Re: ??? Just a piece of C/F?
I Used a 2mm spacers in the rear and the the stock hollow tubing that came with the Hara kit.... but I didn't mount the torque rods to the steering posts..
It might look like that in the pic but it's not that way..
also you will need 2 10mm bolts and 2 20mm bolts for up front
-Dave
Old 01-16-2003, 08:29 AM   #1489
lee82gx's Avatar
thanks
JDM_DOHC_SiR
exactly what ive been looking for.
Old 01-16-2003, 03:56 PM   #1490
rc- do you or anyone else have a high bite asphult setup? for stock.
teamAE is offline   Reply With Quote
Old 01-16-2003, 07:09 PM   #1491
popsracer's Avatar
I could give you mine if you are interested (have to go look). If something better is posted, I would like to try it. I'll go look now.
popsracer is offline   Reply With Quote
Old 01-16-2003, 07:46 PM   #1492
Talking No problems
thanks
JDM_DOHC_SiR
No problem
-Dave
Old 01-16-2003, 07:58 PM   #1493
racer's Avatar
Default camber links
on, the Pro 3
by mounting the front camber link on the outer lower hole of the shock tower. do you get more or less steering???
Thanks!
Old 01-16-2003, 10:06 PM   #1494
popsracer's Avatar
Default Asphalt/Rubber set-up
Front;
Shocks #6847 Green springs, 45wt oil, mounting A-2. Take-off 27CS premounted tires/wheels, 6 deg caster, 0 deg kick-up, -1 deg camber in position B-3. Zero front toe, Front one-way Diff, Front (black) swaybar. Ride height 4.5mm.
Rear;
Shocks #6844 Red springs, 40wt oil, mounting A-2. Take-off 27CS tires/wheels, -1 deg camber in position B-3, 2 deg toe-in (2-2-9)
Ride height 5.0mm
Chassis;
Stock HPI USA plastic chassis, HPI Graphite upper deck, HPI Graphite shock towers F & R. Monster Stock motor geared 116/33
Side note:
I had to go 2 steps softer overall with the springs after installing the Upper Deck.
For NEXT weekends race I will be changing to 3 deg caster blocks with 2 deg of kick-up. Hopefully to gain a little more on power steering.
Old 01-16-2003, 11:00 PM   #1495
thanks pops I will give it a try tomorow.
Old 01-16-2003, 11:06 PM   #1496
nozauta619's Avatar
Thumbs up thanks...
thanks JDM-DOHC-SiR,
do you know places (probably online) to purchase those arms?
Kyosho Blizzard EP / Tamiya DF-03RA / Tamiya TA-03F / Traxxas Monster Jams Maximum Destruction / HPI Pro 3
nozauta619 is offline   Reply With Quote
Old 01-17-2003, 04:48 AM   #1497
sosidge's Avatar
Default Re: camber links
I haven't done that exact change, but whenever I raise the front roll centre (which is what that mod does) I find it reduces total steering, and seems to dull the steering response. It does "smooth" the front end out a bit though.
Old 01-17-2003, 06:46 PM   #1498
Default Re: thanks...
You have a PM nozauto619
-Dave
Old 01-21-2003, 05:25 AM   #1499
sosidge's Avatar
ttt
Old 01-21-2003, 05:01 PM   #1500
Talking One more Bump
HPI Pro3 Drift Demon R/C Items: Wanted to Buy 1 06-26-2007 11:04 PM
HPI Pro3 Drift Demon Australia Wanted to Buy 0 06-21-2007 04:06 PM
pro3 for .12 better than you R/C Items: For Sale/Trade 4 04-25-2005 02:35 PM
HPI RS4 Pro3 Denso R/C Items: For Sale/Trade 5 01-26-2005 12:37 PM
FS: HPI Pro3 SteveM R/C Items: For Sale/Trade 7 12-04-2001 06:03 PM
