Old 07-02-2003, 06:25 AM   #1
Lonestar's Avatar
Arrow T30: " Volts Too High!"
Howdy folks,
can somebody please tell me what's going on with my T30 when I'm cycling 3000HV's? It charges just fine (1 peak 5A db 0.04V) and then it refuses to start discharging by himself... it only discharges if I start the discharge by hand (I loose the peak voltage and IR info though), which is kind of contrary to the purpose of having an "automatic" cycling feature...
Could it be that my HV's have soooo much voltage at the end of the charge? That's what I started suspecting... I changed my settings to 2 peaks, 0.02 and 0.01, with a 200s delay between both, a mean to let the voltage settle down a bit before discharging, ssince you can't set up the time between the last peak and discharge on the T30... and then it cycles properly. But I still find this solution unsatisfying.
It cycles my GP3300 and 3000UMH just fine... it's just an issue when cycling the HV's.
Anybody ever had that problem?
Thanks fot your feedback,
Later
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 07-02-2003, 07:07 AM   #2
dtm
dtm's Avatar
Send a message via ICQ to dtm
You are correct! the voltage of the pack at the start of discharge is too high. Can't remember what that level is...but that is where your error is coming from. CE changed the software during the T35BL to account for this. The first batch of T35 had the same problem too.
dtm is offline   Reply With Quote
Old 07-02-2003, 07:46 AM   #3
Lonestar's Avatar
Thumbs up Thanks
thank you for your answer... Now I know :-)
Thx!
Paul
Old 07-02-2003, 08:09 AM   #4
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I think if you change the number of cells in the system from 6 to 7 it should be ok. At least it will provide a work around.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 1 03-13-2007 07:20 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
STUFF FOR SALE """"LQQK """" EZRC R/C Items: For Sale/Trade 11 10-22-2006 09:49 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
How can I tell if Im racing on a "high-bite" track? MikeDeadly Electric On-Road 3 02-21-2005 12:15 AM
