Old 02-19-2008, 09:53 AM   #1
Default Gearing / Rollout?
Could anybody tell me what the correct gearing/rollout would be for a sedan with 27Turn motor with Foam tires on Carpet track? Were all Rubber tires here in NORCAL, want to give foam a try....Thanks....
TheOtherNut is offline   Reply With Quote
Old 02-19-2008, 10:51 AM   #2
Regional Moderator
CarbonJoe's Avatar
Which 27 turn motor?
For a CO27, try 1.08 (inches). For a Monster Stock, try 1.00. For an Orion Core, try 1.13. Those were popular rollouts at the Halloween Classic and the Cleveland Indoor Champs.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-19-2008, 11:26 AM   #3
Thanks Carbon Joe, Could U please exsplain to how figure out the rollout? Is it spur x pinion divided by internal ratio X tire size divided by PIE (3.14) ? I'm lost, any help would be great....Thanks
Old 02-19-2008, 11:30 AM   #4
Regional Moderator
CarbonJoe's Avatar
Download the XRAY Setup book here: (it is a PDF file zipped up) http://www.teamxray.com/teamxray/sho...p?file_id=2525
Check out the info starting at page 40. All your questions about rollout will be answered. Of course, substitute your actual internal drive ratio for the XRAY 1.7 ratio (34 and 20 tooth pulleys).
HTH!
Rollout / Gearing? Drifter73 Electric On-Road 9 03-06-2009 06:00 AM
GEARING/ROLLOUT QUESTION oldfart Electric On-Road 7 06-25-2007 11:42 AM
rollout and gearing RocketRacer Electric On-Road 7 06-20-2006 08:06 PM
1:12 Scale Brushless Gearing or Rollout? Decathalon Electric On-Road 6 05-29-2006 04:48 AM
Rollout Figures For Gearing Calculations Steevo Electric On-Road 16 10-08-2002 05:05 AM
