Old 02-18-2008, 10:54 PM   #1
Default tc4 steel outdrive question???
I just ordered a set of them for the front diff on my TC4. When I hit the wall sometimes lightly the CVD pops out and chews the right side outdrive up. The car is tough but lately I've been going threw the composite outdrives like crazy and I'm not even hitting the wall that hard. My question is will I need any thing else to complete the diff, or will i be able to build the diff with just replacing the composite outdrives with the steel ones. thanks to anyone that can help. Gotta love this site.
budget man is offline   Reply With Quote
Old 02-19-2008, 01:34 AM   #2
DaveW's Avatar
The steel diffs are built differently. The spring and a white T-nut (one you have to get that is just like the T-nut in every other offroad AE diff) goes in the long steel outdrive. The thrust assembly and the bolt go in the short steel outdrive.
You need:
AE white T-nut
Round diff rings (same size as the D shaped rings... but NOT D-shaped)
Steel outdrives
The rest of your composite diff assembly
After your steel diff is built you will have these parts left unused:
Small aluminum nut that fits in the short composite outdrive
Two D-shaped diff rings
Short and long composite outdrives
If i remember correctly. If you cant find the rings specifically for the TC3 steel outdrives... the older 10L3/12L3 onroad and oval cars used the same rings. If this is wrong anyone please chime in! Its been awhile since i have cross referenced all of AE's parts.
DaveW is offline   Reply With Quote
Old 02-19-2008, 05:51 PM   #3
Grease's Avatar
I just went through this myself. This is the kit you will need
http://www3.towerhobbies.com/cgi-bin...?&I=LXPA07&P=7
and as Dave said, there is a slightly different assembly order. The spring goes on the other side, underneath the white nut. I didn't know this at the time when I assembled them and although it still worked, it destroyed the nut.
Serpent S811e 2.0
Serpent S411 ERYX 3.0
www.norcarracing.com - www.franchiseracingproducts.com
Grease is offline   Reply With Quote
WTB XX4 outdrive savers Autocrosser R/C Items: Wanted to Buy 3 03-27-2008 10:33 PM
WTB: Barra one-way outdrive Dorigecko Australia Wanted to Buy 0 01-03-2008 11:35 PM
Xray multi diff spring steel outdrive bigdog xxx-s R/C Items: Wanted to Buy 2 10-17-2007 01:58 PM
Spring Steel T Plate/Shock spring Question jnor Oval, Larger Scales and More 3 04-15-2007 03:12 AM
TC3 Steel Outdrive Trouble Paul_TC4 Electric On-Road 14 11-03-2004 02:22 PM
