Old 02-17-2008, 08:08 PM   #16
We need more info dude.. Could you at least list your setup.. You can go softer springs in the rear, add another .5degree of negative camber, change to a staggered tire setup ie cs27 in the front and 22's in teh back.. Tons of stuff. It all depends on what you are doing already...
Slowing down before corner entry will also prevent the car from over rotating..
How do you want the car to feel? You can up the rear traction way up and just set the car up to push.. All depends on what you want...
fishnfst is offline   Reply With Quote
Old 02-17-2008, 08:14 PM   #17
Drifting101's Avatar
ALLWAYS run the same tires on the front and the back but treat them differentley if you need
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 02-17-2008, 08:40 PM   #18
Francis M.'s Avatar
double post
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-17-2008, 08:46 PM   #19
Francis M.'s Avatar
triple post
Old 02-17-2008, 08:48 PM   #20
Francis M.'s Avatar
Originally Posted by [email protected] View Post
Was using soft springs at the rear, camber 1.5 rear, 1.5 front. Rear 3 toe-in.
your suspension might be to soft in the rear already.
What car are you driving and what brand springs are you running.
For asphalt 17.0lb front springs and 14.0lb rear springs are good starting point with 30 to 35 wt shock oil all around. droop is usually at 3-4 mm up travel all around maybe limit the front a little more.
You really shouldn't have a big difference in spring rate from front to rear on asphalt..... Making the front too stiff and the rear too soft might actually be the cause of your spining out probems coming in to corners....
Old 02-17-2008, 09:09 PM   #21
Check your car out on a tweak station. Almost every time my car spins out its due to this problem.
wcalaker is offline   Reply With Quote
Old 02-17-2008, 10:53 PM   #22
How about buying a good setup book.
_pilot_ is offline   Reply With Quote
Old 02-18-2008, 12:20 AM   #23
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
also make sure the rear diff isnt too tight.
Syber Serulean is offline   Reply With Quote
Old 02-18-2008, 03:22 AM   #24
CLK@racing's Avatar
Originally Posted by xraysteve View Post
i would try less rear droop. not less the 1 1/2 mill. then i would try to experiment with a rear sway bar. they some times add traction and sometimes takes it away. you should also try and make your rear camber link longer and or level. lay the shocks down in the rear. try and if something dos not feel good put it back and try something else always one at a time. all else fails put some anti dive in. that is when the front henge block is lower then the rear front henge block. but if your car steers the way you like it then you will have to change your caster block. go to 6 degrees. if all that dos not work let me know. good luck.
When you say less rear droop, means less downtravel for the damper right?
Reading on the droop gauge should be of bigger number? Or vice versa?
And thank you for all the feedbacks and inputs you guys gave!
By the way, xraysteve, nice avatar!
Real man races Modified.. simple.
CLK@racing is offline   Reply With Quote
Old 02-18-2008, 04:31 AM   #25
LOSI123's Avatar
Trader Rating: 63 (100%+)
1 make sure you dont have any front tow out ( try straight ahead)
2 also run a front spool , dont run a one way.
3 and run the front and back ride height the same .
4 slightly thicker oil in the front shocks too.
5 run a sway bar on the front end, or a thicker one.
6 run less drag brake (if you can)
7 or turn down the brake on the transmitter (if you can)
8 make sure the rear wing is not cut down to small
There is tons of stuff you can do....
LOSI123 is offline   Reply With Quote
Old 02-18-2008, 06:10 AM   #26
razzor's Avatar
For quick problem solving or a point of reference i downloaded the attached Serpent reference chart which puts your tuning options in order of importance.
It might be for gas cars but it applies to electric aswell.
Print it and have it laminated for your pit bag.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-18-2008, 07:18 AM   #27
beta bob's Avatar
Trader Rating: 2 (75%+)
Ilearned froma pro at my track that if the rear slide out to just raise the ride hieght in the rear or lower it in the front. But thats if the rear end slides out at the middle or the end of the turn.
Team Terribles---------2009 post of the year
"Cant you read Mopar???He said that he drives a T-max 2.5!!!!"
Spec classes are for communist
beta bob is offline   Reply With Quote
Old 02-18-2008, 08:25 AM   #28
first rebuild rear diff!
alex-fr is offline   Reply With Quote
Old 02-18-2008, 09:04 AM   #29
JimmyMac's Avatar
Camber gain.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 02-18-2008, 10:18 AM   #30
rough512's Avatar
Default Some things to check first?
Yes, check if your rear diff is "diffing" smoothly
also, remove the rear shocks and check that the rear arms are moving smoothly. Check for tight or bent hingepins.
check drag brake settings (if any)
Check that the shocks are smooth and not bottoming out. Rebuild if necessary.
we are assuming of course that there's nothing wrong with the drivetrain? no seized bearings and pinion/spur gears are meshed correctly
If the above list checks out fine, then you may begin looking at the setup
rough512 is offline   Reply With Quote
How do you find the car's center of gravity in the Z axis? haulin79 Electric Off-Road 11 08-08-2008 05:15 PM
The Thread That Slides! ManiTech Singapore R/C Racers 62 07-10-2008 07:14 AM
Aluminum Anodizing for RC/Car's where? mike ivy R/C Items: Wanted to Buy 3 04-19-2006 12:13 AM
Racing... from a car's perspective :) Bob Nilsen Electric On-Road 15 04-09-2006 08:00 PM
RACE CAR's TRADE FOR HELI OR FOR SALE 2PAC R/C Items: For Sale/Trade 0 07-30-2004 11:42 AM
