12 scale brushless gearing? >
Old 02-16-2008, 04:43 PM
Default 12 scale brushless gearing?
What gearing is a good starting point for a 10.5 brushless CRC Gen-x? We are turning about 9 to10 second laps with 13.5 brushless. Our track is about 80 by 42 feet.
Thank you
Dave
Horth Racing is offline
Old 02-16-2008, 08:50 PM
AdrianM's Avatar
Thank you
Dave
Start out at a 56mm roll out. I think I ended up closer to 60mm at my 100x48 carpet track.
AdrianM is offline
Old 02-18-2008, 05:16 AM
wallyedmonds's Avatar
start at 47mm roll and go up from there
at fastcats where i run im running 49.5 about.
when i go up to 53 the car runs but is doggy in the corners
just play till you fined what works good,good high speed with good infield
wallyedmonds is offline
Old 02-18-2008, 07:39 AM
Your gearing will depend some on what speedo you're running and how your motor/car work on the track. I normally start a little low and go up from there until the laptimes fall off or the motor gets too hot.
56mm is probably where I would start with a Novak speedo. Just go up and down from there to find what's fastest.
Unregistered is offline
Old 02-18-2008, 11:05 AM
Thank you gentlemen! I will be doing a little R & D next week.
