Old 02-16-2008, 10:55 AM   #1
bboy's Avatar
Unhappy LRP Brushless 4.5 Problem
I just put in my LRP Brushless 4.5 with Sphere ESC. After running 5 min on my IB4600 (6 cells), I notice that the motor does not run every now and then and appears to be in a freeze position even when I pull the trigger. The motor seems kind of stuck with no response.
However if I move the spur or the car a bit, the motor run again.
Is there something that I am doing wrong? I didn't have this problem with the 3.5 motor with same ESC.
Help...
Serpent 960-08 + Max XL9
XRay NT1 + Max XXL3
bboy is offline   Reply With Quote
Old 02-16-2008, 11:17 AM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Help...
do you have it set for NiMH or lipo battery??
Old 02-16-2008, 11:20 AM   #3
bboy's Avatar
I have it set for NIMH. I have been running the 3.5 motor with no problems. I just changed to 4.5 motor with same ESC setup and batteries etc, and I got this problem.
Could this be a faulty motor?
XRay NT1 + Max XXL3
Old 02-16-2008, 11:23 AM   #4
Super Moderator
Marcos.J's Avatar
what rotor does it have?? maybe try the rotor from the 3.5. if not just send it back to lrp
Old 02-16-2008, 11:29 AM   #5
GreaseMonkey's Avatar
Why would he send an LRP motor to Novak?
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 02-16-2008, 11:30 AM   #6
Super Moderator
Marcos.J's Avatar
my bad typo its fix, well since is a lrp motor i would throw it in the garbage thats what i did with my lrp 4.5 and 13.5 reason for that was i had both rotors shattered inside the motors!! with barely any runs on them.
Old 02-16-2008, 11:44 AM   #7
razzor's Avatar
Ive heard of this and some have said that sometimes the oil/grease from the bearing goes on the sensor pickup so it cant read the starting point.Give it a clean with a electric cleaner or CO2.
Also heard that some motors have a bad solder joint on the back board so that might be a option too.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 02-16-2008, 11:50 AM   #8
bboy's Avatar
You mean the brushless rotors are interchangeable? I thought each turn has a specific rotor....
XRay NT1 + Max XXL3
Old 02-16-2008, 11:51 AM   #9
bboy's Avatar
Cool, let me try that... fingers crossed.
XRay NT1 + Max XXL3
Old 02-16-2008, 11:54 AM   #10
Super Moderator
Marcos.J's Avatar
yes they are interchangeable
Old 02-16-2008, 07:37 PM   #11
adamge's Avatar
Try a different sensor wire. Beyond that, if it doesn't work and the 3.5 still works, send the motor back.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 02-17-2008, 04:42 AM   #12
On the subject of lrp motors and rotors does anyone know all of the rotors that fit the lrp motors? I have 2 x-11's which both have the 14mm rotors but they don't seem to go as hard as the latest orion motors which have the 12mm rotors. Does anyone know what options are avalible?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Brushless Problem d4man Electric Off-Road 2 03-17-2008 01:02 PM
Problem w/ brushless help? Kyle_Rcn3rd Electric Off-Road 3 01-31-2008 06:49 PM
micro t brushless problem jbligh Micro and Mini Scales 3 12-31-2007 05:28 PM
Novak Brushless problem shooter26 Electric On-Road 8 09-24-2007 03:27 PM
Brushless problem any help welcome.... aussie racer Electric On-Road 3 07-16-2007 03:21 AM
