GT10 Class
Old 12-16-2008, 11:49 AM
  #841
KMW
KMW's Avatar
Originally Posted by tallyrc View Post
anybody know what is happening with the jaco spec tires? they are out of stock everywhere and not listed some places that they used to be... heck i can't even find them on jaco's site... they were a few dollars cheaper and i liked the rims... anywho.. car is almost done.. widened 10l3t...
A Main Hobbies has them in stock:
http://www.amainhobbies.com/index.php/cPath/1_83_85
KMW is offline
Old 12-22-2008, 09:20 PM
  #842
tallyrc's Avatar
Originally Posted by Hyper_Mike View Post
Tallyrc,
I too am trying to widen a 10L3T for the World GT class and I'd love to hear how you've gone about doing it (I'm really new to pan cars ). Any chance you could either post or PM me what you've done to get it to 200mm?
Thanks in advance.
Cheers,
Mike
lemme measure my hub, but it's a wider right hub (i think just 1/8 wider which is 5mm or so, and shimmed the right 1/8).. the front will just be shimmed also.. the car is a genuine mutt of parts i had in the box, but real pretty with all the different colors...
tallyrc is offline
Old 12-22-2008, 09:28 PM
  #843
SWTour's Avatar
if you use the 1/8" front axles like most of the oval guys use...they are long and have shims so you can widen the front out, or narrow it up by using the shims on the inside or outside of the wheels.
1/8" rear axle spacers on each side of the axle will get you the width you need in most cases...
SWTour is offline
Old 12-25-2008, 10:12 PM
  #844
trackdesigner71's Avatar
I have a body ?
I was at my LHS on CHristmas eve looking for a COrvette C6 for my Pantoura and I didnt find the new Protofrom C6 but I did find the HOI C6...what kind of difference is there between the two and which one would you guys advise would be the better investment for my car? (whichever one I get Im gonna do a FIA GT Phoenix Carsport paint scheme on it)
trackdesigner71 is online now
Old 12-25-2008, 10:30 PM
  #845
tallyrc's Avatar
i'm not positive, but i believe that the new c6 was "optimized" for pan cars meaning it probably has a bit more splitter, wheel arch clearance, and maybe a better or bigger rear wing.. wheelbase may be slightly different also..
tallyrc is offline
Old 12-26-2008, 09:33 AM
  #846
Grenade10's Avatar
Trader Rating: 40 (100%+)
I ran one before the New C6 came out. Bigest issue was tire clearance as the fenders are more rounded. Then Tally is correct in the "lack of splitter" Wheel base did work on both long and short with the I-Fource. Also since the front width is adjuastable, not on issue either.
Grenade10 is offline
  #847
Regardless, you have to cut away so much of the bottom edges of the body to get to the legal roof height of 104mm that you totally elminate the spliter.
Get the Protoform Sophia.
Crashby is offline
Old 12-26-2008, 09:44 AM
  #848
Grenade10's Avatar
What He Said!!!
Old 12-26-2008, 10:12 AM
  #849
tallyrc's Avatar
agreed..
tallyrc is offline
Old 01-01-2009, 03:01 PM
  #850
Ok. Are there any good Alfa Romeo Racing paint schemes I can consider?
Old 01-01-2009, 04:07 PM
  #851
AdrianM's Avatar
Do a Google search for "Alfa Romeo Lancia Rally" and click on images. There are two classic paint schemes there. The white/blue/light blue/red of Martini Racing and the green/white/red of Alitalia.
The Martini scheme is the most famous.
AdrianM is offline
Old 01-01-2009, 05:43 PM
  #852
Man those are AWESOME! I may see about getting that Lancia on a Sophia (itd go great with my Phoenix Carsport Corvette)
Old 01-01-2009, 09:25 PM
  #853
Rob Burns's Avatar
Alfas should always be red.
Something like this:
http://lh3.ggpht.com/_rwaQxNvnz50/SJ...meo+155+TS.JPG
On another note. Does anyone know if the JACO or CRC spec tyres are pre-trued? If so, to what size are they trued?
Rob Burns is offline
Old 01-01-2009, 10:52 PM
  #854
AdrianM's Avatar
They are pre-trued to a too large size. For asphalt we true Jaco's to 2.2" and BSR/CRC tires to 2.3". For carpet go .1" smaller. Unlike 1/12th we tend to run the fronts and rears the same size.
AdrianM is offline
Old 01-02-2009, 07:22 PM
  #855
revo523's Avatar
Can you run lipo in this class?
revo523 is offline
