Old 05-15-2008, 08:00 AM   #436
Re: Active Hobby Toyota GT1 body
I don't think anybody in the U.S. stocks this body. RCMart says they have it here:
http://www.rcmart.com/catalog/defaul...10%20-%20200mm
cdtanner is offline   Reply With Quote
Old 05-15-2008, 08:43 AM   #437
t4mania's Avatar
Jason, I appreciate your honesty about the car and after seeing all the support you give on various forums its what I expect from you and I see it in every post you make. I guess what I'm asking is will the car handle better with the 4 cell vs. the lipo tray with lipo battery.
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 05-15-2008, 08:58 AM   #438
protc3's Avatar
Thanks man,i really appreciate it.
The cars will handle very close to equal with a weighted lipo tray. The lipo car will be a little more of a handful given the higher voltage but they should handle similar. This is based on using a 13.5 as a mod motor. The 10.5 and lower wind motors with 7.4 volts is not efficient. I know people run them but they are extremely hard to go fast with when you are always competing with wheelspin and spinouts. Unless the track is so large and such high traction that anything less looks slow, you wont find yourself running lower than a 13.5 with lipo.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 05-15-2008, 09:27 AM   #439
Mason's Avatar
i've not claimed to try to compare 4cell and lipo using the same motor. we all know the numbers don't add up. I would run a 17.5 or 21.5. if it works on the oval then i'm sure it can't be all that bad.
gotta dust off my pan cars!
anyways back on topic. Its really good to see the interest people have shown so far.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-15-2008, 09:41 AM   #440
protc3's Avatar
The comparison between lipo and 4 cell will arise when they are run together. Low wind motors and 4 cell will beat up on 17.5 or 13.5 lipo car. I definately want to see lipo work well because i think it will help the class. It is tough though being that TC and offroad already run 6 cell so the cars dont suffer as much being they are designed to run with that kind of voltage. The transition for them was much easier. Pan cars havent been designed to run 6 cell with todays motors. They already dont have enough weight behind them to plant the car. If people are willing to buy Pan car specific motors then running a 17.5 or 21.5 will work great. We will still need to weight them to a similar weight of 4 cell for them to work good.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-15-2008, 09:55 AM   #441
crunchracer's Avatar
I started testing my modified Pantoura chassis, BMI 12R rear pod and Dampener Tubes, running a 3250 Core Lipo mounted on a Lipo weight plate, Novak GTB 13.5, 17.5, 21.5 combo, BSR Pro Purple front, Pink DBL Pink Rear, Jacked 1/2 front, Full Rear, HPI Porsche Body. At Seattle Indoor Raceway Carpet Med-High traction.
Basing the handling of the car to the Stock CRC Pantoura that we ran for 24hours world record with a mild Hacker mod motor. Fast lap of 8.2 sec.
13.5 is fast, real fast, 9.5 sec laps, during free run on the track is comfortable and just plane FUN, introduce other cars of diff speeds, Mass brake, and counter steering input and 100% attention, passing was difficult (tight track layout) 10 min run.
17.5 was only 2 to 4 tenths slower, during free run, but 5 tenths faster with traffic, absolutely a BLAST to drive, and drive fast. 15 min run.
21.5, was smooth, but just not enough kick, ran about 5 to 8 tenths slower than 17.5 free run, but this time did not gain any during traffic, with out the bottom end of the 17.5 overtaking other cars was much harder. 15 min run
www.FusionMotorsports.com
Team S.I.R
John's BSR Racing Tires
crunchracer is offline   Reply With Quote
Old 05-15-2008, 09:57 AM   #442
Mason's Avatar
those motors are already standards by roar and/or the oval crowd. *shrug*
Mason McCombs
Old 05-15-2008, 10:08 AM   #443
Mason's Avatar
Originally Posted by tallyrc View Post
at some point don't we just start re-springing cars with much softer springs?
jaybro's right. it can only go so soft. "standard" .16 and .18 springs just don't hold up under dynamic weight let alone static. you could design a cantilever type of suspension you find on most open wheel cars but that ends up being more weight and more things to fix. i thought jaybro had those new springs. maybe he can make a trial set in 16 or 18s *shrug*. your other choice is tire compound and that only goes so far as well.
Basically it comes down to literacy to read the speed control and radio manuals.
Mason McCombs
Old 05-15-2008, 01:59 PM   #444
protc3's Avatar
I am thinking of the majority of TC guys and 1/12th guys who will be running them. I know some guys have a 17.5 from that being the new stocker but 21.5, thats gotta be painfull to watch in TC. Im sure a few of the oval guys will have them but most TC and 1/12th guys wont. I think a 21.5/lipo,17.5/lipo will both be killer classes. 13.5/lipo is getting to the point where we will start feeling handling losses.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-15-2008, 02:05 PM   #445
protc3's Avatar
The springs we make and that come with our car are linear springs. They are softer throughout compression than an AE spring and are a tick softer off center due to the larger diameter. The great thing about them is they do not collapse. I preset each spring to there finish length. I feel if we go too soft, there will not be enough force driving the tires to the surface. We will get everything figured out in time. We will just need to figure out what the standards are going to be as far as voltage and motors.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-19-2008, 07:41 AM   #446
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Im definitely liking how things are looking for this class...we have a it on one of the largest stages in RC right now (IIC) as an official class, we have a number of guys who have been testing and have been running these cars at their tracks, and people are taking notice (and so are companies as you can see). This is going to be a fun summer
trackdesigner71 is offline   Reply With Quote
Old 05-19-2008, 05:33 PM   #447
LOW ET's Avatar
Trader Rating: 97 (100%+)
well since i'm running a lipo pack i'll need to add 80g of weight to equal a 4 cell pack or i'll have to add 240g of weight to equal a 6 cell pack. which of the weights would you add for a brushless 10.5t car?
LOW ET is offline   Reply With Quote
Old 05-19-2008, 06:47 PM   #448
protc3's Avatar
It really depends on the car. The layouts that work best seem to be 4 cell layouts. I would weight it to the weight of a 4 cell.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 05-19-2008, 08:31 PM   #449
tallyrc's Avatar
just for reference i run a wide car with an orion 3200 lipo and added a little over 5 ounces (all in equal placement to where a 6 cell pack would be).. almost enough
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 05-19-2008, 09:31 PM   #450
Grenade10's Avatar
Trader Rating: 37 (100%+)
Matches what I had to add to my I-Fource!!!
Car is still not as planted as the C10X, but it is making progress on the carpet. More testing this week!
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
GT10 Class bodies Keyz Oval, Larger Scales and More 11 10-09-2008 04:57 PM
GT10 Class Discussion trackdesigner71 Electric On-Road 5 02-18-2008 06:02 AM
HB gt10 mt joe of loath Monster Trucks 0 07-10-2007 05:01 AM
TC3 - Trade For GT10... imscottr R/C Items: For Sale/Trade 2 08-28-2003 01:56 PM
