Old 09-29-2008, 08:47 PM   #1276
Goingfast's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Slapmaster6000 View Post
I have been getting some great help here, so I thought that I would keep the momentum going. I have been trying to find the right balance adapter for the Hyperion Duo charger I just purchased. There maybe an old and a new multi-adapter or just a different part #. Here's a pic of my situation. I have an email out to the supplier.
I still have not got an answer if everyone is using a balancer or not. Or does balancing get done rarely.
Thanks!
Brian
you can use the adapter came with the charger ,you can modify for banana plug lipo set up...
SMC 28C 4000/5000 Hardcase Lipo part 2-balancer-adapter.jpg
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 09-29-2008, 09:55 PM   #1277
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Thanks guys! I am feeling 99% good about this new science now. Just threw out the Leisure Timer Charger and those Saft stick packs last week. Movin' on!!!
Franko! Is that lace on your work bench?
Slapmaster6000 is offline   Reply With Quote
Old 09-30-2008, 12:05 AM   #1278
Goingfast's Avatar
Don't you just loving it....lol
Old 10-03-2008, 06:58 AM   #1279
quantum's Avatar
cars with lower top decks like xray and trf416 only just allow enough room for the battery to fit, and this is tougher even if you use a weight plate below the batt.... sorry if this has been asked before, but are there any plans to produce a slimmer pack to allow more clearance? is the new carbon case slimmer?
thnx
quantum is offline   Reply With Quote
Old 10-03-2008, 08:42 AM   #1280
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
thnx
The 4000 pack is plenty thin and even with a PPD plate it fits with no problem at all. I even have a lead plate from Team Fusion sandwiched between my pack and my PPD plate and it fits fine. I juts bought 2 carbon case packs that they are the same thickness as the red cases...20.5mm.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 10-03-2008, 11:27 AM   #1281
Grenade10's Avatar
Trader Rating: 37 (100%+)
Thanks guys! I am feeling 99% good about this new science now. Just threw out the Leisure Timer Charger and those Saft stick packs last week. Movin' on!!!weird:
Brian ... Say it aint SO!!! Man I'm going to be the only one running 80's old school stuff!!! Did finally get rid of most of the stuff from the 70's but not all
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 10-03-2008, 01:06 PM   #1282
Verndog's Avatar
thnx
Here is a very good write up on the 416 and fitting a Lipo the size of the 4000 SMC into it.
http://www.rctech.net/forum/4161632-post118.html
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-03-2008, 01:30 PM   #1283
lbckevin's Avatar
Trader Rating: 91 (99%+)
I run the 4000 pack in my Xray 2008 with the PPD lower tray and it fits excellent.
Ps...
I got the new 5000 top wire red/black case battery and the Hyperion EH adatper does not work at all, thanks for the wrong info Still Bill. The balancer seems to be changed from the older pack.
What balancer adapter would I need for the Hyperion Duo Charger ?
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 10-05-2008, 01:39 PM   #1284
rcjunkie3000's Avatar
Trader Rating: 94 (100%+)
Default Balancer question
I am planning to buy a balancer adapter for an SMC 5000 hard case pack. Is the SMC 5000 (new one with wires coming out on top) a 2S, 3s? I also own the new 4900 saddle, is it also 2s, 3s? I need to buy enough adapters for both packs unless they use the same type
I want to balance and charge at the same time. I currently have the Checkpoint balancer but I need an adapter (I read that the Checkpoint balancer is the same as the Great Planes Equinox). I located a Great Planes Elecrtify Equinox adapter GPMM3161 . Will I be able to charge and balance using this? If not and I use it just for balancing, how will I know that the cells are balanced? I know it's not necessary to balance all the time.
OR
Will I need the Great Planes ElectriFly Equinox GPMM3163 instead? The description reads that it is a high power adapter set and it comes with a deans adapter for charging. Does this have the Align-style plug?
Are there any other balancers, SMC adapters for the Checkpoint-style balancer or an all-in-one charger that can handle all forms of balancing plugs incl. Orion-style bullet balancing (still own some of those too)?
Thanks!
RCJunkie3000 - Gonzo69 Paints / Lex Tyler Paints / Norcal Hobbies
http://www.rctech.net/forum/r-c-items-sale-trade/344416-rcjunkie3000s-garage-sale-batteries-escs-chargers-cars-accessories-etc.html
rcjunkie3000 is offline   Reply With Quote
Old 10-05-2008, 02:03 PM   #1285
Hide's Avatar
Off topic but it seems to be the best place to ask. Do you have any 1/18th scale LIPO saddle packs?
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 10-05-2008, 07:04 PM   #1286
Still Bill's Avatar
Ps...
Will be checking at the hobby shop where I bought everything... Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-06-2008, 03:28 PM   #1287
Hide's Avatar
Guys....
Got the Hyperion Duo charger today and the very first thing they comment about is be sure to use the balance tap and to connect and disconnect in the proper order. Right away, I see that the Hyperion 2S balance tap has 5 pins while the SMC 5000 has only 3. Was there an adapter I needed? Are you guys using the balance system?
Oh, and in the instructions, it did call out that if you create your own charge leads that they need to be a minimum of 14g and no longer then 8". So there must be a voltage drop concern.
Brian
I bought a Hyperion ~ jst-xh adapter from here (its a UK site but I'm sure you can get it abroad). It works with my RED HARDCASE 5000 MaH LiPo from SMC. I also made my own charge leads by buying some 12 gauge wire, Deans, and 4mm banana plugs.
Old 10-06-2008, 07:03 PM   #1288
dag32's Avatar
Trader Rating: 109 (100%+)
Ps...
Kevin I think this is what you need its the same thing listed in the previous post.
http://www.maxamps.com/HYP-MULTI-ALIGN.htm
dag32 is offline   Reply With Quote
Old 10-09-2008, 07:42 PM   #1289
Joel Lagace's Avatar
So i have had my 4000SMC since the spring, have used it in my buggy and now my sedan... My history with this pack has been to charge at 8amps and repeak repeak repeak.........
So i grabbed a Equinox balancer last nite. First time i had ever used a balancer...... Within 10seconds my pack was balanced!!!
So looks like SMC makes the perfect 2cell matched LIPO packs!!!
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-09-2008, 08:47 PM   #1290
mojoman's Avatar
+1
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
* * * BRAND NEW * * * FTB4, SMC 5000 28c Hardcase 7.4 Lipo, JR Z8800s jpeck R/C Items: For Sale/Trade 12 10-26-2008 04:03 AM
FOR SALE: SMC 4000 28C HARDCASE LIPO'S commander Australia For Sale/Trade 4 10-20-2008 11:08 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC 28C 4000 hardcase lipo fred kellner R/C Items: For Sale/Trade 0 04-09-2008 08:31 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
