Old 09-25-2008, 04:36 PM   #1261
Trader Rating: 14 (100%+)
Originally Posted by brians11 View Post
Not any more Just ordered 2 and now it shows out of stock. Hope I got there in time.
rushrush1 is online now   Reply With Quote
Old 09-25-2008, 08:44 PM   #1262
Still Bill's Avatar
Pretty good...for a Tech Rookie.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-25-2008, 11:11 PM   #1263
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Guys....
Got the Hyperion Duo charger today and the very first thing they comment about is be sure to use the balance tap and to connect and disconnect in the proper order. Right away, I see that the Hyperion 2S balance tap has 5 pins while the SMC 5000 has only 3. Was there an adapter I needed? Are you guys using the balance system?
Oh, and in the instructions, it did call out that if you create your own charge leads that they need to be a minimum of 14g and no longer then 8". So there must be a voltage drop concern.
Brian
Slapmaster6000 is offline   Reply With Quote
Old 09-25-2008, 11:56 PM   #1264
Still Bill's Avatar
Originally Posted by Slapmaster6000 View Post
Guys....
Brian
Brian,
I didn't keep the header cards with the part numbers; but, sure that you need the following Hyperion parts to connect to the SMC 4000/5000 packs with Deans plugs:
#1) HP-OUTCORD HYPERION OUTPUT CHARGER WIRE SET W/2 X 4 MM MALE BANANA PLUG $3.95
Then you only have to solder a Deans plug (male) to the bare ends of the Wire Set.
And
#2) HP-LB10-XH-B HYPERION MULTI-ADAPTER BALANCE HARNESS 2S-6S-XH $4.95 (EDIT: Now confirmed with the part number indicated. My apologies to IBCKevin for the wrong info earlier 10/6/08)
These replace the two multi-adapters that came with the charger. The balance plug on the SMC 5000 pack connects to the smallest port on this adapter.
With the Duo, you will want two sets of the above.
Cheers!
Bill
Old 09-27-2008, 10:05 PM   #1265
lbckevin's Avatar
Trader Rating: 91 (99%+)
I just got my SMC 5000 pack today ....I got the new black and red case with the top wires....fit in my Associated T4 real good.
I ran my SMC 4000 in the Xray t2008 today and had tons of rip in 19t.
Thanks.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 09-29-2008, 05:08 AM   #1266
Bill-CZ's Avatar
Send a message via ICQ to Bill-CZ
is it same or not?
http://rc-mushroom.com/product_info....ducts_id=15398
and
http://shopping.rcmodel.hk/index.php...=&filter_id=79
only prise or something new...?
Bill-CZ is offline   Reply With Quote
Old 09-29-2008, 07:00 AM   #1267
mojoman's Avatar
Originally Posted by Bill-CZ View Post
They are the same cells. Only difference is the carbon case and the wires on the black case are coming out the top instead of the side.
HTH,
Casey
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 09-29-2008, 11:50 AM   #1268
speedsterblade's Avatar
I've heard second hand from some racers about some smc lipos being the best packs they've ever ran... my maxamps 4400 saddle pack in my B44 is failing...need a new saddle pack...and soon, more reg lipos to replace my orion 3200s in my other cars.... Found this thread but haven't read every page.. What's the skinny on the smc saddle packs? or where can I find some more info on them? http://www.smc-racing.com/ is of no use...
thanks!
oh, and what kind of balancing tap?..like orions or not?
speedsterblade is offline   Reply With Quote
Old 09-29-2008, 12:20 PM   #1269
timmay70's Avatar
thanks!
Our local shop has had the saddle packs for a couple of weeks now, so they should be order-able at your LHS.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 09-29-2008, 05:36 PM   #1270
I have been getting some great help here, so I thought that I would keep the momentum going. I have been trying to find the right balance adapter for the Hyperion Duo charger I just purchased. There maybe an old and a new multi-adapter or just a different part #. Here's a pic of my situation. I have an email out to the supplier.
I still have not got an answer if everyone is using a balancer or not. Or does balancing get done rarely.
Thanks!
Brian
SMC 28C 4000/5000 Hardcase Lipo part 2-p9290235.jpg
Old 09-29-2008, 05:47 PM   #1271
Maybe I am a little soft in the grey matter. Bill has told me what I need. Everyone agree?
Still: balance or not to balance?
SMC 28C 4000/5000 Hardcase Lipo part 2-hp-lb10-eh.jpg
Old 09-29-2008, 06:05 PM   #1272
skypilot's Avatar
brian, if your asking is it a must, no you do not need to balance charge everytime, does it hurt no, how often do you need to balance, depends on the quality of the cells, as you know i ran two or three times a week, i will put my lipos on a balancer once a month or every other month, they balance themselves in about 5 minutes, usually less
SIR may have the adapters you need for balancing in stock
semi retired..
skypilot is offline   Reply With Quote
Old 09-29-2008, 07:48 PM   #1273
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hi Brian
I would balance the first fresh or new lipo (don't charge)..for reason that is to know what's the condtion of the voltage reading between two cell,,...then charge the lipo after balancer done...
PS if you charge and balancer at the same time ,it would take longer to charge to finish...if the two cell voltage are reading the same # form the start then it no sweat..the charge will be done shorter time..
PSS You have to set your charger at balance mode to balancing the two cell the same..
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 09-29-2008, 07:50 PM   #1274
Goingfast's Avatar
Thanks!
Brian
that is not the one to use for SMC lipo
Old 09-29-2008, 07:59 PM   #1275
Still Bill's Avatar
Brian,
That adapter you took the picture of is useless for the SMCs. Mine are already put away in a drawer. Probably will serve no purpose...ever.
PM Danny at SMC and start a dialog with him. He is a master of this stuff and has set me on the right course every time...NIMH and Lipo-wise.
And, I bet that he will also tell you the next step to go.
Bill...Not in the least bit sponsored by SMC...LOL
* * * BRAND NEW * * * FTB4, SMC 5000 28c Hardcase 7.4 Lipo, JR Z8800s jpeck R/C Items: For Sale/Trade 12 10-26-2008 04:03 AM
FOR SALE: SMC 4000 28C HARDCASE LIPO'S commander Australia For Sale/Trade 4 10-20-2008 11:08 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC 28C 4000 hardcase lipo fred kellner R/C Items: For Sale/Trade 0 04-09-2008 08:31 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
