SMC 28C 4000/5000 Hardcase Lipo part 2 >
Old 08-15-2008, 01:23 AM
  #1036
kschu's Avatar
Trader Rating: 16 (100%+)
hi, can i charge higher than 1c for smc4000 lipo ??
what is the cons if i do so ?? the lipo will spoil ?
kschu is offline
Old 08-15-2008, 09:36 AM
  #1037
Company Representative
Danny/SMC's Avatar
Our Lipos can be charged at 2 to 3C but I reccomend 2C as this should not reduce the cycle life of the pack. The advantage of charging at 2C is faster charge times.
Danny/SMC is offline
Old 08-15-2008, 09:46 AM
  #1038
rjs_13203's Avatar
u guys going to make anything for the b44, or saddle packs in general
rjs_13203 is offline
Old 08-15-2008, 10:35 AM
  #1039
Read the first post at the top of this page.
Jack Rimer is offline
Old 08-15-2008, 11:32 AM
  #1040
rjs_13203's Avatar
lol i seen that after i already posted
Old 08-15-2008, 07:27 PM
  #1041
Jsaves's Avatar
What are you guys using for chargers that are easy to travel?
Thanks and God Bless
Jsaves is offline
Old 08-15-2008, 08:29 PM
  #1042
keepitmovin504's Avatar
Trader Rating: 31 (100%+)
The trusty Duratrax Ice
keepitmovin504 is offline
Old 08-15-2008, 09:07 PM
  #1043
Still Bill's Avatar
And ease of use, the LRP Pulsar 3.
Still Bill is online now
Old 08-16-2008, 09:56 AM
  #1044
STLNLST's Avatar
Trader Rating: 22 (100%+)
+1
STLNLST is offline
Old 08-16-2008, 10:48 AM
  #1045
Trader Rating: 47 (100%+)
When charging at 2C on a 4000 pack. I noticed that when you set the battery mah to 4000, the max you can charge it at is 4 amps.
Does everyone just put in the mah to 8000 so they are able to charge at 8 amps ( 2C ) or is there a different way to do it?
Kingsbury is offline
Old 08-16-2008, 12:00 PM
  #1046
ta_man's Avatar
Trader Rating: 154 (100%+)
Depends on the charger. The Hyperion EOS0610i I use will let you set the charge rate to at least 2C (10 amps on a 5000 pack). You don't have to lie to it about the capacity. The Turbo35 would probably let you do that or more.
ta_man is offline
Old 08-16-2008, 12:46 PM
  #1047
Danny/SMC's Avatar
Some chargers won't allow you to charge higher than 1C but you can trick the charger by putting the mAh at 8000 which should allow you to charge at 8 amps.
Old 08-16-2008, 02:12 PM
  #1048
Verndog's Avatar
I carry 3 batteries so charging @ 1c keeps me running during practice. Those that want to charge 2c with the Ice do just that, put 8000 mah into capacity for 4000 @2c = 8 amps.
Verndog is offline
Old 08-16-2008, 03:13 PM
  #1049
Team EAM
Trader Rating: 79 (100%+)
The GFX requires a Mah setting. So to charge at 8 amps you must set the mah to 8000 and so on.
The pulsar 3 allows you to charge at any rate you wish....it doesnt have a mah setting.
Those are the only two I know of.
EA
EAMotorsports is offline
Old 08-16-2008, 04:38 PM
  #1050
yokemad's Avatar
Hi Guys
I recently ordered SMC 4000 Pack but My current Pack is Trackpower 4900 and I've got Trakpower Balancer!
Balancing connections are different as you know
Do I have to do Balance Charge?
or
Is that what I need?
2/3/6S HIGHRATE - V BALANCER HARNESS
yokemad is offline
