Old 06-09-2008, 09:36 AM   #796
mojoman's Avatar
Originally Posted by Danny/SMC View Post
When testing a Lipo pack on the T35-GFX the packs that have lower IR and higher average voltage will run better on the track. Some seem to think that testing Lipos at 35 amps on the GFX isn't the correct way of testing Lipos for performance. So far I have tested many packs using the GFX and results on the track prove that testing on a GFX is a good way of testing Lipos.
Danny,
When you are cycling packs do you balance while charging? Or just charge and discharge through the power leads? I guess my point is to find out if there are any signifigant differences in a balanced cycle vs. an unbalanced cycle on the GFX.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 06-09-2008, 09:46 AM   #797
Trader Rating: 16 (94%+)
Originally Posted by mojoman View Post
Danny,
I don't think the balance connector/plug can handle that much current.
Danny?
kn7671 is offline   Reply With Quote
Old 06-09-2008, 11:49 AM   #798
Company Representative
Danny/SMC's Avatar
Danny,
Balance charge is good to do once in awhile but it's not needed everytime you charge. When I cycle using the GFX and don't use the balancer.
I have seen a small improvement in pack performance by balance charging and I have over 10 cycles on a pack that was balance charged once a regular charge for the next 10 or so cycles and the numbers have stayed the same.
Danny/SMC is offline   Reply With Quote
Old 06-09-2008, 11:54 AM   #799
Danny/SMC's Avatar
Danny?
If you look at the high power adapters that are sold for this balancer you can see that they removed the outer black and outer red wire and attached these to a Deans male plug which then goes straight to the packs power leads. With this setup you can charge up to 6 amps and I have used it at 5 amps with good results.
I would not use this balancer without the high power adapter or modifying the adpater that comes with it.
http://www3.towerhobbies.com/cgi-bin...3163&search=Go
Old 06-11-2008, 11:51 PM   #800
Cameron Kellogg's Avatar
Trader Rating: 45 (100%+)
Hello Danny,
I just wanted to say hi and tell you I just bought my first lipo pack; SMC 4000mha. The MAIN reason I bought your pack, besides the great "C" rating(which I did not even know what that was until reading about it here), was because you are here and I think the info you share with us in regard to Lipo battery technology is great. I appreciate your time here and thats why I will be purchasing more SMC batteries.
Cameron
Cameron Kellogg is offline   Reply With Quote
Old 06-12-2008, 12:21 PM   #801
Danny/SMC's Avatar
Thanks for the kind words. I feel the internet can be great to share info and I have always liked helping out when possible.
Old 06-19-2008, 07:05 PM   #802
jammincrtjames's Avatar
What type of balance tap comes on the 4000 pack?
NEXUS RACING www.nexusracing.com | FANTOM RACING www.fantomracing.com
ORCA www.orcarc.com | TURTLE TRAX / www.turtletraxraceway.com
"If you're not first...you're last!"
jammincrtjames is offline   Reply With Quote
Old 06-19-2008, 09:56 PM   #803
The Bear's Avatar
Just a little update. I've got well over 50 runs on my 13.5 sedan. I run for 5 minutes, come in and put it back on the charger. No cycling or balancing. This thing is freakishly amazing each time. Danny, thanks for such a tough product.
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Old 06-19-2008, 10:05 PM   #804
lbckevin's Avatar
Trader Rating: 91 (99%+)
Danny,
Any further word on the saddle packs ? The offroad ROAR nats is just a little ways away and I want to run your packs. It needs to be ROAR approved like your other packs, in order to run them.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is online now   Reply With Quote
Old 06-20-2008, 02:02 PM   #805
Danny/SMC's Avatar
The balance connectors we use is JST-XH.
Old 06-20-2008, 02:05 PM   #806
Danny/SMC's Avatar
Originally Posted by lbckevin View Post
Danny,
Were still waiting on the casing to be done. We should have a test casing/pack in by the end of next week. If everything is o.k. we will go into production which means the packs should be available by the end of July if all goes as planned.
Old 06-22-2008, 05:23 AM   #807
Daddy's Avatar
Hi Danny/SMC,
An interesting question was raised at my track recently, What is the maximum cell voltage imbalance in a lipo pack before it becomes dangerous?
Daddy is offline   Reply With Quote
Old 06-22-2008, 12:03 PM   #808
timmay70's Avatar
Hi Danny,
The word occur is misspelled in the second to last paragraph in the instructions...
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 06-22-2008, 12:23 PM   #809
Danny/SMC's Avatar
Originally Posted by Daddy View Post
Hi Danny/SMC,
I'm not really sure but our supplier told me that our cells can be charged to 4.3v with no issues so I would say that .10 off would be o.k.. Based on some of the overcharge stories I have heard I'm pretty sure it could go even higher but the problem is that while one cell is overcharged they other cell will be undercharged.
Old 06-24-2008, 12:03 AM   #810
mojoman's Avatar
I just got two 4000 packs and did some initial testing on charge methods. Here are my findings.
Method 1- Charge/Discharge straight through the power leads no balancing at all.
Pack#1
Charge-4089
Seconds-2790
Discharge-4112
Seconds-423
Average Voltage-7.30
Resistance-7.8
Pack#2
Charge-4126
Seconds-2833
Discharge-4093
Seconds-421
Resistance-8.2
Method 2-Balanced charge (interface mode)
Pack#1
Charge-4178
Seconds-4906
Discharge-4102
Seconds-422
Average Voltage-7.29
Resistance-8.4
Pack#2
Charge-4171
Seconds-4784
Discharge-4073
Seconds-419
Average Voltage-7.28
Resistance-8.7
Method 3-Discharge pack to 6v then balance cells using a soft discharge (typically .10 to .12 amps)
Pack#1
Charge-4125
Seconds-2886
Discharge-4122
Seconds-424
Average Voltage-7.32
Resistance-7.3
Pack#2
Charge-4067
Seconds-2747
Discharge-4083
Seconds-420
Average Voltage-7.33
Resistance-6.9
All tests were done using CE GFX and a Great Planes Equinox Balancer. Charges were at 6 amps and discharges were at 35 amps.
Casey Castleman
* * * BRAND NEW * * * FTB4, SMC 5000 28c Hardcase 7.4 Lipo, JR Z8800s jpeck R/C Items: For Sale/Trade 12 10-26-2008 04:03 AM
FOR SALE: SMC 4000 28C HARDCASE LIPO'S commander Australia For Sale/Trade 4 10-20-2008 11:08 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC 28C 4000 hardcase lipo fred kellner R/C Items: For Sale/Trade 0 04-09-2008 08:31 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
