Old 06-02-2008, 11:09 PM   #766
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by bmmer701 View Post
thanks verndog i would just like to know if you can mount the smc 5000 pack with the ez lipo base to the 416. (i saw a picture with ppd plate with a 4000 smc pack. not sure if a 5000 smc will heat the top deck) i read somewhere that smc height is 24.5mm while the clearance for 416 is only 25mm.
That is likely so. Our base plate is just shy of 1mm thick after installed, and the pack reviewed was 23.5mm thick, and it just fit.
Looks like the 4000 is the more practical fit in the 416.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 06-05-2008, 06:27 PM   #767
syndr0me's Avatar
Trader Rating: 32 (100%+)
You know what's hotter than a LiPo fire? Charging and balancing two packs simultaneously.
SMC 28C 4000/5000 Hardcase Lipo part 2-img_0762.jpg
syndr0me is offline   Reply With Quote
Old 06-05-2008, 07:19 PM   #768
lbckevin's Avatar
Trader Rating: 91 (99%+)
is that charger ac/dc as well...?
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 06-05-2008, 08:37 PM   #769
syndr0me's Avatar
Nope, DC only. It's about the size of an ICE, though maybe just a tad larger. It's two full chargers and balancers, and can do 10A on either side, simultaneously. Firmware is upgraded via USB, not sending it in for a new EEPROM. It'll do just about every type of cell imaginable, and can mix chemistries. So, you could be charging a LiPo on one side at 5A, and a NiMH on the other at 8A. It's a nice charger. :-)
Old 06-06-2008, 07:11 PM   #770
MaxRain's Avatar
Default SMC lipo source
Most of us know about the common manufacturers, Kokam, Enerland etc. But has anyone heard about Simplo Technologies?
Could this be the mysterious supplier for SMC?
Don't want to start any speculation, but it would be interesting to find out.
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06, and I run all Tekin ESC's - Youtube Channel "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg - Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 06-06-2008, 07:21 PM   #771
Company Representative
Danny/SMC's Avatar
No this isn't our supplier. I have mentioned before that our supplier custom makes the high C rate Lipos exclusively for SMC. Even if I would mention the name you wouldn't find any info online about this company.
Danny/SMC is offline   Reply With Quote
Old 06-07-2008, 06:22 AM   #772
stiltskin's Avatar
Trader Rating: 102 (100%+)
Damn you Syndrome. I've been very happy with my Checkpoint and now you have to show me this. You're not my friend anymore.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 06-07-2008, 10:37 AM   #773
syndr0me's Avatar
Haha, sorry man! I've got a Checkpoint Bloody ICE for sale if you want another one. :-D I've been getting a lot of questions about the charger, so here's what I've been telling people:
So far, the charger is awesome. It's two full chargers and two full balancers in one. So, each side is capable of charging at 10A simultaneously. I charge my packs at 1C, so I'm only using half that. And yeah, it can balance both packs while charging. About the only complaint I have is that it's got a small 2 line screen, rather than something big like the ICE. Also, it beeps annoyingly after the battery is done charging until you stop it. I haven't figured out how to turn that off. It's got 10 different "charging finished" tones, and you can set them to be different on each side. In reality, it's two separate chargers and you switch between them with the CH button. The functions for each side are completely independent.
The balancer is cool, it shows you the voltage of each cell. You can toggle into that view while you're charging, or look at the other screens with the normal info, including internal resistance.
So, here's what I ordered:
1 x Hyperion EOS0610I DUO $269
2 x Hyperion XH Multi Adapter (for SMC packs) $7 each
1 x USB Adapter $18
1 x Firmware Adapter $2
The last two pieces will allow you to update the firmware from your PC, and apparently display more data once the software is released.
Hyperion's site isn't great, but it's got some info. I wonder if that beta software for the PC works with the DUO? I'll have to try it! Also, there's 80+ pages of discussion from the R/C flight crowd here. Most of it is quite favorable.
Old 06-07-2008, 10:53 AM   #774
syndr0me's Avatar
Looks like the PC software is out. Here's some discussion on it, solicited by a company rep. Cool stuff.
http://www.rcgroups.com/forums/showthread.php?t=873516
Old 06-07-2008, 11:02 AM   #775
bmmer701's Avatar
Trader Rating: 17 (100%+)
hi just bought smc's 5000 lipo pack. just want to ask for those who have tried this battery and those that have tried orion's 3600. do you need to change your gearing? if so, if you are using lets say 38 pinion when you were using orion 3600. if you use the smc 5000 lipo plus you heat them also, do you need to put 39t pinion or 37t pinion? thanks hehe hope it make sense
bmmer701 is offline   Reply With Quote
Old 06-07-2008, 11:05 AM   #776
Danny/SMC's Avatar
Typically you should gear down as our packs have higher voltage and lower IR. I would start with 3 teeth less on the pinion and look at your motor temp after a run. If it's to hot go down more and if it's cooler than when you run the Orion pack gear up.
Old 06-07-2008, 10:50 PM   #777
The Bear's Avatar
little update. still beating my packs like red headed step child. charge, run, repeat. no loss of power or performance, these packs are amazing. Thats 35 runs with no love (cycle/balance, etc).
*I do not advocate the destructive methods I'm using, only playing the roll of test dummy.
Sponsors for 2013 - NoVak / Team Scream / liquidrc.com
The Bear is offline   Reply With Quote
Old 06-08-2008, 03:49 AM   #778
Danny
last weekend ran an orion 10.5 with the smc 4000 packs and i must say faultless although one of my mates was running the same motor on a track power 4900 and mine come of the track at 42.5 c (packs were cool) with a rollout of 40 and his come of at 75.0 c with a rollout of 36 ( packs were quit warm) with a difference in straight line speed of about 3 feet to me.Lap time were within .5 sec. How hot should the lipo get ??????
Competition ended on the sunday arvo so i placed the 4600 MM in for a trial run which turned into 2 batteries and 25 min later and the lipos were warm. What an excellent combo SMC4000 , Castle Creations 4600 just got get a bit more experience befor i place the 7700 in
Steven
Casino Kid is offline   Reply With Quote
Old 06-08-2008, 08:10 AM   #779
STLNLST's Avatar
Trader Rating: 21 (100%+)
you said dummy
STLNLST is offline   Reply With Quote
Old 06-08-2008, 08:56 AM   #780
The Bear's Avatar
heh, heh, heh,,,,,,,,, poop.
* * * BRAND NEW * * * FTB4, SMC 5000 28c Hardcase 7.4 Lipo, JR Z8800s jpeck R/C Items: For Sale/Trade 12 10-26-2008 04:03 AM
FOR SALE: SMC 4000 28C HARDCASE LIPO'S commander Australia For Sale/Trade 4 10-20-2008 11:08 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC 28C 4000 hardcase lipo fred kellner R/C Items: For Sale/Trade 0 04-09-2008 08:31 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
