Old 05-13-2008, 09:32 PM   #646
Wade Rowley's Avatar
Originally Posted by Danny/SMC View Post
Were thinking of changing our Lipo case so the wires would come out on top of the casing. What I would like to know is in what corner should we put the wires ? When looking at a sedan would you rather have the wires on the outside front of the pack or the outside rear ?
if you could split the difference between center and the outside edge it would help. it really does not matter which end you put it on because, depending on the car (right, left, or center battery mount), it will end up either in the front or the rear outside anyway.
what really gets in my way is the balancing plug, wish you could use a system similar to the orions.
IF IT ISN'T BROKE, FIX IT UNTIL IT IS...
THE SURGEON GENERAL NEVER SAID ANYTHING ABOUT SMOKING THE COMPETITION...
HORSEPOWER IS HOW FAST YOU HIT THE WALL... TORQUE IS HOW FAR THE WALL MOVES AFTER YOU HIT IT...
Wade Rowley is offline   Reply With Quote
Old 05-13-2008, 11:05 PM   #647
poorbie:('s Avatar
Send a message via MSN to poorbie:(
any idea on when these newer packs would be out? and will anyone of your dealers ship internationally to australia as it seems that they are classed as flammable and tower wont ship them etc...
id love the idea of having packs without wires... this would allow me to cleanly connect up the packs in series and have no excess "baggage" so to speak of....
what diameter would the plugs be? thats the only issue when taking serious amps out of these packs? would a 5mm plug be too big? will the current plugs be able to take what the pack says it will provide (120A+)
and is charging these straight after the run while still warm in a very warm environment(30-40 degrees C) ba dfor them, ive read thorugh the thread, and id only charge at 1c anyway, but will it hurt the life of it? (seems to help in the short term, just considering my small budget, id like to get longer life with possibly slightly less performance (i dont race hard, just have fun!)
thanks
Xray XT8E
MMM - Neu 1512 3D - 4/6S lipo.
Xray '09 T2 - Losi esc + motor - 2s lipo
poorbie:( is offline   Reply With Quote
Old 05-14-2008, 12:03 AM   #648
Company Representative
Danny/SMC's Avatar
Thanks to everyone for the input and just as I thought it's impossible to come out with a position for the wires that will suit or please everyone.
Our packs are made using the best materials available which is the reason why they have high average voltage and low IR. Since these packs are designed with racing in mind it makes no sense for us to make the connection inboard as this requires the use of a PC board which will increase IR. By using wires the racers have the option soldering directly to the wires to get maximum performance out of the packs. Were considering going to 10 gauge wire to improve the connectivity.
Danny/SMC is offline   Reply With Quote
Old 05-14-2008, 12:12 AM   #649
syndr0me's Avatar
Trader Rating: 32 (100%+)
Danny,
The 5000 packs seem to be getting hard to find. Will they be making it to shops again soon? Also, what balancing tap do you use?
syndr0me is offline   Reply With Quote
Old 05-14-2008, 12:42 AM   #650
Danny/SMC's Avatar
The packs are exclusively made for us and so our supplier will only build what we order. Our initial shipment soldout much faster than we had expected so we had to order more and they take 2 months to get done. We have a new shipment of 5000s coming in next week and 4000s the following week. Our supplier also told us he would be ordering more material to try and cut down on the time it takes to get orders done.
The balance connector is the same as Align , E-Flite and ElectriFly. It's used by other companies as well so it's pretty common.
The Deans style connectors used on our packs don't fit as tight which seems to create extra resistance which makes for inconsistent cycle numbers. There seems to be fluctuations from connector to connector so starting with this newest batch we will take the packs cycle info straight from the wires which means the numbers will look better as we will bypass the connectors. This is done to try and get more consistency out of the cycling.
For those using the original connector on our pack I would reccomend replacing it with a new Deans connector. I also reccomend you change the male Deans connector once in awhile to keep everything tight to keep resistance as low as possible.
Old 05-14-2008, 04:13 AM   #651
Tornado_Racing's Avatar
Originally Posted by ShaunMac View Post
Tony - What type of heating pad are you using?
Walmart brand, just use some rubber bands and wrap it up like a burrito.
Tony Moffre
PRS Customer Service
PRS - Hyperdrive - EA Motorsports - Corally USA - Parma/Faskolor - SMC - Killer Koncepts - MSA - Finishline - IRS - Lunsford - Trinity - Guarantee Graphix - RC4Less
Tornado_Racing is offline   Reply With Quote
Old 05-14-2008, 06:21 AM   #652
i know i am not Tony, but.....i put my heating pad in a LIPO SAC, kills 2 birds with one stone. i did find i had to use a lower setting on the heating pad to get the desired temp because it was in the "SAC".
Old 05-14-2008, 09:34 AM   #653
The Bear's Avatar
Hey, just wanted to post a thanks. Ran my 5000 last night 5 times with a simple re-peak between runs. Pack was outstanding!
and again, anyone using an RDX, these packs fit in with no mods AND you can put the wires facing forward/inside and lead them through the top deck for a wicked clean look!
Thanks Again!
The Bear is offline   Reply With Quote
Old 05-14-2008, 10:51 AM   #654
jag88's Avatar
I'm wondering how this would be possible ? (the soldering part)
jag88 is offline   Reply With Quote
Old 05-14-2008, 10:57 AM   #655
timmay70's Avatar
A thing commonly known as a soldering iron.
sorry, couldn't resist...
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 05-14-2008, 11:03 AM   #656
Danny/SMC's Avatar
You solder your speed control wires directly to the wires of the pack.
SMC 28C 4000/5000 Hardcase Lipo part 2-img00067.jpg
Old 05-14-2008, 11:34 AM   #657
i would recommend this type of connection to be used by only ADVANCED racers. for "regular racing" or "backyard" running please use connectors.
Old 05-14-2008, 11:35 AM   #658
syndr0me's Avatar
Holy crap!
Old 05-14-2008, 12:44 PM   #659
jag88's Avatar
Originally Posted by syndr0me View Post
Holy crap!
What he said !!!!!!
Old 05-14-2008, 01:30 PM   #660
Direct soldering is really easy. Just make sure you cut one wire shorter than the other so they don't cross.
Tony Moffre
* * * BRAND NEW * * * FTB4, SMC 5000 28c Hardcase 7.4 Lipo, JR Z8800s jpeck R/C Items: For Sale/Trade 12 10-26-2008 04:03 AM
FOR SALE: SMC 4000 28C HARDCASE LIPO'S commander Australia For Sale/Trade 4 10-20-2008 11:08 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC 28C 4000 hardcase lipo fred kellner R/C Items: For Sale/Trade 0 04-09-2008 08:31 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
