Old 05-10-2008, 04:08 PM   #616
sonic31's Avatar
who's got the 5000 hardcase in stock i need 2 of them ...
Tamiya TRF418 SAMIX / KO Propo / Tekin RS Pro / Spektrum
sonic31 is offline   Reply With Quote
Old 05-10-2008, 07:56 PM   #617
The Bear's Avatar
Ok, wondering if you could help me out. Have a 5000 and an ICE. What are the steps of use? Using NiMh, I would charge at 8amps, run, discharge, equalize, cool down and charge again.
After reading through this thread, it sounds like the steps are: charge at high amps if you don’t have a method of warming after charge, run, discharge at 35 amps, cool off and charge preferably with a balancer to allow for release of overflow charge to the shorter cell(s).
It sounds as though balancing is more of an option than a requirement and the charge rate is not held to the 1amp per 1000 mah. However, in looking at JimmyMac posts, his second pack is starting to take less of a charge. Granted, sounds like he gave them a workout, but is going through a forced cycle (35amp discharge/12amp charge) going to decrease overall life and mah capacity?
Danny, sounds like you have been trying both with the main intent on keeping the pack warm before use. For a person like me who is planning on running this pack not only through the summer (5 to 10 runs a week at least) but preying they can last through vegas, would I be correct in saying 5amp charges will allow the pack to stay as fresh as possible to vegas?
Sorry for the long post and multiple questions, but I’m stoked to run a product like this! HELLO POWER!!! Wooooo Ha!
Thank you!
The Bear is offline   Reply With Quote
Old 05-10-2008, 09:03 PM   #618
suntok2's Avatar
Send a message via ICQ to suntok2 Send a message via AIM to suntok2 Send a message via Yahoo to suntok2
Originally Posted by Casino Kid View Post
iv just purchased 6 x 4000 smc lipos and a GT Power charger and it works a treat. here is the site http://www.hobbycity.com/hobbycity/s...dProduct=6443#
Steven
Please check again because we tested this charger and after 3 to 4 min the lipo battery drop a little. when we use hyperion the power from the start to end is the same.
suntok2 is offline   Reply With Quote
Old 05-11-2008, 01:17 AM   #619
Super Moderator
Grizzbob's Avatar
Originally Posted by chad423 View Post
i just purchased your 5000 pack.im looking for balancer is the new max amps method balancer any good?
Everyone's got their opinions, but I for one really like the Core UDC-20, it'll charge almost ANYTHING & can balance packs from 2S through 6S(I believe, personally I don't need anything more than 2S balancing, since I only use 2 cell packs), & the SMC packs' balance plug is the same as the UDC-20 uses, so you don't even need an adapter. I've been using it a few weeks now & I'm really liking it......
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 05-12-2008, 10:30 AM   #620
mojoman's Avatar
Check with Team OHP (link in my sig.) Last time I checked he had some. Call the tel. # The lipos aren't on the website but I know he carries them.
Peace,
C
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 05-12-2008, 12:25 PM   #621
The Bear's Avatar
I've also heard that you can 'trick' a charger (ice or checkpoint) by lying about the number of cells to achieve a higher charge rate (no gfx for me yet). Also wondering if a slow charge would be of any benefit?
thanks!
Old 05-12-2008, 12:30 PM   #622
stitchy's Avatar
+1 on the Core UDC-20. It's great, and super easy to use.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 05-12-2008, 12:30 PM   #623
Mike Haynes's Avatar
Casey lets say you want to charge at 8 amps on an ice, tell the charger you have an 8000mah pack.
I have been using 8amp charge on my gfx for my smc packs with great results.
Every once in a while i cycle them for kicks, but on race day all i do is repeak, no warming or whatnot.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-12-2008, 12:37 PM   #624
The Bear's Avatar
sweet, thanks Mike! I was planning on just re-peaking between runs, but all this talk of 35 amp discharges and 12amp charges got me all turned around.
Any chance you would run a night with us at rce sometime?
Old 05-12-2008, 12:40 PM   #625
Yea i have to make it up there again, i hear ya even have lights now
I was all set for that February race until my buddy's 21st birthday outing the night before
Old 05-12-2008, 01:04 PM   #626
Joel Lagace's Avatar
I use the BLOODY ICE and there is no need to "trick" the charger into high amp rates. Its default setting is 1C and its default max setting is 2C.
So for my 5000mah pack i say 5000mah and the charge amp rate goes to 5amps. But if you want more you just dial it up to 10amps.... On a pack like a 3200 then yes if you want 8amps then you will need to at least cal it a 4000mah pack..
I run my 5000mah at 8amp charges between runs. Its been great so far.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 05-12-2008, 01:13 PM   #627
Company Representative
Danny/SMC's Avatar
In my testing I see that heating the pack up prior to using it in the car is what makes the pack run at its maximum. By charging at a higher rate you will reduce your charge time and it may increase the temp of the pack just a little which will yield a bit more power. You could achieve better results by warming up the pack prior to using it in the car.
When using balancers you need to be careful as some of them will not charge the pack correctly as the balancer will create extra resistance which will give the wrong voltage reading to your charger. Example: I use the Equinox by ElectriFly and to use it you need to plug your charger into the Equinox then plug the balancer into your balance plug. The maximum amps that most balance connectors can handle is 3 amps which is kind of low for a 5000 pack. Since I use a GFX I have seperate voltage sensing leads. When I attache the leads on where I plug the GFX into the balancer I was getting a higher voltage reading then when I hooked up the leads straight to the pack. This is normal as the balancer and the balance connectors have resistance. So if I were to use this balancer with a charger that doesn't have seperate voltage sensing leads then it would never charge the pack to it's full capacity. To me balance charging in theory is good but not something that must be done and if it's done you should check the voltage of the pack and the voltage your charger is dispalying to make sure it's the same. If it isn't this is due to increase in resistance by the balancer.
Here is what I do to my packs and it seems to work very well. I use the Equinox balancer by itself. This means I plug my pack into it by the balance conenctor and then balance the pack so both cells are the same. By doing this my packs stay well balanced and it allows me to charge through the power leads at the charge rate I want to use.
Danny/SMC is offline   Reply With Quote
Old 05-12-2008, 02:28 PM   #628
The Bear's Avatar
Danny: Thanks for the response, I really appreciate it. So if I want to do this the technically 'perfect' way I would: balance then charge (5amp), warm up then run. Cool down, Ballance and charge ...... many thanks.
Mike: YES! The new lights are in and it's SO bright! Kenny and I had painted the walls and we got mad comfortable rolling office chairs for the pits, add to that our new heating.... well, you get the idea.
thanks to you both!
Old 05-12-2008, 04:01 PM   #629
Danny/SMC's Avatar
Yes that will work well. There is no need to let the pack cool down prior to charging it back up as charging at 5 amps the pack will cool down while charging.
Old 05-12-2008, 04:21 PM   #630
Kenny L's Avatar
Trader Rating: 16 (100%+)
Danny,
What is the magic temp to heat packs too? And thank you very much for helping me out earlyer
Team Tekin, Ko Propo America
Kenny L is offline   Reply With Quote
* * * BRAND NEW * * * FTB4, SMC 5000 28c Hardcase 7.4 Lipo, JR Z8800s jpeck R/C Items: For Sale/Trade 12 10-26-2008 04:03 AM
FOR SALE: SMC 4000 28C HARDCASE LIPO'S commander Australia For Sale/Trade 4 10-20-2008 11:08 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC 28C 4000 hardcase lipo fred kellner R/C Items: For Sale/Trade 0 04-09-2008 08:31 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
