Old 03-01-2008, 11:42 AM   #316
Trader Rating: 18 (100%+)
Originally Posted by rai13 View Post
Roar APPROVED!
http://www.roarracing.com/approvals/lipobattery.php
Got my 5000 on order.
Just ordered a 4000.
trilerian is offline   Reply With Quote
Old 03-01-2008, 02:35 PM   #317
Company Representative
Danny/SMC's Avatar
Today Eli is using Energ 4600s and his lap times aren't faster than when he was running the 5000 pack. He tells me he feels they are pretty much the same. We have just been doing a regular 5 amp charge with no heating up of the pack prior to using it. Eli will be doing more tests at his home track track but so far it seems promising.
Danny/SMC is offline   Reply With Quote
Old 03-01-2008, 03:29 PM   #318
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
By heating do you mean an external heater or discharging at 35 amps?
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 03-01-2008, 03:34 PM   #319
glassdoctor's Avatar
Danny, I have my GFX now and I'm starting to check out some of my packs.
It's fresh from CE with the lipo update and faceplate etc. They do check/calibrate them when they get sent in don't they?
I put deans on the main leads, and clipped on the sensor leads like you showed earlier.
I'm not going to clutter your thread with data from my stuff, etc but I will say that I'm very happy with the #'s from my packs, just based on what you have posted so far. But I have more testing to do for sure...
Thanks for all the info.
glassdoctor is offline   Reply With Quote
Old 03-01-2008, 03:35 PM   #320
Danny/SMC's Avatar
Heating is to get the pack up in temp prior to using it on the track. The goal of the testing we have done so far was to see how the pack would react with regular 5 amp charge. So not heating or high amp charging and back to back cycling has been tried. The one thing we were doing is to discharge the pack after a run.
Old 03-01-2008, 03:39 PM   #321
Danny/SMC's Avatar
GFXs are calibrated but they do tend to be different from unit to unit. I have 2 of them and one of them always gives me 10 seconds more than my other but the voltage and IR is pretty much the same.
Old 03-01-2008, 06:14 PM   #322
Scottrik's Avatar
Trader Rating: 245 (100%+)
Thinking about the heating issue now, the only practical way I see of doing it is the high amp discharge as Danny has been doing it, then charge it when it's wrapped in the tire warmers or over the ceramic heater, etc. These heating methods aren't terribly effective in heating the battery thoroughly, but they should greatly slow (possibly even eliminate if you can create 140-150 degree ambient heat around the pack) heat loss while the battery charges or sits after you've warmed it via discharge.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 03-01-2008, 08:34 PM   #323
Mike Haynes's Avatar
Originally Posted by dodgeguy View Post
Danny how well does the 5000 pack fit into a Losi Type R?
Danny had me put the lipo in my car for a test fit, the 4000 went right in with no trouble, but the 5000 was too tall by the bulkheads, if you shave them down it will get in there, and there is still enough material to hold tweak and all properly, but i would be very careful not too strip out the upper deck screw holes.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 03-01-2008, 10:38 PM   #324
STLNLST's Avatar
Trader Rating: 21 (100%+)
4000 fits in my Cyclone but a 5000 won't fit since it's bigger than the orion 4800 and that barely fits. If I stick with my TC5 I can run a 5000.
STLNLST is offline   Reply With Quote
Old 03-01-2008, 11:37 PM   #325
Trader Rating: 198 (100%+)
That sucks, the 5000 pack is probably a better pack when compared to a sub C. i have a Type R and I am not going to be modifying the car to make the 5000 work. So unfortunately I am going to go with another brand of LIPO.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 03-01-2008, 11:44 PM   #326
STLNLST's Avatar
from the testing we have done and the torture tests results my boy Ling has done this is the pack to have. I'm wishing the 5000 would fit but the 4000 is still better than anything we've seen on the track. Until I get my doors blown off with something else there's no reason for me to look elsewhere.
Old 03-02-2008, 04:48 AM   #327
John Tag's Avatar
Trader Rating: 42 (100%+)
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 03-02-2008, 05:14 AM   #328
Xpress's Avatar
What are the dimensions for the 4000 and 5000 packs?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 03-02-2008, 05:22 AM   #329
From page #1:
We expect our new 28C Lipos to be shipping out to the distributors on the 28th of February.
28C/4000/7.4v
Part # 4028LD (Deans connector) 4028LT (Traxxas connector)
Retail: 160.00 Estimated street price 105.00 - 125.00
Size: L 136mm x W 46.5mm x H 20.5mm
Weight: 240 grams
28C/5000/7.4v
Retail: 195.00 Estimated street price 135.00 - 150.00
Part # 5028LD 5028LT
Size: 136 x 46.5 x 24.5
Weight: 290 gr.
Ted Flack is offline   Reply With Quote
Old 03-02-2008, 05:38 AM   #330
The 4000 should still outperform almost anything else on the market... Unless you need the runtime. The 4000's run about 4100-4200 in capacity, FYI.
Jack Rimer is offline   Reply With Quote
* * * BRAND NEW * * * FTB4, SMC 5000 28c Hardcase 7.4 Lipo, JR Z8800s jpeck R/C Items: For Sale/Trade 12 10-26-2008 04:03 AM
FOR SALE: SMC 4000 28C HARDCASE LIPO'S commander Australia For Sale/Trade 4 10-20-2008 11:08 AM
SMC 4000 mah Hardcase Lipos 28C NIB rraden R/C Items: For Sale/Trade 11 09-12-2008 11:20 AM
SMC 28C 4000 hardcase lipo fred kellner R/C Items: For Sale/Trade 0 04-09-2008 08:31 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
