Old 06-29-2003, 01:48 PM   #1
Send a message via AIM to Smartazz07
Default Has anyone had problems with the V3r
I have a V3R and sometimes when I turned it on the throttle would be reversed(my friend had the same problem).And either I could switch the throttle reversing on my controller or turn it off and on again and hope it was fixed. Also whenever I was driving it would just stop working for a few seconds and then it would come back on and it would be reversed.And I almost lost my car because of this. I got tired of it and bought a new speed control but am wondering if there would be any way to fix it. Any suggestions would help. thanks.
Brandon
Smartazz07 is offline   Reply With Quote
Old 06-29-2003, 02:54 PM   #2
I had the same problem, only when it would come back on it would have neutral set at WOT!!!! I have had problems with the Vseries and MTroniks speedos.... nevr agian will I own a POS that sets it's self when it is switched on!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 06-30-2003, 05:05 PM   #3
I know It pisse the hell out of me so I threw it away but my friend doesnt have the money for a new speedo so does anyone know of a way to fix it?
Old 06-30-2003, 11:39 PM   #4
newracer's Avatar
R/C Tech Charter Subscriber
I have a v3r and a v6r that both have to be set when first turned on. they have both worked perfectly for me. maybe you should contact horizon for repairs?
newracer is offline   Reply With Quote
Old 07-01-2003, 12:15 PM   #5
Regional Moderator
Darkseid's Avatar
I own a V3r and it has worked great for me, for the most part.
The only time I had problems with it was when I tried to run it on only 4 cells(4.8v) in my micro. The manual says that it will work with this setup, but it wont!!! Everytime I tried to set it, it would reverse the throttle(forward was backward, backward was forward) and even reversing the throttle on my radio didn't change it.
When I went to using 6 cells(7.2v) in my micro it worked like a charm. I now use it in my F201 with 6 cells and a 19t motor and it works great.
You didn't say what situation you were using yours in, so I don't know if this helps....
TLR 22...Tamiya F104...
Old 07-01-2003, 07:25 PM   #6
I had mine in an HPI pro 3 and then tried it in my xxx-s and my friend has his in a xxx-t.I had a 27t motor and he has a 19t we both have six cell packs from 1500-3300mah.
b4/t4 problems trdsupra88 Electric Off-Road 12 03-15-2008 10:52 PM
JR Z-1 Problems...need help! pumpkinfish Radio and Electronics 3 10-24-2007 05:31 PM
Problems.. Oasis Chat Lounge 9 01-16-2006 08:41 AM
tc3 one way problems dontfeelcold Australian Racing 7 12-31-2003 04:34 PM
Set Up Problems Griz Australian Racing 5 12-05-2003 12:44 AM
