Old 02-12-2008, 09:43 AM   #1
Default asphalt body?
I'm just getting back into electric sedan and need some advice on a body, we're running stock with rubber tires, extremely high traction and very tight track with a short straight.
I was thinking about the Stratus 3.0 c-type (would seem to remove some drag/traction)
How is the A-type, the Nemesis or the G6?
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 02-12-2008, 10:02 AM   #2
mac853's Avatar
Not only track condition, it depends also will you use oneway/spool or 2X diff, but i think you will use one way in the case of stock race in high traction.
Try this link which maybe could help you a little:http://www.rctech.net/forum/showthre...t=touring+body
mac853 is offline   Reply With Quote
Old 02-12-2008, 02:13 PM   #3
Your link for carpet oval wasn't really very helpful past one guy in hong kong saying M6/Speed 6 for spool.
I wouldn't consider running a one-way with my nitro car so it doesn't seem likely with the electric car either but that's a good point that I may have to try since the speed is so slow and brakes may not be required.
Do that few of you really test these bodies or have opinions on them?
Old 02-12-2008, 02:23 PM   #4
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Brain,
I would start with a PF Mazda 6, to me it is the most neutral body.
Then, after your comfortable with the car, and the way it is working, try different shells to suit your driving.
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 02-12-2008, 04:13 PM   #5
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Originally Posted by TimPotter View Post
Brain,
+1 The Protoform mazda six seems to be a common ground in bodies for outdoor touring. You may also want to think anout the Protoform DNA2 for asphalt.
Mazda
http://prolineracing.com/protoform/index.html
DNA2
Rember for electric you want 190mm
Sorry links don't get you compleatly there. Click products on the left side of te screen and then click touring car bodies
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 02-12-2008, 05:37 PM   #6
So the 6, not the speed 6 right?
At least this isn't as bad as picking bodies for 8th onroad, I have 6 and that's not even everything that could be used.
Old 02-12-2008, 06:03 PM   #7
TimPotter's Avatar
The regular 6, not the speed 6. The regular seesm to be smoother, better overall starting point body.
Old 02-12-2008, 06:15 PM   #8
Trader Rating: 244 (99%+)
If your just getting back into things you should try the Nemesis. I always liked the balance of this body.
Fred Perkins is offline   Reply With Quote
Old 02-12-2008, 07:36 PM   #9
The nemesis is more of a grip body right?
I'm looking for more of a body that frees up the car, unlike the parma m in the nitro cars. I finished 17th at the nitro sedan nationals this year so I should be ok with stock electric.
I ordered the 6 and the a-type 3.0, looking for the c-type as well.
Old 02-12-2008, 07:40 PM   #10
mac853's Avatar
I almost forgot Ri196 accord body, could be also fine!
Old 02-13-2008, 04:15 AM   #11
I would say no. It seemed to have less effect on the handling of the car.
Old 02-13-2008, 04:43 AM   #12
Apparently I'll have to add to my order, my poor painter..
Old 02-13-2008, 04:50 AM   #13
Zagar's Avatar
Let me ask this question here...
Where are you measuring the car to get the 190mm or 200mm that I see on these body listings? I measured my GT-One 1/10th at the wheels (outside to outside) and it's 8-3/4" or 222.25mm.
I would like to get some new bodies for this car, and I can't find anything close.
Zagar is offline   Reply With Quote
Old 02-13-2008, 08:27 AM   #14
And it's electric? the only thing close that I can think of is the nitro super ten class from years ago, kyosho and hpi had them I believe
Old 02-13-2008, 09:03 AM   #15
Zagar's Avatar
Yeah, it is an electric and from what I understand, it's about 10 years old.
Here is a link to the manual request I made for it with thumbnails:
http://www.rctech.net/forum/showthread.php?t=205628
Any thoughts of where to pick up bodies like that?
Asphalt '07! Arun Georgia Racing 196 08-08-2007 08:52 PM
1/12 for asphalt sampaio Electric Off-Road 1 05-13-2006 11:38 AM
Best body for asphalt is...... spanish armada Electric On-Road 17 11-04-2005 02:49 AM
Hot set-up for TC3 asphalt??? Dreamer Electric On-Road 2 05-10-2003 01:14 PM
Asphalt Onroad OVERTHEWALL Louisiana Racing Fourm 2 03-24-2003 05:00 PM
