Old 02-23-2008, 07:02 AM   #46
Trader Rating: 38 (100%+)
Originally Posted by Diggity View Post
You will need to use 2 - .030 shims to lift the brace so its flush with the PPD brace
What do you shim and what is flush? Do you provide the shims?
or8ital is offline   Reply With Quote
Old 02-23-2008, 11:39 AM   #47
Verndog's Avatar
Trader Rating: 16 (100%+)
[/INDENT]
All you need to do is put 2 3mm dia washer between the underside of the Diggity brace and the chassis where the hold down screw goes into the battery strap holder.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 02-23-2008, 03:49 PM   #48
Good deal. When will these be available to purchase. Im ready to send my money
Old 02-23-2008, 04:09 PM   #49
Diggity's Avatar
Trader Rating: 29 (100%+)
I will be listing the new offset brace that can be used with the PPD base plate tonight. I suppose its possible to sell them with the shims.. I will also be placing a link to the PPD base plate to use along with the CF brace!
Damon
www.rcamerica.com - www.teamxray.com - www.powerpushbatteries.com - www.teamscreamracing.com - www.fantomracing.com - www.kimbrough-products.com - www.diggitydesigns.com
Diggity is offline   Reply With Quote
Old 02-23-2008, 04:41 PM   #50
RAP66's Avatar
Unhappy
Damon
DANG!!! I just got mine...
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 02-23-2008, 04:49 PM   #51
Trader Rating: 139 (97%+)
Send a message via AIM to twistedone
is it safe to assume that you can run battery the other way also with pos and neg in front turn battery around 180 from how you have it ?
twistedone is offline   Reply With Quote
Old 02-23-2008, 04:52 PM   #52
Diggity's Avatar
Depending on which LIPO you are using, you will be ok with the original. The new one moves the battery pack .060 to the inside for the Trakpack and other LIPO's the have the plugs (positive and negative) more towards the inside of the pack...
Damon
Old 02-23-2008, 04:53 PM   #53
Diggity's Avatar
Gonna look at that option and post some pics in a little bit!
Damon
Old 02-23-2008, 06:09 PM   #54
nevermind.
Old 02-23-2008, 07:41 PM   #55
if it matters im running 3600 orion and 180 from how you have it
my thought's were slot the post area. so you can move it where you need it and then you could utilize all the org's you cut also.
might be wrong but I would like to get one and see if it was slotted if it would work that way
Old 02-23-2008, 07:44 PM   #56
Verndog's Avatar
I've got an Orion 3600 and cant see how you can ever get the 4mm plug in with the top deck right over the inside corner of the battery. Is there a reason you cant flip the battery the other way?
Not sure how slotting the post area would help. It's position is set by the screw location that is set in the chassis. You'd have to elongate the chassis screw hole which I wouldn't recommend.
---Team Hoarders---
Old 02-23-2008, 07:58 PM   #57
yea
Old 02-23-2008, 08:15 PM   #58
RAP66's Avatar
Damon
My pack is an Orion 4800, I may just off it and replace with a different brand.
Rich Pedro
[email protected]
www.rcracing.com
Old 02-23-2008, 08:29 PM   #59
Diggity's Avatar
I run the Orion 4800 pack as well, the stock brace should be fine? Have you installed it and checked it out yet?
Damon
Old 02-23-2008, 08:32 PM   #60
Diggity's Avatar
I dont think slotting the holes is the best option, as it could tweak in a wreck or hit and the pack and brace could move! I would recommend mounting the battery with your positive and negative plugs to the rear of the car. Not to mention shorter wires are better!
Damon
Diggity Designs 3200 mAh 20C Hard Case Lipo off-road Diggity Electric Off-Road 51 08-13-2008 04:51 PM
Diggity Designs 3200 mAh 20C hard case lipo Diggity Electric On-Road 75 08-12-2008 10:25 PM
WTB: diggity designs b44 lipo tray bgolat R/C Items: Wanted to Buy 2 04-17-2008 10:20 AM
Battery mounting on an Diggity RC18B vtracer Micro and Mini Scales 2 01-27-2008 01:05 PM
ask DIGGITY DESIGNS Apl Hed Electric On-Road 0 04-02-2004 04:33 AM
