Old 02-11-2008, 01:42 PM   #1
Cosmo's Avatar
Default Minimum size for track?
We are looking for a place to hold races here in town. While we'd love to have a huge track like some of the ones we've seen, that's not going to happen. Ours will have to be smaller. What is the minimum length and lane width that we should go for? I realize ROAR has specs on tracks, but we aren't going to hold sanctioned races or anything like that. Right now, there are no on-road tracks within a few hours of us, so not a lot of racers yet. This will be just for club racing. We want to run primarily electric 1/10.
Any suggestions would be greatly appreciated...
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 02-11-2008, 02:14 PM   #2
Well you may not be running sanctioned races but the specs ROAR uses are still good to go by. We run a 60' by 60' track where we keep a minimum of 8' track lane widths and a 10' preferred lane width. It's small but we have fun racing. The smallest we've run was 60' by 30'...it wasn't easy designing a track that small but it did work out. I wouldn't reccomend going with a track that small for normal racing. For us this is a special event track in conjunction with a local car show. Space is really limited there.
Old 02-11-2008, 04:19 PM   #3
adamge's Avatar
Strange that the guy in Hawaii ("space is really limited here", 190 ppl per square mile) thinks 60x60 is small. Where I live (pop density 4.5 ppl per square mile), we run a 36x60 track, and I think it is big enough for TC racing. Not ideal, but it works.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 02-11-2008, 04:30 PM   #4
Cosmo's Avatar
You wouldn't happen to have any photos of that track would you?
The parking lot I have is roughly that same size.
Old 02-11-2008, 05:11 PM   #5
Send a message via Skype™ to revolution31
Here is a pic of the 60x40 track where I live in Colorado.
The track is in a building with 3 small rooms, The big main room and an upstairs loft.
I think there are a couple pictures with a 1/10 TC on the track so you can see car::track ratio
Pic of the Track
Pics of pits/the track
revolution31 is offline   Reply With Quote
Old 02-11-2008, 05:12 PM   #6
If everyone is close to the same skill level then a track that small with more narrow lanes can work. But when there is a wide range of skill levels on the track at once anything less then a 8' lane tends to end up with a great deal of carnage. Our 60' by 30' track worked out but it was really tight for anything more then 6 TCs.
Old 02-11-2008, 05:22 PM   #7
That is a good point... 7 is the most we run, much more than that and lap traffic starts to cluster things up....
Old 02-11-2008, 05:33 PM   #8
Nice track. I could see 60 x 40 working out, especially for a permanent indoor track. The way I figure it you need 4 lanes width to do any kind of infield S turn and still maintain a straight. At 40' width you can have 4 10' lanes or even go down to an 8' lane to open up a bit more design creativity. At 30' you end up with 4 7.5' lanes which is pretty close to ROAR's minimum at 8'. For a setup like that I would make the straight a bit wider to maybe 9' or 10' and have the infield at 7'. Drivers tend to wander a good deal more on the straights then they do on the corners so it helps to have the straight a bit wider.
I'm not saying 60' by 30' is too small. Personally I'd put that at the limit though. If you have more space though...use it.
Old 02-11-2008, 05:59 PM   #9
adamge's Avatar
http://www.sarcarclub.com/Pictures.html
Pic 34 is a track we set up at a car show. I think it was about 36x55.
We are usually in the 6.8s range for a fast 19t lap, and 7.0 range for a fast 27t lap. Max we run is 5 per heat. Most often it is 3 and 4.
-Nietzsche
Track Size? rxmeador Micro and Mini Scales 5 04-26-2008 11:03 PM
Minimum size for track? Cosmo Electric On-Road 0 02-11-2008 01:39 PM
track size barry Micro and Mini Scales 7 12-24-2007 04:44 PM
1/8 on road track size cadguy Nitro On-Road 11 07-20-2007 10:09 PM
Building a Track/Size GearGuy2006 Electric On-Road 2 02-15-2006 09:14 PM
