Old 02-10-2008, 09:21 PM   #1
aussierevo's Avatar
Trader Rating: 14 (100%+)
Default Orion Element 19T V2 Spec Questions
I've been running the above motor in my TA05 at a FDR of around 7.2 to 7.5 (rollout of between 25 to 26.50 approx) on a flowing track with medium grip and rubber tires, and I'm very pleased with it so far, but would always like more from it.
I'm wondering if I could run this motor at even lower FDR of around 6.00 to 6.50......is this possible with this motor?
Also, I'm wanting to change the brushes, but unsure of what would be the best brush to use....want good performance, but do like something to last more then a handful of runs before having to change.
Any information would be appreciated
aussierevo is offline   Reply With Quote
Old 02-10-2008, 11:49 PM   #2
bigbutstupid's Avatar
i guess you can always try.
i run my komodo dragon pro spec 19t at FDR 5.7, i have to true the comms every 2 round and change the brushes every 3-5 rounds. i only do this during club racing.
if it's just for bashing or practicing, stick with your ratio. if want more power, u might want to look at a lower turn motor instead.
bigbutstupid is offline   Reply With Quote
Old 02-11-2008, 12:47 AM   #3
C_O_jones's Avatar
On a very large track I geared it up to a 5.14, try 5.6 and go from there.
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 02-11-2008, 04:53 PM   #4
aussierevo's Avatar
thanks for the info.....any suggestions for quality brushes to replace the existing ones?
Old 02-11-2008, 06:17 PM   #5
C_O_jones's Avatar
Sprint non serated brushes and the MR 10 coil springs, break them in for 300 seconds at 2V.
Bacon is Meat Candy
Orion V2 element motor oakesy2001uk Electric On-Road 16 04-28-2006 07:44 PM
would an orion element armature fit a orion core stock can? bionictony Electric On-Road 5 01-19-2006 10:32 AM
orion element ???'s Zac R Electric On-Road 12 12-18-2005 07:12 PM
Orion Element V2 19T micros_rock Electric On-Road 40 04-28-2005 09:15 PM
Orion 19T element Brian Miskolczi Electric Off-Road 4 02-17-2004 02:53 PM
