Old 03-06-2010, 09:20 AM   #1186
just bought one of these second hand, where can I download a parts list so I can order some spares
Bosscat is offline   Reply With Quote
Old 03-06-2010, 11:24 AM   #1187
V12
V12's Avatar
I think there is no parts list but you can find a manual here http://bmiracing.com/bmiv4/images/in...structions.pdf
Also at bmiracing.com there is a webshop where you can see all the BMI spares available.
V12 is offline   Reply With Quote
Old 03-07-2010, 05:28 AM   #1188
radio_car_racer's Avatar
see attachment
it's for the DB10R cars up until the flexplates change to long versions I believe
radio_car_racer is offline   Reply With Quote
Old 03-10-2010, 11:35 AM   #1189
ttso's Avatar
Since I saw DB12R thread....
Copperhead 10 photo needed
Last edited by ttso; 03-11-2010 at 12:33 AM. Reason: Just realize I wrote 12 instead of 10...;p
ttso is offline   Reply With Quote
Old 03-10-2010, 11:50 AM   #1190
protc3's Avatar
I will be assembling the Copperhead 10 tonight so i will post some pics here shortly.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-11-2010, 01:27 PM   #1191
protc3's Avatar
Here is a sneak peak of the new copperhead 10. I will have high quality pics shortly. Just want to give you guys a peak
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-11-2010, 02:09 PM   #1192
Interesting...I really like the new battery mount positions with the tape holes, that will make things much easier. Will the shock mount cross brace be aluminum like in the pic? I'm hoping for graphite. I like the thicker front bumper too.
Old 03-11-2010, 02:13 PM   #1193
2wdrive's Avatar
wow that looks really good. A lot less cutouts (almost non). More place to put the electronics and the chassis is stiffer. (sometimes i felt the db10rr was a little too flexy on carpet with a 2s 13.5t) It seems it takes 2s saddlepack in the middle? Is that lipo brace aluminium and if so why no carbon?
I see it has seperate plates under the front suspension? Is that for adjusting the width?
edit:
Just a note, could the bumper be made of kydex and not carbon. Carbon breaks after one hit. Less flashy but more practicle
2wdrive is offline   Reply With Quote
Old 03-11-2010, 02:18 PM   #1194
protc3's Avatar
Believe it or not, i made a graphite battery strap with an aluminum shock mount and it was actually heavier than the aluminum one. The aluminum one was also more rigid. The cool part about the battery strap is that it offers 6 mounting locations with 3 holes. If you flip it around, it offsets the shock length by half the center distance of the holes(puts the second set of holes centered between the others). Then you shim for verticle height. Very adjustable.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-11-2010, 02:22 PM   #1195
protc3's Avatar
The front allows for track width adjustment. A total of 8mm. The chassis is milled for 1S LiPo so you can run either down the center or across the chassis. You can run your electronics behind the battery, on the sides or in front. 2S will fit as long as you shim the battery plate up. We went with the more rigid chassis design and also narrowed the chassis up quite a bit.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-11-2010, 02:25 PM   #1196
protc3's Avatar
The bumper was beefed up alot as was the mounting. It is no longer just mounted by the screws and body post. 2 screws and lock nuts were added. The wall thickness is doubled also. We had absolutely none break in testing. I am very confident.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-11-2010, 02:32 PM   #1197
Is the new front end for the 12 going to work on the 10 as well?
Old 03-11-2010, 02:45 PM   #1198
JCarr's Avatar
Can I get a trade in on my old 10R?
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 03-11-2010, 02:57 PM   #1199
Uga
Uga's Avatar
Waiting for that new frontend to order my chassis.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 03-11-2010, 03:24 PM   #1200
protc3's Avatar
The new front end will fit both the 12 and 10 cars
Jason Breiner
BMI Racing
Team Associated
J Concepts
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
