Old 11-03-2009, 12:59 AM   #1141
I run a 9502 analogue version with no trouble even 4 cell mod on carpet.
Jason
jasonb is offline   Reply With Quote
Old 11-10-2009, 11:07 AM   #1142
Suspended
Hey guys were you able to get the body posts to fit snug? i couldnt get them to fit perfectly so i shimmed them and also if i hit a wall i rip one of the body posts off. anyone have a solution?
Miles1519 is offline   Reply With Quote
Old 11-10-2009, 12:29 PM   #1143
-showtime-'s Avatar
I've been using 5-40 screws in the body posts on my 1/12 instead of the smaller 4-40 ones that they come with. They thread right in and are much more secure. You may have to open the holes up in the chassis a little. Haven't stripped one out since going to the bigger screws.
Greg Dobrosky
Showtime Designs
BMI - Parma - The Raceway at Beaver, PA
-showtime- is offline   Reply With Quote
Old 11-10-2009, 01:04 PM   #1144
Likewise, although I have used M3 screws (actually Corally 15mm titanium ones - I had some!) to get the same effect. No problems with losing body posts since. HTH
SlowerOne is offline   Reply With Quote
Old 11-15-2009, 01:00 PM   #1145
2wdrive's Avatar
i need to replace the db10r flex plate as it is cracked (didn't break yet though) What flex plate do i have to use? I see
-DB3010 Flex Plates G10
- DB3010R Flex Plates G10
-DB3015 Flex Plates Thin G10
I gues i need the db3010R?
2wdrive is offline   Reply With Quote
Old 11-15-2009, 01:14 PM   #1146
The DB3010R are the stock flex plates. However new carbon fiber ones are coming soon so if you don't need them right away you may want to hold off for a bit.
Old 11-15-2009, 01:21 PM   #1147
2wdrive's Avatar
thanks, i need them right away, one flex plate cracked this saterday and next sunday i have a race
Old 11-17-2009, 01:37 PM   #1148
Does any one know what weight the silver center spring that comes with the DB10R kit is?
BIGBOT is offline   Reply With Quote
Old 11-17-2009, 01:56 PM   #1149
AOD
AOD's Avatar
I believe it's 14.5#'s
AOD is offline   Reply With Quote
Old 11-19-2009, 02:21 AM   #1150
2wdrive's Avatar
a question about the tweak screws. After a second time of driving my new db10r car i wanted to see what the tweak screws did. Are the tweak screws supose to go through the chasis brace without screwing them down? When i use the tweak screws i can't screw them in the carbon chasis brace as the hole is too big. I can only screw them in the flexplate? Is it suppose to be like that?
Old 11-19-2009, 03:55 AM   #1151
Uga
Uga's Avatar
I think those holes are ment only for screwdriver. You only have to remove the front two screws, which holds the plates to access them.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 11-19-2009, 05:07 AM   #1152
2wdrive's Avatar
ok thanks, i thought i had to screw them through the chassis brace to let them touch te flexplate. i already wonderd what that hole was in the flexplate but i understand now, screw the set screw through the flexplate and then let it touch the chasis.
Old 11-19-2009, 12:23 PM   #1153
The hole is larger on the brace so you can fit an allen wrench through there to adjust the tweak screws. The tweak screws thread into the L plates until they just touch down on the chassis. Once you get them set there you can adjust tweak pretty much like a t-bar car.
Old 11-23-2009, 09:05 AM   #1154
hi all,
Just picked up a DB10R and was wondering about springs.
I've gone through the thread (77 pages !) and saw one or two posts about using TC springs (which is good as I have a few of them)
Which springs are people using in terms of lb ?
CPD Racing
chris_dono is offline   Reply With Quote
Old 11-23-2009, 10:03 AM   #1155
V12
V12's Avatar
The stock spring for the center shock is an AE 14.5 lb spring what has worked for me very good until now so no need for anything other. Maybe Iīm trying a slightly harder spring next time indoors. But anyway I donīt think you will need a large assortment of springs.
V12 is offline   Reply With Quote
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
