Old 10-18-2009, 09:26 PM   #1111
The reason for reaming the steering block for the king pin is because sometimes in a hard impact the king pin will get pushed up and if it is tight it will get stuck that way and cause tweak in the front end as the spring will have pre-load. If it moves smoothly then it won't get stuck.
Old 10-19-2009, 12:12 AM   #1112
2wdrive's Avatar
Thanks for explaining.
2wdrive is offline   Reply With Quote
Old 10-21-2009, 07:08 PM   #1113
MaxSp97's Avatar
Here is my 10RR battery holder for 1S Lipo.
BMI DB10R!!!-dsc00557.jpg   BMI DB10R!!!-dsc00563.jpg   BMI DB10R!!!-dsc00564.jpg
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 10-21-2009, 09:52 PM   #1114
Hey guys what should my front track width be? I know the rear is 200mm just not shure about the front. I am running jaco world gt lilac tires.
Thanks for your help
BIGBOT is offline   Reply With Quote
Old 10-22-2009, 03:46 AM   #1115
Default BMI DB10RR
Hi, looking for new or good used BMI DB10RR. Just drop pm or mail [email protected]
Thanks!
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 10-22-2009, 06:59 AM   #1116
t4mania's Avatar
Hey Jason I know you used to run a TC3 touring car with the BMI double deck chassis. I have one with this chassis & was wondering if you had any tips on setup for carpet & asphalt including tires. Thanks
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 10-24-2009, 03:34 AM   #1117
Default ESC
Hi,
I know that many are using Tekin RS ESC in DB10R. What do you think about new Mamba Max Pro 1/10th Sensored & Sensorless ESC? Maybe some one is using that ESC? Does it fit in DB10R? Any other ESC to go with?
Audrius
Old 10-24-2009, 07:14 AM   #1118
Uga
Uga's Avatar
If money is not an issue then just get the Tekin, seriously, it's the best stuff out there. Evaldas in Lithuania has both BMI kits and Tekin brushless stuff, I can give you his contacts in PM if you don't know the guy.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 10-24-2009, 07:44 AM   #1119
Hi Uga,
yep, I know him... :-) and get in this tread only with Lokanas help :-) I was thinking about CRC Gen-X 10...
But money is issue... At the moment I am off road racer and do not know if I will love on road :-) Also would like to get two kits. My son is racing to! You know, full racing kits will cost me not small amount :-) So now looking how to cut costs a little bit... Also, have niece in USA. She can help me buy and bring stuff in...
Audrius
Old 10-24-2009, 05:15 PM   #1120
Send a message via ICQ to markrichards Send a message via AIM to markrichards Send a message via MSN to markrichards
Default mid corner grip roll
as the title says. I get grip roll at the mid part of a corner. Carpet racing. I am using the world spec tyres ( purple banded ) I am not sure how to cure this as I dont want to just change tyres to any other combo of non spec type. Meaning no double pink this, or grey that. I have used the carbon effect spec tyres, but i generally get the same result. Not as bad though.
I'm running a 1 cell lipo, the car is set as this;
front
.016 springs
5 degree block
shim 1 forward 1 back
1 degree camber
0.5 toe out
sides.
standard flex plates
mounting hole front
50k side goop
centre
silver spring
40 wt oil
ride height down to 4mm
I've run kit front springs but, with lipo and the lack off weight ment i got very bad understeer. The 0.16 springs gives me great turn in now.
I had the grip roll with standard kit springs too.
markrichards is offline   Reply With Quote
Old 10-24-2009, 07:03 PM   #1121
Unfortunately the ride height rules for WGT really bite you in the butt on carpet and when the grip is high the rolling starts. Guys at IIC were truing their tires almost down the the rims and CA'ing the tire sidewalls to keep that from happening. Have you tried that yet?
Old 10-25-2009, 02:26 AM   #1122
yes. delayed the roll, but it still happened towards the end. I'm not sure we have or rather use rules much over here, so the minimum ride height is whatever doesnt rub the chassis on the carpet
Old 10-25-2009, 03:38 AM   #1123
What's your ride height then? You'll want about 3.5mm
Old 10-25-2009, 05:27 AM   #1124
i posted the setup a few messages back
Old 10-25-2009, 12:37 PM   #1125
radio_car_racer's Avatar
Mark Richards
how much addy are you using on the fronts?
radio_car_racer is offline   Reply With Quote
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
