Old 07-16-2009, 07:09 AM   #946
avs
avs's Avatar
Originally Posted by protc3 View Post
You want to use the short shock mounting position and the 2 hole piston. No glue on the tires either.
Ok, thanks. So all the glue application schemes is a 1/12 scale only thing.
avs is offline   Reply With Quote
Old 07-16-2009, 09:20 AM   #947
protc3's Avatar
I only resort to glue if the traction is super high. I havent had any traction roll issues otherwise that couldnt be tuned out through setup
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-17-2009, 03:35 AM   #948
V12
V12's Avatar
well I think of trying a WGT car and going with a DB10R now also. I just think if converting my DB12RR makes sense or going with a new kit. I think I have a lot of stuff from the wide pancars laying around here also, maybe I could use some pieces from them beside the required graphite parts. What wide is the left hub from the rear axle on the DB10R?
Is there a foam bumper from BMI for the DB10R or is there any other what will work for the DB10R?
Jason, I have some special questions. It seems I have problems with private messages sometimes. What emailaddress should I use for contacting you?
V12 is offline   Reply With Quote
Old 07-17-2009, 03:56 AM   #949
Xtant3150c's Avatar
I think you still might come out ahead by just buying a DB10RR kit rather then converting.
Still wouldn't mind seeing a nicely priced conversion kit for the DB12R/RR to DB10R/RR status
space for rent
Xtant3150c is offline   Reply With Quote
Old 07-17-2009, 02:51 PM   #950
avs
avs's Avatar
buying a 2nd kit is a great way to buy spares. i don't see that much that is redundant that isn't also a potential replacement item for either car.
Old 07-17-2009, 02:52 PM   #951
avs
avs's Avatar
ok i will start there, hopefully this weekend!!
Old 07-19-2009, 06:18 AM   #952
protc3's Avatar
I got a chance to run 1S lipo this weekend and must say, i love it. The car runs excellent with the 1S and didnt really require any setup changes. The BMI cars hit the fastest laps of the day and took TQ by over a lap and won the main. The car worked extremely well.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-20-2009, 07:54 AM   #953
avs
avs's Avatar
I was just wondering how you mounted the battery? the retention plate height is fine, but the front shock mounting stud retaining nut interferes with a lipo battery. is there a trick? seems like i need to add about 3/16" shim under the supports and then some foam rubber or some kind of cushioning to fill the gap?
Old 07-20-2009, 08:00 AM   #954
JCarr's Avatar
I'm having the exact same problem. I haven't run my car in a while because I got tired of messing with round cells. A fellow racer loaned me his single cell, but I ran into this issue. Also, Jason are you running the 0* blocks and shims in the back for outdoor or in indoor carpet?
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 07-20-2009, 10:35 AM   #955
AOD
AOD's Avatar
Jason could you post your setup and picture of your cars electrics layout. Sorry but I'm kind of a monkey see monkey do type of person.
AOD is offline   Reply With Quote
Old 07-20-2009, 10:39 AM   #956
protc3's Avatar
I taped the battery in and did not use the weighted tray. The weighted tray would have made me over weight. With the lipo and race ready with no weight i was at 870 grams. I had to add some weight to get to the 930 to be legal.I took a battery locator plate and clipped it in 1/2 and flipped it around and used it as a front stop for the pack. Battery never moved. I will snap some pics and post my setup. The car was simply amazing. I was very happy with it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-20-2009, 10:41 AM   #957
protc3's Avatar
The weighted tray is for use with 7.4 volt lipo to help keep the car controllable. Single cell doesnt need it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-20-2009, 12:16 PM   #958
Ah...that being the case we probably don't need the 2 that I put in my latest order for IIC, I believe that will be a 1 cell LiPo race in WGT. Let me know if I'm not right.
Old 07-20-2009, 01:12 PM   #959
protc3's Avatar
That is correct. You will need to add weight but not the full weight of our lipo tray. I am going to make a lighter one for 1s lipo shortly
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 07-20-2009, 01:59 PM   #960
Cool...Will it be out in time for IIC?
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
