Old 02-02-2009, 08:28 PM   #826
protc3's Avatar
Originally Posted by Johnny Wishbone View Post
Jason B, what are the chances of Jason S posting his setup from the snowbirds on here?
Thanks Johnny Carey got you pm.
I will have him post it this week.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 02-05-2009, 08:55 AM   #827
AdrianM's Avatar
Free shipping on all orders in February from www.bmiracing.com!
Adrian Martinez
Old 02-05-2009, 09:59 AM   #828
ttso's Avatar
International order included?
(damnit we don't have WGT class yet..)
ttso is offline   Reply With Quote
Old 02-10-2009, 09:22 AM   #829
Johnny Wishbone's Avatar
Jason B, can you ask Jason S if he had a chance to open his trunk and get the setup off his car from the Birds yet??
Old 02-10-2009, 09:29 AM   #830
protc3's Avatar
I will call and ask him tonight.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-10-2009, 09:57 AM   #831
Trader Rating: 15 (100%+)
Default rear pod
Whats the difference in the rear pods? Were they a running change and when were they phased in ?Just wondeering if i have to order one while the stimulus package is offered.
AARON YOUNG is offline   Reply With Quote
Old 02-10-2009, 11:37 AM   #832
schreff's Avatar
Send a message via AIM to schreff
I'll work on that setup tonight guys. Yes, that's right, I finally emptied the trunk out of my car. Only took a week.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 02-10-2009, 01:52 PM   #833
protc3's Avatar
The new rear pod is widened for brushless motors and centers the weight of the brushless motor. The diff hub that it comes with is offset so you can run 2mm of shims per side and achieve a 200mm track width. It comes with a new battery hold down plate also as we move the shock back to put the upper pivot inline with the center pivot.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-10-2009, 03:36 PM   #834
schreff's Avatar
Default Birds' Setup
Hey fellas...
Here's my Birds' setup in a nutshell.
-Front End-
-BMI #4 ride height spacers
-0 degree caster blocks
-6 degrees caster
-associated .020 10th scale springs with .020 spring sag
-#3 sure lube on pins
-servo angled and in lower holes in servo mounts
-BSR handout tires cut to 2.08"
-Middle-
-Battery all the way back
-2.5 ounces of lead right in front of battery (to make race weight)
-50 wt Losi oil w/ #3 piston in center shock with Associated Blue touring spring
-Rear-
-#3 surelube in tubes
-.065 black side plates in long position with tweak screws just barely touching chassis
-0 axle bearing carriers
-BSR Handout tires cut to 2.08"
-2mm BMI rear width spacers
Gearing was 100/35 with a Losi Xcelorin 13.5 motor. It coulda used another tooth or 2 in the main as it was cold after the race and needed just a tick more straight line speed.
I used all the updated parts that Jason just mentioned as well. It was almost an identical setup to my 12th scale car with only the front caster blocks really being different. Kinda cool the cars were that close together in setup.
Body was a Protoform Sophia and I used the new outer holes on the cross brace for body mounting. It really stiffened the body roll up.
Keep in mind this was only my 2nd week on the car WGT car. The next time out, I will be running a new Parma DB9 body, which looks really trick. Looks like the Grand Slam event in Maryland will be the next race out for the WGT car.
-Jason Schreffler-
Old 02-12-2009, 11:39 AM   #835
protc3's Avatar
Thanks schreff. The car really worked awesome with that setup.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 02-12-2009, 03:03 PM   #836
Uga
Uga's Avatar
a quick question: what size spur comes with DB10R kits?
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 02-12-2009, 03:59 PM   #837
Trader Rating: 8 (90%+)
100t/64p
Johnny Carey is offline   Reply With Quote
Old 02-12-2009, 08:24 PM   #838
Are either you or Adrian coming to the state race in Kissimmee. If You can't make it on saturday there is always sunday with two qualifier and the mains.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 02-16-2009, 10:21 AM   #839
Richter Cells's Avatar
Anyone tried using the IP4200 saddle pack trinity is promoting yet?
According to Trinity it's dimensions are 69 x 46 x 23.
It appears that this might fit under the upper deck without spacers.
The guys at the local track here all run CRC's with 21.5's and Lipo's and can't keep up with my 13.5 4cell so they are having the rules changed so I have to run lipo and I am trying to find a hard case pack that fits with minimal modifications.
Richter Cells is offline   Reply With Quote
Old 03-01-2009, 12:21 PM   #840
sportpak's Avatar
Trader Rating: 26 (100%+)
C'mon guys, this thread has been quiet too long....
I am real close to ordering a DB10 from Stormers; however, I am worried about getting an old kit with the narrow pod. What are the chances of Stormers having the "RR" spec brushless pod DB10?
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
