Old 01-26-2009, 11:57 AM   #796
Johnny Wishbone's Avatar
Default Johnny C???
Johnny C, what do the second holes for the dampner tubes do? I have 2 sets of holes, just behind the pod mount for the shock.
Another ?, on your last setup how much if any of the tires are you doping? And with what if used? Are cutting the widthe of the rear tire down ?
Old 01-26-2009, 12:32 PM   #797
Trader Rating: 8 (90%+)
Im not actually sure what moving the damper tubes forward or back does.
The last setup, I was running 1/3-1/2 front and full rear, with Jack. With the stock width tire. Our club racing gets about 12 full heats and we have really really good consistant traction.
Johnny Carey is offline   Reply With Quote
Old 01-26-2009, 08:59 PM   #798
Richter Cells's Avatar
Default More Steering
Jason,
Thanks for the help with the traction roll problems. The smaller tire diameter and gluing the outside edges solved the problem except for an occasional bicycle through one corner.
I only need 1 more thing to get the car perfect. More Steering!!!
Which change do you think would offer more steering 5 degree front blocks or moving the battery forward?
Right now the car has 10 degree blocks (1 front and 1 rear shim) battery centered.
Richter Cells is offline   Reply With Quote
Old 01-26-2009, 09:05 PM   #799
I would make 3 changes. Move the battery forward one notch, 5deg block, both shims back.
Old 01-26-2009, 09:11 PM   #800
Of these three changes you recommended which one would offer the most benefit.
I don't like to make this many changes at one time without knowing which one solves the problem.
Old 01-27-2009, 04:14 AM   #801
protc3's Avatar
Another thing i found is that the car gains steering when you increase camber. I run 2-2.5 degrees of camber and the car steers great.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-27-2009, 04:14 AM   #802
protc3's Avatar
I also run the 5 degree blocks as Johnny mentioned.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-27-2009, 09:12 PM   #803
skypilot's Avatar
Trader Rating: 14 (100%+)
any idea when that battery plate will ship??
Ritchie
semi retired..
skypilot is offline   Reply With Quote
Old 01-28-2009, 07:27 AM   #804
protc3's Avatar
Ritchie
Can you please refresh my memory. I think im losing it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-28-2009, 10:30 AM   #805
skypilot's Avatar
my order on invoice number 354765, I ordered a DBB1102
DB10RR Rear Pod Conversion Kit. it didn't come with the battery plate.
semi retired..
Old 01-28-2009, 11:44 AM   #806
axle182's Avatar
Trader Rating: 18 (100%+)
Send a message via MSN to axle182
Listen ive heard the DB10R isnt a very good car, so if anyone has heard the same, Ill buy it....im looking for one second hand........
Seems no one wants to let these things go Im loving my DB12r and had a drive of a WGT DB10R and loved it. Very nice car.
axle182 is offline   Reply With Quote
Old 01-28-2009, 12:36 PM   #807
You should have bought Gregs, its a bottom sucker . Good luck finding one though.
Old 01-28-2009, 12:37 PM   #808
protc3's Avatar
Ah i see. Please pm me your shipping info and i will get it out to you. Sorry about that.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-28-2009, 12:38 PM   #809
protc3's Avatar
Thanks buddy. Im glad you enjoyed the car. Thanks for the compliments.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-28-2009, 04:40 PM   #810
protc3's Avatar
Jason Schreffler is looking good at the snowbirds right now with his DB10R. This is his 2nd time running the car and is still getting things figured out and is top 3 so far for practice. Should be great once he gets situated and gets the final adjutments made. Jason and Larry are also on A main pace with the new DB12RR also. Its nice to finally have the car in the hands of a team driver at a big race.
Jason Breiner
BMI Racing
Team Associated
J Concepts
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
