Old 01-16-2009, 03:09 AM   #781
islander360's Avatar
Trader Rating: 42 (100%+)
Send a message via AIM to islander360
I'll be there.
Originally Posted by BullFrog View Post
Are any of you racing this weekend at the state race in you area (Tampa)?
JConcepts - BMI Racing - Speed Passion - KustomRCGraphics - Core R/C
islander360 is offline   Reply With Quote
Old 01-16-2009, 12:01 PM   #782
Uga
Uga's Avatar
Originally Posted by protc3 View Post
The car doesnt come with the weighted lipo tray. We offer that as an option along with a tall lipo battery hold down. The tray fits a maxamps 4000 mah saddle pack with no problem. The SMC and TrackPower saddle will require the tall lipo mounting kit.
Where can I see the tall lipo mounting kit? I don't see it on the webshop.
And another question - when is the new brushless pod going to be included in the kit?
We are investigating the World GT class around here and considering going for it. We will be running on asphalt, as we lost our permanent track we will be most likely back to parking lots. The main idea is that it has to be faster than 13.5+5cell TC and slower than 1/10 nitro TC. Can 10.5T+4cell be compared to 13.5+lipo?
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 01-16-2009, 12:04 PM   #783
Trader Rating: 8 (90%+)
The brushless pod is being included in all of the recent kits.
Johnny Carey is offline   Reply With Quote
Old 01-16-2009, 12:11 PM   #784
Uga
Uga's Avatar
Oh, that's great! I probably misunderstood as I see in the shop DB10R chasis and DB10RR conversion kit seperately.
-=Xray XB4=-
-=Xray XB8E=-
Racing in Latvia
Old 01-16-2009, 12:39 PM   #785
You are correct, how they are seperated. But I am 99.9% sure that the new DB10r kits are coming with the updated pods, longer flex plates, and shorter diff hub. Im sure Jason will chime in if I am wrong.
Old 01-20-2009, 08:41 AM   #786
Richter Cells's Avatar
Default Gearing??
Jason, I thought I read earlier in this thread that you were recommending a 52 mm rollout for 2.2 inch tires, 13.5, and 4 cells.
When I raced the car for the first time last Sunday I found that I was so far off the pace that I needed to gear up.
I went all the way to a 68mm rollout before I was even competitive.
Does this sound normal?
Also is gluing the sidewalls of the fronts the only way to reduce traction rolls?
Other than these 2 small issues I finished third in the A-main behind 2 pro's driving CRC's with 7.4 lipo's on the cars maiden voyage with out of the box setup.
Richter Cells is offline   Reply With Quote
Old 01-20-2009, 09:06 AM   #787
In the UK stock is 10.5 we roll out at 58-60mm so I think you are about right for 13.5
Jason
jasonb is offline   Reply With Quote
Old 01-20-2009, 09:28 AM   #788
protc3's Avatar
I geared mine at a 65mm rollout with a 13.5 and the car was fast. I would check your speedo settings. It will be difficult to match the punch of a car running 7.4 volt lipo just due to the fact that it is more voltage and a higher torque motor.
On carpet i never run my tires taller than 2.100. If the traction is high,hack down those tires. This will cure the traction roll issues.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-20-2009, 11:30 AM   #789
JCarr's Avatar
I finally got back out to run my 10r this weekend. I want to say thanks to Jason for helping me out with my pod issues as it seems that was what my problem was. The car was back to it great handling self, I was just down on power a little bit to the other guys. I really enjoy driving this car, it really a relaxing drive.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 01-20-2009, 11:54 AM   #790
Johnny Wishbone's Avatar
Jason, just wanted to let you know that I finally got to run the car and it worked very well on carpet using Johnny Careys setup, I managed to TQ the WGT at the WCIC races this weekend and if not for a tire dopping error on my part in the final the car was dead on for another great run.
Nice car, easy to drive, easy to work on. As a matter of fact tire wear was exceptional and even all around all weekend, so no tire truing issues, and was actually kind of boring to have as no tweak settings where required either.
Old 01-21-2009, 12:01 AM   #791
Thats good to hear-
What I have found with that setup, is that the car will get faster as the day goes on and traction goes up. Just silly good.
Old 01-23-2009, 06:41 AM   #792
slakr's Avatar
Trader Rating: 31 (100%+)
Does the BMI weighted LiPo tray fit the SMC single cell LiPo?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 01-23-2009, 07:10 AM   #793
protc3's Avatar
It does fit in the tray but the battery hold down will need to be spaced up. I will be releasing an optional tall battery holddown for the SMC pack soon but you can do it if you space the top plate up. The pack fits the tray though
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-26-2009, 11:34 AM   #794
This is the setup I ended with yesterday. Very quick transitioning car. Couple of chicanes on a tight high traction Carpet track.
4.25mm ride height
10* Castor
Both Shims Back
-1.5* Camber
CRC Blue lube
Servo Flat
Jaco Wheel
Batts in the middle
Shock back hole
60wt oil, 3 hole piston
1mm pod droop
17.5lb spring
Thick plates, short mount
Red Sure Lube in tubes
Tweak screws touching
Axle at 200mm
4.5mm ride height
4.2 split ride height
Jaco Wheel
Sophia Body
Old 01-26-2009, 11:46 AM   #795
Jamesalex's Avatar
Questions??
Just a quick question does anyone know if the IRS left rear hub on the DB10R is balanced the same and would the RC10R5 axle?
Jamesalex is offline   Reply With Quote
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
