Old 11-09-2008, 10:25 PM   #706
Trader Rating: 37 (100%+)
Jason,
"Standard flex plates with no set screws installed"
I saw where you posted this in your set up. Standard is thick ones correct? What would thin ones do? Fairly High traction Ozite, IIC RULES with the Vette Body but we run 104mm body height and 17.5 motors.
looking for a little more steering mid corner off ?
Thanks,
Steve Crane
East texas RC Raceway
4TH Annual Fall Cla$$ic: Mike's Hobby Shop November 12-14, 2010 www.easttexasrc.com www.mikeshobbyshop.com 17.5 Rubber Sedan, 13.5 Rubber Sedan, 17.5 1/12TH, 13.5 1/12TH, WORLD GT, stock sedan and SLASH
EXPRESS MOTORSPORTS : SCHUMACHER MI3 : ASSOCIATED 12R5 : ASSOCIATED 10R5 : TAMIYA TT 01 : LOSI XXXT-CR : LOSI BK : TRAXXAS SLASH : LOSI SLIDER : CUSTOM WORKS OUTLAW
steve crane is offline   Reply With Quote
Old 11-10-2008, 08:59 AM   #707
protc3's Avatar
The thin flex plates actually mellow the car out. The stock plates are the thicker ones. Try running the 5 degree castor block with 4 degrees of castor and 2 degrees of camber.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-15-2008, 10:52 PM   #708
Jason
Are there any setups on your site or any where else for the DB10R I saw 2 and a blank sheet for the DB12R on your site but did not see any for the DB10R? (I race asphalt)
BIGBOT is offline   Reply With Quote
Old 11-16-2008, 02:57 AM   #709
Richter Cells's Avatar
Jason I just received my new DB10R and during the build I have run into a strange problem. When I go to mount the servo mounts to the chassis the screws bottom out in the mount before the mount is clamped to the chassis. Have you ever had this problem in the past? Is there something I am doing wrong? Am I the only person that has had this problem? It appears that the countersink in the chassis is too deep.
Any suggestions?
Richter Cells is offline   Reply With Quote
Old 11-16-2008, 06:51 AM   #710
protc3's Avatar
Originally Posted by BIGBOT View Post
Jason
I will try to get my setup on there on monday for you
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-16-2008, 06:54 AM   #711
protc3's Avatar
Any suggestions?
Actually, i had that happen 1 other time. If you have a countersink, you can enlarge the countersink on the threaded holes in the servo mount just a little so the screws dont bottom out. The thickness on the material is very close to the depth of the countersink in the chassis. If you need any assistance or have problems while doing this just let me know.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-16-2008, 10:52 AM   #712
Jason - I tried the countersink idea but was not happy with the results. The countersink had to be cut quite a ways into the servo mount before the screw heads would grab the chassis and then there was only about 1 thread holding in the mount. I finally had to open the hole in the servo mount to a clearance hole for the 4-40 screw and put a nut on the top side. I am still a little concearned about the holding strength of the screw head considering that the head of the screw is not far from breaking through the chassis.
My only other thought is to drill and tap the servo mount for a 6-32 screw that has a larger head to see if this works better. Maybe the larger head will grab more of the chassis.
I am not sure this is the correct fix but it is my last resort to solve this problem. I was really looking forward to racing this car today but had to postpone my racing until I got this problem worked out.
Old 11-16-2008, 10:57 AM   #713
protc3's Avatar
Do not tap 6-32. The head angle is 82 degrees on imperial screws and that diameter of a head will not work on 2.5mm carbon fiber. Send me your address and i will send you a new set of servo mounts that will work.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-16-2008, 10:58 AM   #714
protc3's Avatar
nice vette in your avitar. Is that yours? If so post a good pic so i can check it out. I love vettes. Im on my 4th one now.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-16-2008, 11:07 AM   #715
Thanks for the help Jason. I will send my address to your direct e-mail account.
As far as the vette goes Yes that is a picture of my 2003 C5. I is my fifth and I have to say it is the best one I have ever had.
Old 11-16-2008, 01:22 PM   #716
protc3's Avatar
Very Nice !!! I love the yellow!! I had an 04 commemoritive edition convertible. The C5 is awesome. I went to the C6 in 06 and have had it ever since. Here is a pic.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-19-2008, 12:44 PM   #717
protc3's Avatar
Hey Guys,
I wanted to let you know that i am working on making a brushless optimized rear pod that will be similar to the one on the new DB12RR. I am working on the hubs now and i will post a pic by tommorow or friday
The upgrade will consist of the upper and lower pod plate, diff hub and pod tube brace.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-19-2008, 01:03 PM   #718
Jason,
Is the pod availiable for the DB12R yet?
If so how do I go about ordering it?
Also any idea on when this will be completed for the DB10R?
Old 11-19-2008, 01:18 PM   #719
protc3's Avatar
The pod will be available at the end of this week also. Both use the same parts with exception to the hub. They are different.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-20-2008, 02:16 PM   #720
Jason
Is there a list of hobby stores that carry your products and kits I know STORMER HOBBIES does but are there any others?
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
