Old 11-02-2008, 08:06 PM   #691
Wall Banger's Avatar
Jason could you please post a carpet setup for lilac tires or any carpet setup
Wall Banger is offline   Reply With Quote
Old 11-03-2008, 06:31 AM   #692
Fastforward's Avatar
Default LiPo
Jason - can you confirm that the SMC LiPo saddle pack will fit in the lipo tray?
Dimensions are:
length = 2.655
Width = 1.790
Tall = 1.025
Bob DeGood
AKA Big Bad Bob
AKA BBB
Fastforward is offline   Reply With Quote
Old 11-03-2008, 07:59 AM   #693
protc3's Avatar
The SMC lipo is sitting in my car right now. It does require a tall battery mounting kit that i am working on. I will shoot some pics and post them today. I will have the mounting kit ready in about a week.
Here is my carpet setup.
Here is what i run on my 10R
Front:
5 degree castor blocks with shims centered on upper arm(4 degree castor)
.020 linear front springs
5000 wt. diff oil on the kingpins
4mm ride height and .5mm front droop
2 degrees camber
0 toe
servo on angled mount
2X pink front tires cut to 2.100
Rear:
Standard flex plates with no set screws installed
10,000 wt in tubes
silver(stock center spring)
35 wt. oil in shock
batteries in back position
1mm pod droop
2X pink rear tires cut to 2.100
4mm ride height
I used a C6 corvette body and i sauced the full rear tire and 1/2 the inside front. The Lilac tires shouldnt make the setup much different. I would start here and see how it goes.
Thanks,
Jason
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 11-03-2008, 08:05 AM   #694
Thanks Jason
When running Lilac all the way around I have found that I need to sauce about 3/4 of the front tire. That may be the tuning option depending on local track conditions.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Old 11-03-2008, 08:10 AM   #695
Jason Thanks for the setup
Old 11-03-2008, 08:10 AM   #696
Jason - what are the shur lube equals for 5000wt and 10000wt diff lubes?
FastForward - The kit works well all you need is a very thin peice of foam to keep the battery from moving around in the tray.
Lee Schultz
Founding Member of CORRC
www.OnRoadColorado.com
LeeS is offline   Reply With Quote
Old 11-03-2008, 08:40 AM   #697
protc3's Avatar
5000 is probable #2 and 10000 is about #3
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-04-2008, 08:49 AM   #698
JCarr's Avatar
I had the car out last night for some carpet time and made the adjustments to try and get rid of it carrying the inside front tire through a corner. It was better, but was still doing it. My ride height is at 5.5 rear and 5 front, it looks like the rear of the chassis/front of the pod has been dragging. I'm not sure how ling that has been going on, I just noticed it last night. What am I doing wrong here?
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 11-04-2008, 09:02 AM   #699
protc3's Avatar
I would take your front springs off and make sure the front end is not binding. Next, make sure that the pod is level at ride height. Check all 4 corners of the pod. Once you have this all taken care of, Check to make sure you have some pod droop. You want about 1-1.5mm of uptravel over ride height.
What are you using for side dampening?
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-04-2008, 09:09 AM   #700
I didn't see where you mentioned your tire sizes. They need to be down around 2.15 front and rear.
Bob DeGood
AKA Big Bad Bob
AKA BBB
Old 11-04-2008, 09:11 AM   #701
JCarr's Avatar
Looking at the car sitting at ride height on a tweak board with my calibrated eyeball the pod looks to be level. I had 10,000wt in the tubes at first but went up to 35,000 just as a test. I was curiouse how exactly to set rear pod droop. I had moved the shock from the front mounting hole to the rear and did not see a whole lot of change. I made the shock longer to add some droop, but do not know how to measure the droop on the pod. I will check the front end tonight also, but it does not seem to be binding.
Gorilla Size Racing
Old 11-04-2008, 04:16 PM   #702
Swampracer's Avatar
Trader Rating: 69 (99%+)
Jason, please check your PM'S. Thanks
Swampracer is offline   Reply With Quote
Old 11-07-2008, 07:22 AM   #703
JCarr's Avatar
What's the best way to go about setting rear pod droop? I'm gonna be at the track this sunday and want to try and have the car pretty much set before I get there. I hope I can get this problem figured out I had a blast with this car outside, but on carpet it's killin me.
Gorilla Size Racing
Old 11-07-2008, 08:36 AM   #704
protc3's Avatar
The way to check and set pod droop is like this:
Set your ride height 1st and set the pod to level at all 4 corners of the pod. I do this by using a ride height guage and checking the 4 corners of the pod and making them all the same by adjusting the spring collar. use my setting from the set up i posted on here. Now you want to take your ride height guage and make sure it is 4mm at the back of the chassis plate(either side). Now lift the car by the top pod pivot ball area until you feel the shock piston bottom out in the body just before the wheels leave the ground. With this lifted recheck the ride height. The difference between the ride height and ride height while lifted is your amount of pod droop. I like it to be about 1-1.5 mm.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 11-07-2008, 09:00 AM   #705
JCarr's Avatar
Thanks Jason, I will see how it goes tonight.
Gorilla Size Racing
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
