Old 10-13-2008, 12:32 PM   #616
RPage's Avatar
Originally Posted by s13evo View Post
whats Spur/Gear combo are you using or would use for a 13.5 BL novak?
The last time I ran my DB10R on asphalt with a Novak 13.5, the rollout was around 68 mmpr with 56 mm tires. 88 spur/34 pinion
RPage is offline   Reply With Quote
Old 10-13-2008, 05:57 PM   #617
s13evo's Avatar
cool ill try that out. thanks.
oh was this setup fast enough for big tracks?
s13evo is offline   Reply With Quote
Old 10-13-2008, 10:04 PM   #618
RPage's Avatar
My local track size is around 70x40 and motor came off at 150, running a 4 cell pack. I started at about 62 mmpr rollout and went up in gearing to get the speed and punch I wanted while maintaing a reasonable motor temp.
There are too many factors involved in determining the correct gearing to say whether that gearing would work or not on a larger track. If you are running a 4 cell pack, you could start with that gearing and go from there.
Old 10-14-2008, 12:08 AM   #619
ffactory666's Avatar
Trader Rating: 19 (100%+)
Originally Posted by protc3 View Post
I just checked and the SMC hard case saddle pack lipo will fit our car with the weighted tray. It will just require a tall cell mounting kit which will consist of 3 standoffs and a tall ballstud.
Jason do you have this mounting kit available or soon to be available . I will also be running the SMC saddle pack and weighted tray .
ffactory666 is offline   Reply With Quote
Old 10-14-2008, 01:36 AM   #620
protc3's Avatar
I will have them ready this week
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 10-17-2008, 03:46 PM   #621
Here might be tricky one for you Jason .
I am turning the 10R into a record 2 cell speed run car . I am starting off with the Orion 2.5t brushless motor which has 13800kv to get use to a speed car and to fine tune it so it doesn't fly off the road
Then i'll upgrade the motor to a faster one
With the 48p 72T spur i have what pinion range should i look at ?
By the way here are a few pics of the custom painted LMP body i will be using .
BMI DB10R!!!-2008_1010miscpics10080001.jpg   BMI DB10R!!!-2008_1010miscpics10080003.jpg   BMI DB10R!!!-2008_1010miscpics10080007.jpg
Old 10-17-2008, 09:00 PM   #622
JayBee's Avatar
Trader Rating: 31 (100%+)
Just got mine today Jason Now I'm off to buildin'
Thanks again
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-18-2008, 02:49 AM   #623
V12
V12's Avatar
2.5T on a 7.4V Lipo??? Hmm, you´re sure you have an ESC and Lipo what could handle this? Also a 72T gear? Don´t know how this should work.
V12 is offline   Reply With Quote
Old 10-18-2008, 06:05 AM   #624
s13evo's Avatar
does anyone know if i can use NOVAK's 1/12th scale brushless motor gearing chart for the 1/10th DB10R?? or is the the 1/12th scale gearing totally different compared to 1/10th?
Old 10-22-2008, 07:57 AM   #625
JCarr's Avatar
Well, I got my order Tuesday, thank you Jason and Keira. Just need to paint a body and then it's off to Cleveland. The car is great I just hope I can drive up to it's full potential.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 10-22-2008, 09:11 AM   #626
protc3's Avatar
You can use the same rollout, just not the same pinion and spur size. The larger diameter tires of the 1/10th scale changes the pinion/spur size over 1/12th. I hope that isnt too confusing.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-22-2008, 09:12 AM   #627
protc3's Avatar
Good luck out there buddy.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-22-2008, 09:19 AM   #628
Jason - I got the new mouting kit for the Lipo tray and installed it this past weekend. It looks pretty good, I did have to raise the the shock mount block up another .030" to a height of .060" to clear the ball cup for the shock. I also used a tall ball stud on top of the pod to keep some angle in the shock. The height of the stand-offs leave just a little space above the battery packs. I think that a very thin piece of foam wil keep the battery from moving around.
Thanks,
Lee Schultz
Founding Member of CORRC
www.OnRoadColorado.com
LeeS is offline   Reply With Quote
Old 10-22-2008, 10:29 AM   #629
protc3's Avatar
Glad you like it buddy. It is a prototype and will be perfect for production. Let me know how it works for you. The small space is for thin foam.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 10-22-2008, 10:51 AM   #630
Sounds good. I am going out of town for the next week. I will get you some pictures when I get back.
I any body using the Losi 17.5 brushless motor and speedo? It has a fan on it and does not quite fit under the rear pod. What I need to know is if I can take the fan off and still be ok.
Thanks,
Lee Schultz
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
