Old 08-10-2008, 08:04 PM   #496
protc3's Avatar
Thanks buddy
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 08-11-2008, 08:44 PM   #497
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
At the risk of making a double post. What the heck is a guy supposed to use to true 1/10th pan car wheels on a Hudy Truer? Hudy has discontinued theirs. I have also tried a couple other brands of adapters but no luck. I have a 10r on the way and I want to get everything I will need to keep it going to minimize downtime. Help!
mrrcguy is offline   Reply With Quote
Old 08-11-2008, 09:01 PM   #498
EricF's Avatar
did you check Integy?
E
EricF is offline   Reply With Quote
Old 08-11-2008, 09:10 PM   #499
MikeXray's Avatar
Trader Rating: 73 (100%+)
RC4less makes a nice one that does all 1/10 pan tires and also 1/12.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-14-2008, 01:45 AM   #500
espresso1967's Avatar
Trader Rating: 18 (100%+)
I just broke some of the ears on my JR z3650 servo and cannot find replacement parts for it or the case. If you have a non functioning z3650 and are willing to part with the case or top plate let me know how much.
If unsure how it looks here is a pic
http://www.jrradios.com/Products/Def...odID=JRPSZ3650
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 08-14-2008, 11:55 AM   #501
Regional Moderator
mrrcguy's Avatar
Thanks! I put one on order.
By the way have any of you had trouble with getting screws to fit in the mounting hole of the Jaco 1/10t Wheel/Tires ?
Old 08-14-2008, 05:58 PM   #502
Jason :
Are you or Adrian planing to make the first state series race this year? I would like to race if I can make it with my GT10 car?What have ya'll decided on motors or batteries. My selection is at this time a 13.5 with either a 4 cell pack or a 3200 lipo pack.Body is the HPI Mercedes.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 08-14-2008, 06:52 PM   #503
JCarr's Avatar
Jason, I got to run a couple laps yesterday. The car ran much better, I put 10,000wt in the tubes and had no problems with the chassis dragging. I only ran about 5 laps cause I grabbed the wrong battery, but it was enough. Thank you for the great support and advice.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 08-14-2008, 08:16 PM   #504
protc3's Avatar
Originally Posted by BullFrog View Post
Jason :
Unfortunately due to an extremely tight schedule, I will only be running the minnreg races. I may do a couple races locally but not many. I wish i could though.
I like the 10.5 w/ 4 cell to be honest. Lipo and a 13.5 is a nice combo also.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-14-2008, 08:17 PM   #505
protc3's Avatar
Glad to hear it worked buddy. Let me know if you have any questions
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-14-2008, 08:45 PM   #506
ffactory666's Avatar
Trader Rating: 19 (100%+)
Hey Jason ,
i know you are waiting on the lipo trays ,did you get my last PM about my order
Also guys looking at 48p gears as i will be running outdoors and lipo and was recommended 74/24 gearing with the Mamba 5700kv motor on 7.4v lipo.
I can't find any 74t spurs , only found Kimborough 48p 72t spurs so what pinion range would i go to for with the same set up , i was thinking 26t - 30t .What about a smaller spur ?
Remember i'm in Australia so even finding simple things like a 48p 72t spur is difficult , i buy probably 85% of my rc gear from the US , Stormer , Tower and A Main hobbies .
No one runs these cars down in my area and most of Australia so i am trying to get my local track to allow me to race with TC for no points.Problem is i can see a few of them complaining if they get into a tangle with me on the track and losing points , they will say that if i wasn't on the track they wouldn't of been in the accident and thus losing position .
At worst i'll just run in practice and between there rounds on my own
ffactory666 is offline   Reply With Quote
Old 08-18-2008, 05:08 AM   #507
Jason what do you think of these saddle batteries , 24mm high http://aedownloads.com/press/in_050608_4800saddle.pdf
Available now
Old 08-18-2008, 07:37 AM   #508
protc3's Avatar
Got your email buddy. I should have the lipo trays out for anodize tommorow. I got your email. I will be putting the prices together for you today. Thanks for your patience.
The saddle pack is nice but on the tall side. The max amps 4000 pack is perfect and not very expensive.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 08-18-2008, 09:52 AM   #509
JCarr's Avatar
Ok two weeks down in the record books and I love this car even more. Now I think I'm ready to start tinkering with some settings and since I am a pan car noob pretty much I come to the experts for advice. I was checking the ride height and noticed that the front was at 6.5mm and the rear was 5.5mm. To adjust the front I need to use shims under the control arms correct? If that is the case I'll need to order some. Also for the rear, I started adjusting with the shock but the realized that IRS parts for the rear axel should do that. Jason do you offer a complete set of the front shims? I have all of the rear height adjusters. I still have a slight problem with the car wanting to skip sideways in some corners and I figure the ride height was what was causing that, or do you think it could be something else in my setup?
Thanks,
Jon
Gorilla Size Racing
Old 08-18-2008, 10:18 AM   #510
protc3's Avatar
We do offer a shim set for the front end.
Jason Breiner
BMI Racing
Team Associated
J Concepts
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
