Old 04-20-2008, 03:05 PM   #256
t4mania's Avatar
Jason, would a thrust bearing like the one from Slapmaster help to smooth out the diff even more. I've done it on my KSG pan car and it really does the job.
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 04-20-2008, 05:19 PM   #257
protc3's Avatar
It wont make it any more smooth but it will make it last longer. Let me give a quick explination. This is in no way bashing or supporting what is available. It will just be explaining the reasoning behind running with and without a thrust bearing.
If i am running at a big event i will never use thrust bearing. I want the diff to be as free as possible with as little drag or resistance as possible. Unfortunately, this leaves me at risk of blowing my diff if i take a big hit. This is a risk i will always take because a diff with minimal drag is the most effective and makes the car handle better.
The reason for this is by using a flanged ball bearing, you are getting a thrust bearing effect without squeezing the balls between washers. The ball bearing spins about as free as an unloaded bearing even when the diff is tight. The only resistance is the balls in the spur being squeezed by the diff rings. Now, with having a diff using a new bearing for a thrust bearing will be doing the job of a thrust bearing with alot less friction. The problem is that when you take a good side shot to the rear axle, the flanged bearing can not take the side load and the inner race exploads or breaks. So in a nutshell, a diff using a flanged bearing for a thrust bearing will yield the best possible diff but will be in danger of going south on you if you take a good hit. Adding a thrust bearing will increase the life of the flanged bearing. A thrust bearing is designed to take a side load. It takes the side load off of the ball bearing and keeps the diff staying smooth for a long period of time. The down side is the added resistance of another set balls being squeezed by washers.You sacrifice the best possible diff for a longer lasting diff. The decision is up to the hobbyist as to which is more important to him or her and what makes them able to enjoy running there cars. If you have your share of wall hits, A thrust bearing is a must so you can stay sane. If you dont crash much and can benefit from a super free diff, you dont really want to run a thrust bearing.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-20-2008, 06:46 PM   #258
t4mania's Avatar
Thanks Jason, I learned something tonite.
FT T4 Dirt Oval
Old 04-20-2008, 06:50 PM   #259
protc3's Avatar
Not a problem buddy. Running a thrust bearing will make the diff feel super smooth for a long time.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-20-2008, 07:08 PM   #260
Trader Rating: 24 (96%+)
is the manual available online in pdf yet? Any setups available to start with for high bite asphalt?
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
http://www.kolorsbykropy.net
nemix is offline   Reply With Quote
Old 04-20-2008, 07:53 PM   #261
protc3's Avatar
The manual and car will be on the website tommorow. I will be putting the box setup on the site this week that will be good for high bite asphalt and club level traction carpet. We have tested the car on every surface and about any condition. The car is extremely adjustable and easy to tune for any surface. It also comes standard with the new BMI linear front springs.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-20-2008, 08:02 PM   #262
thanks - you guys really put allot of work in this car. i dropped you an email to ask about how you shipped out on friday.. what carrier and if you have tracking numbers. Delivery without someone to sign for it in my neighborhood is a pain.
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
Old 04-20-2008, 08:09 PM   #263
protc3's Avatar
I will check with the shipping department on monday. Normally shipments in the US go UPS and international via USPS unless another method is specified by the customer. Either way we will have your tracking #.
We really try to produce the best possible products. Thank you for the kind words.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-20-2008, 08:13 PM   #264
tbeardmore's Avatar
Me too Jason.... I'm hoping it only takes 2 days to get here.... (Saturday and be here tomorrow)....LOL
Wishful thinking I bet?
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 04-20-2008, 08:50 PM   #265
protc3's Avatar
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-21-2008, 05:56 AM   #266
AdrianM's Avatar
BMI DB10R Kits and the instruction manual are on line.
BMI WebStore DB10R Order Page
BMI DB10R Manual
Adrian Martinez
Old 04-21-2008, 06:00 AM   #267
t4mania's Avatar
Hey Adrian, when I click on the DB10R assembly manual I get the manual for the DB12.
FT T4 Dirt Oval
Old 04-21-2008, 07:09 AM   #268
AdrianM's Avatar
Sorry, I just fixed it....
FYI, here are some new pics of the car.
Adrian Martinez
Old 04-21-2008, 04:32 PM   #269
car will be here tomorrow.
advise on what compound foams i should pick up for testing? one track is high bite super smooth indoor asphalt, other is standard carpet
AE TC5
DB12R
DB10R
Losi 8T
Kyosho RB5
Old 04-21-2008, 04:59 PM   #270
protc3's Avatar
I would start with double pink rear and purple fronts. We have been running 2x pink on outdoor high bite asphalt and it has been real good. Indoor may be a little more bite. Run the tires at about 2.150 front and rear.
Jason Breiner
BMI Racing
Team Associated
J Concepts
db10r for sale j manikis R/C Items: For Sale/Trade 19 06-25-2008 05:25 AM
BRAND NEW, never ran BMI DB10R 74VWTECH R/C Items: For Sale/Trade 6 06-24-2008 03:05 PM
