Old 02-09-2008, 01:30 PM   #1
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
Lightbulb Chassis design idea, mid-motor mid-mounted saddlepack style...
So i was looking at chassis pics and stuff...and i notce 2belt drivetrains are the same now as they were with when the HPI Pro came out (and Pro2, heck even the Pro3). Chassis designs all look similar, im sure its the smaller things and geometrys that make them what they are though. Anyways, ive always wanted to see a wacked out "wow thats weird" chassis design that works very well (this is how i feel about the JRXS-R) and thought up of my own.
After looking it, i realized that has never been done because the belts would have to sit too high. So realizing that while sitting here, i drew up this one..
That one looks maybe better? I figure the ESC and RX can go in other places then where i drew them (like down the center behind the battries maybe).
Have either of these designs been done before at all?
Would be awesome to see inboard mounted canti style shocks as low as possible down the centerline as well...not sure how possible that is tho lol.
Yeah im just throwin out ideas, feel free to shoot them down or comment or give thoughts!
Syber Serulean is offline   Reply With Quote
Old 02-09-2008, 01:55 PM   #2
annie_himself's Avatar
Send a message via AIM to annie_himself
They both look interesting enough.
I think the first one is feasible if the belts go through a tunnel so they are protected.
annie_himself is offline   Reply With Quote
Old 02-09-2008, 02:15 PM   #3
Well i have a hard time seeing the first one happen cuz most 2-belt or singlebelt mid-motor designs have the belts run pretty low, and if they run high so they can go over the batteries (in my design) that means the spur and layshaft will have to be higher and possibly even the diffs. I can see the second happening more easily tho if the funny long diffs are used (like in the jrxs or Pro3)
Old 02-09-2008, 02:18 PM   #4
Trader Rating: 38 (100%+)
You need to flip your second one around, otherwise the car would go backwards due to the motor being on the wrong side, would it not?
or8ital is offline   Reply With Quote
Old 02-09-2008, 02:31 PM   #5
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Also for the second one, you would want to have the servo on the same side as the receiver and ESC. to help balance the car.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 02-09-2008, 02:40 PM   #6
could explain why nobody has done it that way, but i suppose BL motors can reverese their directions and work better than way than brushed motors....or no?
And yea, good point about the servo.
Old 02-09-2008, 02:41 PM   #7
I remember my JRXS was like that.
But can't the belts run under and over the batts? Maybe I'm thinking out-loud again..
Old 02-09-2008, 03:01 PM   #8
Jochim_18's Avatar
I have exactly the same layout on my MLPX10P4 From Marty Peterson probably some of you guys know this chassis.
Old 02-09-2008, 03:02 PM   #9
tony gray's Avatar
The rc-lab 7.0 had a true mid-mount motor with belt drive. It ran saddle packs but at the rear.
There's no way (on that car at least) that you could run the batteries down the centre. Not sure it'd work easily on anything?
tony gray is offline   Reply With Quote
Old 02-09-2008, 03:41 PM   #10
GreaseMonkey's Avatar
Looks similar to the OFNA EOB4 or whatever it is called.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 02-09-2008, 04:48 PM   #11
Cosmo's Avatar
That layout is much like the old Ofna OB4 (which was the best handling touring car I had ever driven at the time). The batteries were saddle packs, but on each side in the rear of the motor. The servo, receiver, and ESC were in front of the motor.
That RC Lab car is a virtual mirror image of the Ofna car.
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 02-09-2008, 05:09 PM   #12
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
This has all been done before.
To say that today Touring cars are the same as the HPI PRO/PRO2 even the PRO3 If you had compared todays cars with the early Yokomos like the YR-4SP or Schumacher SST99 then maybe, but right now their are no "new" cars running saddle packs alla the PRO/PRO 2 and as far as the PRO3 goes it's more simular to the JRXS-R that anything.
If you had done a search you would have seen this "design a new chassis exersize" has been done more time than i can remember.
follow me @RC3grafix on Instagram for pictures of my paint work.
PaintingRoly is offline   Reply With Quote
Old 02-09-2008, 05:44 PM   #13
AdrianM's Avatar
You guys are thinking too much about mass centralization across the the chassis. Keep in mind its just as important along the length of the chassis. All the cars gear needs to fit in the smallest square (not rectangle) possible at the center of the chassis.
Adrian Martinez
Old 02-09-2008, 08:04 PM   #14
stiltskin's Avatar
Trader Rating: 102 (100%+)
I remember this being talked about before. The centerline battery and motor pushes alot of weight over either the front of the car or the rear of the car. Not too good for polar moment.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-09-2008, 08:11 PM   #15
Trader Rating: 27 (100%+)
....................R.I.P.
"I can't be any clearer, on how crystal clear I am being"
convikt is offline   Reply With Quote
Any idea what kind of motor is this nazgul Electric On-Road 28 04-08-2013 05:02 AM
17mm Truggy mounted tires and Traxxas style 17mm adapters Cain R/C Items: Wanted to Buy 3 06-07-2008 10:33 PM
Buggy chassis damper, idea from subaru... WheelNut Electric Off-Road 11 02-07-2007 11:17 AM
motor guard idea Iceracer Electric On-Road 2 11-06-2006 10:29 AM
speed+metal=Rosstertail of sparks good idea or bad idea? TC3Racer87 Electric On-Road 6 11-13-2004 09:25 PM
