Old 02-06-2008, 01:57 PM   #1
CREWMAN's Avatar
Trader Rating: 19 (100%+)
Default Tire Compounds
I have ran Jaco foam carpet tires all the time. I was wondering for example is a Jaco yellow compound tire the same as a Parma(or any other foam tire Maker)yellow tire. If not is there a way to figure what compound is equal to another
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 02-06-2008, 05:50 PM   #2
CREWMAN's Avatar
bump
D&K HOBBIES!!!!
Old 02-06-2008, 06:01 PM   #3
Scott S's Avatar
Trader Rating: 30 (100%+)
The only way to know exactly how hard any tire is is to use a durometer. (Here's one I just found online: http://www.pegasusautoracing.com/pro....asp?RecId=349)
A durometer measures the hardness of the foam. It's most commonly used on real race car tires to "match" tires of the same hardness.
Xray T2 007 | Xray T2 | CRC 3.2R | CRC Gen X
Willis Hobbies | 360 RC Speedway & Hobbies | LIR
Scott S is offline   Reply With Quote
Old 02-06-2008, 06:32 PM   #4
Trader Rating: 16 (94%+)
There's more to foam rubber rating than just a durometer rating. The are other chemicals in the foam rubber compounds that change the wear and grip of the foam.
Also, you shouldn't try to compare one brand to another on a durometer only. That will get you in the ballpark, but testing will be the only way to know for sure.
kn7671 is offline   Reply With Quote
Old 02-07-2008, 07:10 AM   #5
Gain Time's Avatar
The tire you run can vary from track to track depending on the grip.
I would ask the guys who run that track regularly what tire they are running. Everyone I have ever asked has always been kind enough to tell me. In fact I have never had anyone refuse to tell me or be rude.
If no one is running the tire you are thinking about running try contacting the customer support of the manufacturer and ask them. I have good luck with that as well. They will want you to run well so you will buy and "sell" their product.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Foam tire compounds? quick5pnt0 Electric On-Road 2 08-02-2007 07:50 PM
Tire Compounds? surreal Rookie Zone 6 09-18-2006 03:11 PM
Tire Compounds HVAC25000 Electric Off-Road 4 02-21-2005 02:28 AM
Ruber tire compounds Intermision Rookie Zone 2 10-15-2003 06:15 PM
Rubber tire compounds ZER01 Electric On-Road 10 07-09-2003 07:08 PM
