Old 02-19-2008, 04:06 PM   #16
imjonah's Avatar
Default I must be missing something
I must be missing something or misunderstand the different requirements of
Brushed and brushless.
From the charts and recomendations I have seen a 19 turn on my TC should have a FDR of between 7 and 8.
The Novak chart says I should run the 13.5 at 4.5
If the 19 turn and 13.5 are roughly equivalent then that is a pretty dramatic difference in gearing.
imjonah is offline   Reply With Quote
Old 02-19-2008, 04:43 PM   #17
big al's Avatar
I've been running my 13.5 w/13mm rotor at 4.9...plenty of punch and speed. The temp stays pretty low. I don't have a temp quage, but I can leave my finger on it comfortably after a 6min run.--Al
big al is offline   Reply With Quote
Old 02-19-2008, 04:53 PM   #18
The Evicerator
it is roughly equivalent in speed, not in gearing!
The power bands between a brushed and brushless motor are just different and being as such, you must gear differently between the two of them.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 02-19-2008, 05:01 PM   #19
Regional Moderator
CarbonJoe's Avatar
No, it is the 10.5 and 19t that are roughly equivalent.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-19-2008, 05:01 PM   #20
The Evicerator
Steve Weiss
Old 02-19-2008, 05:45 PM   #21
RedRocketRacing's Avatar
Default FDR
Soundslike the car manufactures need to find a way to lower the internal ratios in the cars to make these FDR even possible. We are going to have to get the internals down to 1.5 or less to not have to have 50-60 tooth pinions. Right now in my TC5 with a 13.5 I am running a 100/40 for a 5.0 FDR. And that was a pretty smooth gear.
If the internal was less than 2.0 maybe a 1.6 than my FDR would be 4.0.
Time to make those center pulleys a little bit bigger.
RedRocket
Mastercard fresh off of Suspension
www.HomeRestorationsInc.com
Team West Coast Hobbies
NWIC 2008/09
RedRocketRacing is offline   Reply With Quote
Old 02-19-2008, 06:18 PM   #22
call me crazy but the gearing they list for a 17.5 in 1/12 is way under what we are running here for gearing. in my car right now im rolling out at a 81mm. and my motor is comming off the track at around 125 degrees. and im staying with the brushed stock motors just fine.
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
13.5 novak brushless gearing chris c Electric Off-Road 35 12-05-2007 03:18 AM
gearing charts and roll out Mark G Chat Lounge 2 01-23-2006 04:45 AM
gearing charts Titan_TC4 Electric On-Road 2 04-10-2005 08:07 PM
novak brushless gearing ant Australian Racing 4 09-21-2003 07:58 PM
gearing for novak brushless? Elk666 Electric On-Road 0 04-04-2003 10:46 AM
