Old 01-13-2009, 09:35 PM   #601
Rob Burns's Avatar
Is it metric? apart from the axles obviously.
www.RCOttawa.com
Rob Burns is offline   Reply With Quote
Old 01-14-2009, 05:00 AM   #602
Julius's Avatar
All screws are metric.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 01-14-2009, 05:11 AM   #603
Julius's Avatar
Originally Posted by avs View Post
here, maybe this will help clarify the situation with January 08' chassis plates. i added a white tapeline and marked the current hole locations and added black lines on the posts to indicate their respective hole locations. the only way to fit a 3650 servo is by elongating the hole on right in the picture.
Attachment 406014
From your picture I think the right side post is ok.
The left would need a new hole. If the markings you put on the posts are to indicate the respective positions of the offset holes, I think you could drill a new hole to the right of the original hole.
If you drill about 2 - 2.5mm and then countersink from the bottom before making the hole 3mm I believe it will work without running into the stock hole.
I agree the hole locations need some work... They were moved because the futaba servo didn't fit the original holes. The change messed up the JR....
We'll look into slotted holes.
Old 01-14-2009, 08:10 AM   #604
avs
avs's Avatar
agreed, except i don't see any real value in 2 sets of mirror image hole locations, why not use each set to address each servo configuration?
a slot would cover a wider range but then the trick post machining is wasted effort.
avs is offline   Reply With Quote
Old 01-14-2009, 08:13 AM   #605
C Verano's Avatar
Originally Posted by rx7ttlm View Post
hey, pm me or post the part number for those nuts cause that was one of my complaints..
thanks
Here you go Patrick..
http://hotbodiesonline.com/products/en/z676.html
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 01-14-2009, 09:30 AM   #606
Regional Moderator
CarbonJoe's Avatar
Originally Posted by C Verano View Post
Their shipping is completely ridiculous. $9.18 to ship 1 package ($2.00 worth) of wheel nuts? Are you kidding me? FedEx Standard Overnight is $43.18??? Pass me some of whatever they are smoking...
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-14-2009, 10:52 AM   #607
Julius's Avatar
The good thing of the mirror holes is you're able to choose to run the servo left and right.
But that is assuming the holes are in the correct places to use all popular servo's.
I agree with slotted holes the need for offset posts is gone. We'll look into the options available. For the moment bring out the dremel!
Old 01-14-2009, 11:41 AM   #608
C Verano's Avatar
I was just showing Patrick the nut and part number..
Old 01-14-2009, 12:21 PM   #609
gashuffer's Avatar
Trader Rating: 48 (100%+)
Stop showing your nutz and number? I will not say it again! What up Torrance!
gashuffer is offline   Reply With Quote
Old 01-14-2009, 06:33 PM   #610
C Verano's Avatar
What's going on Jersey..How have you been? I haven't seen you in a long time.
Old 01-14-2009, 07:38 PM   #611
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
i am all sad now cause chris showed me his nuts..
that and the ONE time I had my car out it was on asphalt and there was less grip than any track I have EVER run. lame lol.. NEVER got full throttle with a 10.5 how weak is that?
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-14-2009, 11:46 PM   #612
C Verano's Avatar
Old 01-19-2009, 03:52 PM   #613
Trader Rating: 36 (100%+)
Did anyone ever figure out which part was the incorrect part in the new kits, the King Pin or the pivot ball?
And if I order replacements to fix the problem am I going to get the same parts I already have?
thanks
EVILGRAFX is offline   Reply With Quote
Old 01-19-2009, 04:09 PM   #614
Racer Z's Avatar
thanks
You should get the new ones I would think. I got T-Bars a week ago and it looks like a running change. I received the updated ones!! Oh I got a sick set-up for the car. PM me and I will LYK
RC AMERICA, HUDY, XRAY, Nexus Racing, Desoto Racing, 301 Raceway(RIP). XRAY T4/NT1 coming for that #1 spot!! AKA-Melvin Aulston
Racer Z is offline   Reply With Quote
Old 01-19-2009, 06:06 PM   #615
avs
avs's Avatar
thanks
after getting poor results with grinding the pins to fit, i ordered a set of kingpins this past weekend from Stormer and got 0.125" diameter pins. these work with the 'team assosciated' pivot balls which seem to fit ok in the lower arms.
so for now i suggest just purchasing assosciated pivot balls.
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
