Old 01-09-2009, 04:52 PM   #541
Regional Moderator
CarbonJoe's Avatar
Originally Posted by Tral View Post
Where do you buy parts for yours s120?
Do you know online shop anywhere in the world where are all spare and tuning parts instock or they can very fast get them?
http://www.ashfordhobby.com/
http://www.stormerhobbies.com/
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-10-2009, 03:06 PM   #542
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Default rules update
just thought I would share a rules update
01/06/09 1/12th Scale Min Weight
The ROAR Executive Committee has approved the request to increase the 1/12th scale min weight, rule 8.10.3.1, from 794gr to 865gr for the 2009 ROAR On Road Carpet Nationals, hosted by The Gate at the Holiday Inn in Strongsville, OH.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 01-11-2009, 02:58 PM   #543
Sorry for little offtopic but according to this information from serpent.com :
Serpent S120 improved and more complete (17/12/2008)
By:
Ronald Baar
Linked to:
Serpent S120 1/12th scale
The Serpent S120 has made a very strong introduction on race-tracks around the world.
The new look with the one-piece machined rear pod, the unique central monoshock, the adjustable t-bar tweak-station with blades and the fully adjustable front end has brought a lot of innovations to 1/12.
A few area's needed some improvement and that has been taken care of now.
- improved T-bar design
- improved rear shaft
Now as standard in the kit 3 degree, 6 degree and 9 degree front blocks !!
In the process are now more flexible body-posts front and kingpins with allen key adjustment. Will be released as soon as ready and will then flow into kit-production too.
Serpent S120
Ready to race.
I'd like to ask serpent company if they would like to say something to people that bought first version s120 which was far from perfect?
Tral is offline   Reply With Quote
Old 01-11-2009, 07:26 PM   #544
Tral:
It looks that you haven't read the whole tread. Serpent had discussed all this issues and responded to the clients that bought the S120. At least in US, Serpent America had solve some issues under warranty, I recomend to contact the people were you bought the car and check with them.
Edgar Millenium is offline   Reply With Quote
Old 01-12-2009, 02:04 AM   #545
Originally Posted by Edgar Millenium View Post
Tral:
Unfortunately not in middle east of europe where i live.
Old 01-12-2009, 06:01 AM   #546
The Teacher's Avatar
Trader Rating: 49 (100%+)
Hey guys, I just got a S120 kit and a few of the spare parts and I have a few issues. The first issue is with the spare t-bars I got. It seems that the kit comes with 2 2.0mm thick t-bars, one with the holes counter sunk and one without. The spare t-bars I got do not have counter sunk holes. What is the part number for the new t-bars? Will the older t-bars still work and if so is there any modification that needs to be made? My other issue is with the front King Pin that screws into the steering block. For some odd reason it doesn't fit in the bottom pivot ball in the bottom arm. Is anyone else having this problem? Other than that the car is money!!!
The Teacher is offline   Reply With Quote
Old 01-12-2009, 08:26 AM   #547
Fuzzy's Avatar
CarbonJoe - I think I'm going to get one of these. Are there any spare/tuning parts I should buy at the time I buy the kit.
Fuzzy is offline   Reply With Quote
Old 01-12-2009, 08:39 AM   #548
avs
avs's Avatar
yes, i got the same kit as you. it looks like the pivot ball ID is 3.04mm while the kingpin is diameter is 1/8" or 0.125" or 3.18mm. i ground the pin down just to get the thing assembled, but this can't be what serpent really intended for a $300 pan car.
what servo have you tried to install? i used a 3650 per this thread's suggestion and can't get it centered and still get a good hold of the servo (the holes are spaced apart too much) and the holes are symmetrically drilled. (the same problem occurs if you flip the servo)
i installed the countersunk tbar and deferred experiments with the 'new' bar.
avs is offline   Reply With Quote
Old 01-12-2009, 09:03 AM   #549
I tried to use Airtronics 94145 and KoPropo 949 without success.
Is is impossible to mount them in the center using factory servo posts.
Old 01-12-2009, 09:13 AM   #550
serpentamerica's Avatar
Hey Teacher, about the T plates, there is one with countersunk hole an another without. The one without is the latest one. They both work, but one is stronger than the other.
About the King Pin, the factory is already fixing this. For the time being you could also use AE pivot balls, until we get the correct king pins.
Enjoy your S-120
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: [email protected]
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Old 01-12-2009, 09:19 AM   #551
Regional Moderator
CarbonJoe's Avatar
Fuzzy -
I ordered a few extra thin T-plates, a few of the complete front arm "sets" (cheaper than buying individual pieces). Also consider the TiNi coated shock shafts, monoshock shaft, front hinge pins. The TiNi kingpins seem to be out of stock everywhere.
Old 01-12-2009, 09:22 AM   #552
Hello AVS, sorry to hear about the King Pin issue. The factory is already fixing this. For the time being you could also use AE pivot balls, until we get the correct king pins.
Old 01-12-2009, 09:23 AM   #553
Regional Moderator
CarbonJoe's Avatar
My first time out with the S120 and it was dialed! Running the same motor, ESC, tires, and battery packs on the same track as with my CRC GenX, my fast lap time dropped from 10.02 with the GenX down to a 9.67 with the S120. The S120 was very easy to drive, and consistent, with a 9.68 fast lap in the main. This car carries very good corner speed.
Well done!
Old 01-12-2009, 10:06 AM   #554
Geezatec's Avatar
Yes, King pins has to be 2mm shorter. I had to dremel them shorter. For clearance of the rim. If tighten down it would bind the pivot ball, just by out of roundness, not by KP in contact with the pvot ball. E-clip 3mm in manual too large, can use 2.5mm, clip has play works fine, could go 2mm E-Clip for tighter fit. I use the .5 shims(anadized Orange) to seat the e-clip and frt spring, then just the e-clip.
Othrwise, The model is easy to aassemble. Just a bit of QC should be looked at. New model querks we find.
Geezatec is offline   Reply With Quote
Old 01-12-2009, 11:27 AM   #555
Julius's Avatar
You can use the older countersunk t-bars without problem. For added strength when using the countersunk t-bars, flip them upside down and use the flat head screws. It helps because it removes the added pressure from the countersunk screw.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
