SERPENT 120
#241
electronics
Markus: did you place your ESC on the left side of the car? I am worried about weight balance. The motor is more on the left side, the servo is more on the right. The motor is more heavy than the servo. The ESC with cables is more heavy than the receiver, so in theory if I put the ESC on the left then I will get a car which is more left side heavy. Is this correct? At the same time, putting the ESC on the right will need more cable which means more weight. How did you do it. Your solution is good enough for me
OZe
OZe
#243
He guys!!
Ok, I have placed the servo to the right. You will have more space for the big BL speedo than. On the right there is still enough space for receiver and personal transponder. I have shrinked my receiver. Also the right side of the rear axle is much heavier than the left (due to diff parts), so the placement is fine.
Further I added titanium screws everywhere and shortened all wires to maximum. My car is 856, which is cool!
Greetz
Markus
Greetz
Markus
#244
P.S.: I also run LRP motors....they have a shorter endplate as an option, which is also good for the balance....
#245
He guys!!
Greetz
Markus
Greetz
Markus
Would you mind posting a few pictures of your car. I would like to see the layout of it.
Thanks,
Steve
#246
Suspended
#248
Had the frist weekend race with the car. Came in 3rd at the end
Car was running good. I had technical probs in all 3 qualies, the car was very good in finals.
Thin Tbar is very good.
Had one major technical problem: the side shock rod broke in the 2nd qualifying.
Differential works great and smooth, I made one modification: used 1/8" ceramic diff balls.
Followed Markus' advise on setup. Worked very well.
#249
There you go man!
#250
I found when building my S120 that the side shock shaft gets stressed when you tighten the screws that hold it in place. I suggest using locktite and only applying minimal pressure on the shaft when tightening. Another option I am using currently is a M3 nylon screw. It has a bit of "give" and puts no stress on the shaft.
Another thing to check is the top ball link of the center shock. Due to the angle of the shock the nylon ball link "rests" on the lip of the ball. I slightly beveled the underside of the nylin ball link so there is a bit more room. That way the shock sits tension free.
Good luck racing.
Julius
#251
Thanks, Julius.
Will try to use nylon shims. That should also work.
Good advise on the center ball nest, too.
#252
Suspended
any news edgar?
#253
Hi Oilman:
This week they started to be delivered, If you want I can verify what hobby shops had ordered it.
#254
Suspended
#255
Hello there!
Here is my black S120.
Michael
Michael
