Old 10-11-2008, 04:20 PM   #226
Originally Posted by Tral View Post
Unfortunately not centered
Associated vs Serpent 0:4
T-bar
Front axles
Left hub
Servo posts
Did you try flipping the servo over and use the other holes in the chassis? I know that CRC puts to sets of holes in their chassis so you can use different widths of servos. For a JR3550, I have to use the holes on the left side of the chassis. For a Futaba 9602 or 9650, I have to use the holes on the right side of the chassis. I race Serpent 1/8th cars and they are always very detailed and well finished cars. I can't believe that Serpent would miss the target on how the servos mount.
Crashby is offline   Reply With Quote
Old 10-11-2008, 06:59 PM   #227
I checked all positionsm also servo on left and servo on right. This is airtronics 91145, i used it in rc12l4, corally sp12m Ahoniemi edition and corally sp12x and was always centered.
Tral is offline   Reply With Quote
Old 10-11-2008, 10:49 PM   #228
oze
Originally Posted by Mr. Blonde View Post
2. Try following:
Use 45 weight oil (1400 cst) in the side damper and move the tweak backwards. (stiffer)
Worked damn good on my car tonight. (high grip track)
Hi Markus, what would you use on a bumpy track with high grip?
oze is offline   Reply With Quote
Old 10-13-2008, 12:14 AM   #229
hultan47's Avatar
By the way, do you also have unbalanced left wheel? In my car left hub is badly made, it doesn't center left wheel.
Yes, it does not center(that sounded strange,yes does not), so I got a slight unbalanced rear left!
To make things worse I think my tiretruer or adapter for 1:12 is offline to. So it seems I have unbalanced wheels all around!
I will also try MrBlondes tips on oil in side damper on our surface thats not that high grip. I think it can work there to. But itīs a week away, we only drive sundays!
/Stefan
hultan47 is offline   Reply With Quote
Old 10-13-2008, 05:56 AM   #230
@oze:
I actually ran on a bumpy track with the setup I quoted above.
@all:
I am running a JR servo (3650) and that is centered perfectly.
Markus
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Old 10-13-2008, 06:45 AM   #231
hultan47's Avatar
2. Try following:
Greetz
Markus
Hello Markus
Thanx for all help, but I still have a question for you. Should I use the piston with 2 or 3 holes. Question goes for both dampers.
Best regards
Stefan
Sweden
Old 10-13-2008, 06:57 AM   #232
He!!
Use 3 holes in both!
Markus
Old 10-15-2008, 12:34 AM   #233
hultan47's Avatar
Got new T-bars yesterday. Will try to fix the car, try different oils in side damper, hopefully break no T-bars this weekend.
If I look at the broken thick T-bar and the thin that I got yesteday it seems that the screw is not countersunk as much. For obvious reasons when the T-bar is not as thick
Hope Markus is right when he thinks the thin T-bar is better lasting!!
/Stefan
Old 10-15-2008, 01:57 AM   #234
He!!!!!
Be sure the thin t-bar is much! better!
Also there will come new thick ones in a couple of days.
Markus
Old 10-18-2008, 08:09 PM   #235
Hi guys:
The S120 is finally in US, we got our first shipment this week. As you all heard we are organizing the new warehouse. This kits will be soon on local hobby shops.
Regards
Edgar
Edgar Millenium is offline   Reply With Quote
Old 10-19-2008, 05:23 AM   #236
He guys!
Went to practice again on thursday and friday and found out some more.
Go to 1400st oil in the side damper. Use 0,55 springs front with a 3 degree caster block. Also take a red center shock spring.
I used Jaco Prism dp rears with Jaco Prism magenta fronts....car was flying now and I set a new track record at my home track.
Apply rear additive 20 min before race and front 5-10 minutes (half).
Have fun!
Markus
P.S.: I used a Parma Speed 8 HD shell.
Old 10-19-2008, 07:13 AM   #237
chicky03's Avatar
Send a message via AIM to chicky03
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 10-19-2008, 07:20 AM   #238
*lol*
Old 10-19-2008, 01:25 PM   #239
He guys!
Have fun!
Markus
Thx for all Markus
Regards
Jean-Alain
...the french friend of Ronald!
JudgeFR is offline   Reply With Quote
Old 10-20-2008, 12:55 PM   #240
Suspended
Originally Posted by Edgar Millenium View Post
Hi guys:
Regards
Edgar
damn i cant find one...who has it?
OILMAN is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
