Old 10-09-2008, 02:03 PM   #211
John_S's Avatar
i also broke my t bar at the rear pivot point. If you look at it there only 4 1.5mm sections of t bar across that section. I think it would of been stronger if they had fitted the pivot ball 45 degrees from where it is just now as this would stagger the holes
John_S is offline   Reply With Quote
Old 10-09-2008, 04:25 PM   #212
Suspended
when is the s120 gonna hit the states?
OILMAN is offline   Reply With Quote
Old 10-10-2008, 12:26 AM   #213
hultan47's Avatar
Thanks Marcus, but...
"P.S.: The page is on german though :-)"
There Iīm lost
From what Iīve hear there is another T-bar in the makings because of this problem. Maby I shuldīnt went this here but thats what my retailer have said.
Hopfully I will have a few options in the mailbox today, and a set of T-bars.
Have a great weekend you all!!!
Stefan
hultan47 is offline   Reply With Quote
Old 10-10-2008, 12:53 AM   #214
hultan47's Avatar
Adrian
When you say that the servo donīt fit. Is it because it doesnīt center in the car?
If so I have the same problem!!
Stefan Hultgren
Sweden
Old 10-10-2008, 05:34 AM   #215
Originally Posted by hultan47 View Post
Adrian
Stefan Hultgren
Sweden
What servo do you have?
In all s120 there are 4 servo posts. If you look closer you will see that they are not the same. the difference is possition of hole in the bottom.
So there are 4 different option to mount servo x2 because you have 4 holes in chassis. But those in chassis are simmetrical.
Tral is offline   Reply With Quote
Old 10-10-2008, 05:43 AM   #216
Hi,
What Futaba servo can be used?
Jean-Alain
France
JudgeFR is offline   Reply With Quote
Old 10-10-2008, 06:43 AM   #217
Originally Posted by JudgeFR View Post
Hi,
Jean-Alain
France
Try this:
http://www.12thscale.info/index.php?...id=22&Itemid=2
Old 10-10-2008, 08:07 AM   #218
hultan47's Avatar
Thank you Tral
I have tried them all No, just kidding. I took the best position that got the servo most center. I also notised the different servoposts so there for i tried!!
Thanks annyway!
Stefan
Old 10-10-2008, 08:47 AM   #219
Thx a lot
Old 10-10-2008, 08:53 AM   #220
hultan47's Avatar
Thatīs the one I use I think. Do you have that perfectly centerd in the car? With the servoposts delivered in the kit?
Iīm curious!!
Stefan
Old 10-10-2008, 03:18 PM   #221
He guys!!
Two things:
1. We think there is a problem with the material of the thick t-bars (original in the kits)
I always use the thin t-bar and I really do not have a problem at all. The t-bar I have in my car now is about 50 packs old, even with some good crashes :-) We are checking the thick t-bars issue right now.
2. Try following:
Use 45 weight oil (1400 cst) in the side damper and move the tweak backwards. (stiffer)
Worked damn good on my car tonight. (high grip track)
Greetz
Markus
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Old 10-10-2008, 03:51 PM   #222
Stefan, i will reply you later as soon as i will take my car in hands.
The problem with t-bar is very simple.
The problem is those 2 holes marked in green.
When you cut t-bar in line marked in red you will have in this point only few square mm surface.
I hope you anderstand what i mean.
Men who did that is idiot in my opinion and should never project any part.
By the way, do you also have unbalanced left wheel? In my car left hub is badly made, it doesn't center left wheel.
Old 10-11-2008, 05:24 AM   #223
Unfortunately not centered
Associated vs Serpent 0:4
T-bar
Front axles
Left hub
Servo posts
Old 10-11-2008, 12:22 PM   #224
JayBee's Avatar
Trader Rating: 31 (100%+)
So NO current servo fits on the car centered? That sucks for such a good looking car.
For those that have made do and have run the car, how does the front end hold up? That front end looks killer. I kind of want to try it on my DB12R.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 10-11-2008, 02:07 PM   #225
protc3's Avatar
If you want, you can run the AE slotted servo mounts. You want the servo to be centered. Turnbuckles need to be the same length for correct geometry.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
