Old 09-02-2008, 05:51 AM   #196
hultan47's Avatar
Have anybody tried the car on carpet yet? Iīm curious because I think I will buy one. Looks nice!
hultan47 is offline   Reply With Quote
Old 09-18-2008, 02:10 PM   #197
oze
Hi Guys, does anyone have got a good setup for this car - for carpet?
Bumpy, and fast track.
oze is offline   Reply With Quote
Old 09-18-2008, 05:59 PM   #198
Suspended
i would like one too....
OILMAN is offline   Reply With Quote
Old 09-26-2008, 03:47 PM   #199
Suspended
any updates?
Old 09-29-2008, 05:02 AM   #200
Hu guys!
To start of with, use standart front springs.
I use 3 degree block or 6 degree block with medium caster.
(depends on traction)
Use the long upper arm.
Rear:
- thin t-bar
- red center spring
- 30 wt oil in center shock
- 800 st oil in side shock (as in kit)
- start of with soft tweak
- if car is nervous or lifting wheels go to harder tweak
- use rear cell position (if traction toll go up front)
Hope this helps.
Greetz
Markus
P.S.: Tires rear Jaco yellow or doublepink
Tries front Jaco lilac or double pink
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Old 10-02-2008, 01:37 PM   #201
Suspended
Originally Posted by Mr. Blonde View Post
Hu guys!
Rear:
- thin t-bar
- red center spring
Hope this helps.
Greetz
Markus
can we see some pictures?
Old 10-03-2008, 03:40 PM   #202
Did you try to use 1/8"(3,175mm) balls instead of 3mm in spur gear?
I would try but do not have time. I think it could work better.
Tral is offline   Reply With Quote
Old 10-06-2008, 12:44 AM   #203
hultan47's Avatar
Default Att: Mr Blonde
Hi there, got my car, built it, tryed it. Third battery my T-bar broke. Is this something to get used to? We have an open track with cornerdots. No walls to hit. The T-bar broke straight of thru the holes for the screws of the rear pivotball.
Then I wonder about the tweakparts, what is an god start? My car felt a bit "square" in corners. I would like a car that "rolls" thru corners to make a round corner. Tried to move the "tweaksled" rearwards and felt the car worked better on our lowgrip carpet?? Shouldīnt it be the opposite?
Best regards
Stefan Hultgren
Sweden
Old 10-06-2008, 04:42 AM   #204
Hi Stefan!
Well....not all the time a soft tweak is good on low grip. If the track is very open corner speed is high and the car moves a lot. Than a harder tweak could be better.
Make sure you play around with hardness of side damping. Usually when I stiffen up the tweak, I stiffen up the damping a little too.
Greetz
Markus
Old 10-08-2008, 01:05 AM   #205
hultan47's Avatar
Thanks Marcus
I will try these things as soon as I get hold of a new T-bar!!
Refering to side damping I asume I try different oils for the damper. The 800 oil in the kit, is this a hard or light oil for side damping?
Best regards
Stefan
Old 10-08-2008, 05:15 AM   #206
Hi Stefan!!
The 800 cst oil is more medium....but for myself I would would go up with the viscosity.
Greetz
Markus
Old 10-09-2008, 12:25 AM   #207
hultan47's Avatar
Thanks Marcus
Itīs a god thing itīs so good looking that car, then I can just look at it and be satisfied.
We only drive indoors on sundays, and it looks that I wont get a new T-bar for this weekend. Maby I can change oil in the damper instead
Best regards
Stefan
Old 10-09-2008, 12:45 AM   #208
Stefan, go on www.speedtechrc.de and drop me an email, maybe I can help you out. We got t-bars in stock.
Greetz
Markus
P.S.: The page is on german though :-)
Old 10-09-2008, 01:46 PM   #209
Hi, I've just got my car. I wonder which servo I can use in this car. I've tried my Futaba 9650, but it did'nt fit.
So I hope anyone can help me to tell which servo I can use
Adrian Berntsen, Norway
AdrianB is offline   Reply With Quote
Old 10-09-2008, 01:53 PM   #210
He Adrian!
Another gas driver, who rill run 12scale in the winter :-) Fine!
Well, we use Graupner DS3781 or JR3650 mostly in our cars.
Greetz,
Markus
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
