Old 01-10-2009, 03:53 PM   #1711
Send a message via AIM to John St.Amant Send a message via MSN to John St.Amant Send a message via Yahoo to John St.Amant
WHATS WITH ALL THE SLOP IN THE UPRIGHTS?
THE BUMPER ISNT VERY TOUGH EITHER.
John St.Amant is offline   Reply With Quote
Old 01-10-2009, 05:04 PM   #1712
Suspended
dude for someone who runs this car you sure have a lot of complaints...
.....rayzerdesigns.....www.jconcepts.net...
i am cornholio is offline   Reply With Quote
Old 01-10-2009, 07:12 PM   #1713
HAHA what up corn. You ready for the birds mayne?? What ever slop no slop car is still bomb. You peeking on the thread shopping for a car? Str8 en out. Give me a call aight late
WEEZY is offline   Reply With Quote
Old 01-11-2009, 12:50 AM   #1714
Canyon's Avatar
Trader Rating: 8 (91%+)
Coopa you're such a gangsta! LOL
Canyon is offline   Reply With Quote
Old 01-11-2009, 08:45 AM   #1715
I have owned a lot of cars. Everything from 12th to 8th on and off road.
I have never seen such slop in ANY bearing holder in any location. The big bearings move around in the blocks so much you can not accurately adjust camber. Not only that but the rear toe in is affected greatly and compromises the stability of the car. As of right now I have not found this car competitive on the sticky carpet. All it does is steer way too much and usually spin out. And I do have a clue. Seems to me this cars forte has to be on the pavment. I have still to see a good carpet (one way) set up. The two on the wolf hobbies site dont work at all on my home track. But then again I have had little time to practice with it.
Old 01-11-2009, 04:03 PM   #1716
Eddie M's Avatar
You can always put in some green loctite or thin CA to address the slop. I ran the car as it and I think the car is quite decent even with all the slop.
I guess people are spoil by XRay quality but it does cost a fortune to get one new. I remember the good old TC3 are quite sloppy back then and yet they are still very competitive.
Eddie M is offline   Reply With Quote
Old 01-11-2009, 05:22 PM   #1717
Suspended
stiffen up the front end or raise the arm mounts in front..add a little more rear toe..as for the bearing slop..a little drop of ca will take care of that..or you could try the aluminum steering blocks and hubs..i will say the potential of this car is very high..and yes weezy im very interested..after snowbirds though
Old 01-11-2009, 11:20 PM   #1718
katfish317's Avatar
I tried the carpet setup myself yesterday, it was my first ever time running rubber tires on carpet and it was not very good there either. We moved the shocks all the way in, moved the camber links too the inside hole front and rear, and added 2mm shim at the rear ballstud. It worked pretty well for me but as the tires got up too temp during the race the last two minutes ot got loose. You might try running less camber in the front and put another half degree in the rear.
Of course I am running the factory springs right now as I have no others, gotta place an orer for parts soon.
Over all the steering and handling of the car too me is great, just need some setup work!!!!
katfish317 is offline   Reply With Quote
Old 01-11-2009, 11:26 PM   #1719
katfish317's Avatar
Also, what are people doing ot loosen the drive train in this car??? I have the Kfactory belts, and have changed all the midshaft and mainshaft bearings to ceramics. All the wheel bearings have been changed to Avid rc revolution bearings. I have not changed the diff bearings as of yet as the first order they were not in stock, but I ordered some tonight and hopefully that should do it.
My other car a TC5, that I raced last year is very free. You can spin the tires by hand even with a brushless motor and they freewheel a while. This car does not do it yet but hopefully changing the diff bearings will help free it up.
Thanks for any info!
Tim
Old 01-11-2009, 11:37 PM   #1720
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
I found the drive train to be very smooth. Dosnt feel very free but i think thats the way it is, maybe because of the 3 belts. I Have ran the car in mod for about 7-8 runs now.
mild seven is offline   Reply With Quote
Old 01-11-2009, 11:42 PM   #1721
I also ran the tc5 before this car and the drivetrain was pretty good. Are you running on carpet? I took the seals off my carpet car and soaked the bearings in motor spray in a little jar. Got all the grease out of them. Then i just re-oiled them with a bearing oil. It helped alot with the drive train. I am using stock belts and bearings and my car spins pretty smoothly.
Old 01-12-2009, 08:39 AM   #1722
Send a message via Yahoo to milton6599
What's up guys!
What's is the best set-up for the spur and pinion gear on carpet? I'm running a E4 FS with rubber,Tekin RS 17.5, LiPo.
HPI SPRINT 2 FLUX. 21.5
TEAM MAGIC E4 FS. 17.5
TRAXXAS SLASH
TAMIYA TT-01
SPEKTRUM DX3S
TEKIN RACING
HITEC
TEAM ORION LiPo
ROAR MEMBER No 5-118577
milton6599 is offline   Reply With Quote
Old 01-12-2009, 12:22 PM   #1723
Trader Rating: 26 (100%+)
is there a trick to getting a brushless motor in and out. im usng a tekin and a orion and have to remove belt tensioner and mount?
eddie10 is offline   Reply With Quote
Old 01-12-2009, 12:25 PM   #1724
Originally Posted by milton6599 View Post
What's up guys!
How big is the track? Is it fast and swoopy or all turns?
go to
http://www.gearchart.com/index.cfm?f...n=chart.create
you need to know your internal ratio. if its the same as mine it's 2.0588
I'd start around 4.2 if its a small track. Use no more than 152 teeth and no less than 145 teeth combined and you will find a sweet spot for your track.
Good luck man!
Old 01-12-2009, 02:20 PM   #1725
go to
Good luck man!
Thanks I'll check it out. Right now I'm running a 51 pin, 88 spur.
I race at " The Track"
I say it's fast and swoopy.
What do you use for the springs??
TRAXXAS SLASH
TAMIYA TT-01
SPEKTRUM DX3S
TEKIN RACING
HITEC
TEAM ORION LiPo
team magic m1b pitdog Nitro Off-Road 447 04-30-2013 09:17 AM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 02:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 05:51 AM
Team Magic G4 J_Longbrake R/C Items: For Sale/Trade 0 10-07-2004 07:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 11:40 AM
