Old 02-01-2008, 11:59 AM   #1
Default Differences Between Protoform190mm Mazda 6 and Speed 6
Hey,
I am wondering if anybody has run both these shells and what were the differences on carpet and asphalt??
Thanks in advance.
Bryan D is offline   Reply With Quote
Old 02-01-2008, 01:08 PM   #2
Trader Rating: 1 (67%+)
On carpet I prefer the speed 6, it seems to keep the car more balanced. The regular 6 made the car get a little nose heavy.
Also the light weight body made the car feel more stable, a touch less steering but you could drive it harder.
As for the asphalt.....I have not done enough testing back to back to give you an answer.
Josh Hohnstein is offline   Reply With Quote
Old 02-01-2008, 02:10 PM   #3
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Bryan D View Post
Hey,
Thanks in advance.
for asphalt:
on my TC5 using the same set up and tires... the Speed6 has more steering than the Mazda6. it loosens the car up a bit more. With Mazda6.. the car is more stable. Speed6 = more edgy, aggressive. hope that helps.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-01-2008, 02:51 PM   #4
Great thanks for the info guys!!
Old 02-02-2008, 02:48 PM   #5
(indoor)The mazda6 is most of the time and at the most tracks faster then the speed6. I even tested it today:i drove 2 minutes with the mazda6 then i changed quikly to the speed6 and i continued my run,i was about 1a2 thents slower per lap,then the same run ik changed back at the mazda6 and i was back on pace.There is only one of the six indoor tracks i know where the speed6 is faster then a mazda6.
I find that most of the time the mazda drives smoother and has more coner speed then the speed6.
Outdoor i dont know wich one is faster,i ame going to test it this summer.
Grtzz
sitting duck is offline   Reply With Quote
Old 02-03-2008, 06:12 AM   #6
stiltskin's Avatar
Trader Rating: 102 (100%+)
I may be wrong, but I believe that the Mazda 6 is supposed to be a foam body and the Speed6 was made for rubber.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-03-2008, 09:04 AM   #7
stuey's Avatar
yeah your wrong std mazda is more stable than speed 6 the speed tends to have a little more off power steering
stuey is offline   Reply With Quote
Old 02-03-2008, 10:39 AM   #8
stiltskin's Avatar
http://prolineracing.com/protoform/index.html
Actually I was right.
Tony Rumple
Old 02-03-2008, 10:57 AM   #9
Originally Posted by stiltskin View Post
Sorry, but no. Both mazdas are rubber tire bodies. The mazda speed6 fits in between the mazda6 and stratus 3 handling wise.
Mr_Orange is offline   Reply With Quote
Old 02-03-2008, 11:23 AM   #10
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
Apparently you didnt read the website, he was right.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 02-03-2008, 11:36 AM   #11
Yeti35's Avatar
Where does it say anywhere on that site that the Mazda 6 was for foam? I looked and did not see it. If it were a foam body why does no one even use it for foam. You see it run on carpet, but with rubber, not foam. The Speed 6 description mentions carpet, but does not mention foam at all. I think you are reading too much into it.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 02-03-2008, 01:16 PM   #12
Korey Harbke's Avatar
Both bodies work best on rubber tires. They are both relatively high downforce bodies in comparison to the ones we typically run on carpet with foam tires like the Parma Alfa, Mohawk, and Protoform DNA.
But... back to the original question. In my experience, the Mazda 6 is smoother, a little easier to drive. Sometimes with the MazdaSpeed 6 I find it too aggressive, and the back end of the car will step out in the middle of the corner with it... sorta zaps that corner speed sometimes.
Usually really low grip tracks... I run the MazdaSpeed 6 but move the wing back pretty far. Just helps glue the entire car down a little better. For high grip stuff I'll run the normal Mazda 6.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-03-2008, 02:19 PM   #13
stiltskin's Avatar
When I made the original post, I based it on experience not what the website says. When the Mazda 6 came out, it replaced the Dodge Stratus as the body of choice in the U.S. where foam is definitely more popular. I read on the website that the Mazdaspeed 6 was the next generation of rubber tire body and posted it. Now that I read the site , I'll agree that both bodies were made for rubber tires and the Mazdaspeed 6 was the "next generation" rubber tire body. Sorry if I've gotten anyone's panties in a wad.
I haven't driven the Mazda 6 yet, just the DNA2 and the Mazdaspeed. I like the Mazda better.
Tony Rumple
Old 02-03-2008, 05:49 PM   #14
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
I agree with Korey. The regular 6 is smoother and easier to drive than the speed 6.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-09-2008, 11:15 AM   #15
bboy's Avatar
I have had 2 Mazada 6 and I definitely have no complains on my TRF416.
One question though, how do you guys cut the holes on the wings? I find them quite tedious and difficult to make perfect.
Any suggestions?
bboy is offline   Reply With Quote
Mazda 6 or Mazda Speed body Fast XXXS Australia Wanted to Buy 4 07-05-2008 11:01 AM
Differences between o.s speed .21 v-spec speed alum and magnesium. Hans_Andersson Nitro Off-Road 11 06-23-2008 06:02 PM
TC Body Comparision - Mazda 6, Mazda Speed, Ride RI196 TSX, Alex Racing LX-250 Tsquare Electric On-Road 4 04-02-2007 08:18 PM
Mazda 6 vs Mazda Speed 6 coons88 Electric On-Road 2 02-03-2007 10:25 PM
Mazda Speed 6 or Mazda 6 RCpurplecow Electric On-Road 24 11-30-2006 08:49 AM
