Old 01-30-2008, 09:55 PM   #1
Default LRP Sphere Competition TC Spec fan HELP!
Hi,
I need help here:
Sad news..... The fan on my Sphere competition TC-Spec broke! Are there any replacement fans I can installed on it? Or do I have to send it to LRP? Is it safe to run without the fan?
trf_racer is offline   Reply With Quote
Old 01-31-2008, 02:00 AM   #2
Send a message via ICQ to Jan Larsen
Any fan will work, as long as it's rated the same and has the same size as the original fan. The fan wires on the TC go into the case, so you have to cut them and solder them back together with the new fan wires. It will void warranty though. But it'll beat sending it back, as that'll take months.
Jan Larsen is offline   Reply With Quote
Old 01-31-2008, 05:20 AM   #3
I don't care about the warranty as it is only 90 days and I think I am near the deadline anyways. Will this fan work? Do you think this is the same spec?
Old 01-31-2008, 05:39 AM   #4
Yes. Having the plug on aswell means you can choose from the plug or solder it together. Soldering makes it look clean, but the plug is easier. Your choice really
Old 01-31-2008, 08:15 AM   #5
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
I use a novak fan
the LRP fan broke the first 2 or 3 race days out with it LOL....
Novak's still kicking
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 01-31-2008, 11:41 AM   #6
So that mean if I am using the connector on that fan, I will have to solder on a connector on the ESC?
Old 01-31-2008, 11:49 AM   #7
burito's Avatar
No, you can simply plug the connector into a free slot on the receiver. Doesn't get any easier then that...
Reto Koenig
burito is offline   Reply With Quote
Old 01-31-2008, 02:52 PM   #8
Will that cause interference problem? I have issues when I plug a fan directly to the receiver.
Old 02-01-2008, 01:30 AM   #9
burito's Avatar
It should not cause any interference, since it is soldered to the same BEC line inside the speedo anyway as well.
I did this on many speedos to connect it to the receiver and it never caused intereference.
But I can obviously only say it worked with our fan, not sure if others may cause a problem in regards of intereference.
Reto Koenig
Old 02-01-2008, 02:36 AM   #10
Reto
you have pm
Growler is offline   Reply With Quote
Old 02-01-2008, 04:27 AM   #11
Thanks Reto
Old 02-01-2008, 07:12 AM   #12
Thanks for your reply.
One last question, do that fan have the same spec as the original fan on the ESC?
Old 02-09-2008, 11:17 AM   #13
bboy's Avatar
The only thing you have to be aware if you plug the new fan to the receiver is that you will loose the slot for the motor fan!
I personally use both the motor fan and the LRP fan the same time and I try to use the spare receiver slot for the motor though this is just my preference.
bboy is offline   Reply With Quote
Old 06-25-2010, 10:56 AM   #14
my fan broke too.
What size fan is it? I see several novak fans. 25x25 and 30x30. I want the fan to actually work and not be so loud with its broken blades.
mcdragon2 is offline   Reply With Quote
Old 04-05-2011, 10:58 AM   #15
Gabriel2010's Avatar
Trader Rating: 35 (100%+)
Send a message via ICQ to Gabriel2010
Default Esc
It looks like Lrp Sphere Comp Tc Spec is working fine with the truck. What motor should I run with it ?
Gabriel "Gabe" Galeano.
Kyosho / Pro-Line Racing / Maxy's Pro Fuel Racing / Novarossi / Orion / Futaba / Stickit 1 Racing / Gens Ace/Tattu Lipos / Leadfinger Racing / Samuelson's Design / FTM Grip / Boca Bearings / PT RC Racing / Mushroom Bowl Raceway & Hobby / MBRC.
240-398-0471 RC Sign up= gabrielgrc2011 [email protected]
Gabriel2010 is offline   Reply With Quote
WTB: LRP SPHERE COMPETITION TC SPEC ESC Tuffy34 Australia Wanted to Buy 0 08-27-2008 05:52 AM
FS: LRP Sphere Competition tc spec ESC skriete R/C Items: For Sale/Trade 5 03-12-2008 06:58 PM
new sphere competition TC spec WAYNE SR R/C Items: For Sale/Trade 5 03-09-2008 04:38 PM
NEW LRP Sphere Competition TC-Spec w/X11 3.5 G Mills R/C Items: For Sale/Trade 3 09-13-2007 05:05 PM
sphere Competition TC Spec ESC Racers Concept Australia For Sale/Trade 6 06-12-2007 09:06 AM
